On Wed, 21 Jul 2004 17:27:38 -0400, "Richard Kaplan"
wrote: So why dont' we see lots of homebuilts eliminating separate cylinders? There are some great minds in the homebuilt community and minimal FAA regulation. Are you kidding Richard? There are hundreds and hundreds of homebuilts flying with Chevy V-6's, Ford V-6's, Subaru fours and sixes and numerous other types of auto conversions. There must be at least six companies producing firewall forward "turnkey" engines. Corky Scott |
![]() "Michael" wrote in message om... First off, turbine engines are not out of the questions at all. The reason they are so incredibly expensive has a lot to do with the FAA and milspecs. Second, turbine engines are inherently more reliable - So why hasn't someone developed an inexpensive, reliable turbine engine for experiental airplanes? sufficient mechanical stability, so everything moves too much. Note that the two modern aviation piston engines - the Thielert and Orenda - have abandoned that nonsense. What planes are these used in? Do you have any references about these? Driving cars made in the last 20 years? I find that amazing. Well as one example I experienced a sudden catastrophic engine failure this year in my 1999 Toyota minivan. An engine cooling fan circuit malfunctioned and the engine overheated while driving in a snowstorm. I pulled over right away but nonetheless the engine block had melted and I needed a new block and new cylinders... $8000 in warranty work repairing the engine due to failure of a $125 part. Experimentals are amateur-designed. The engine installations are amateur-designed too. The very fact that after the first 50 hours are flown off the accident rate appears to even out with the certified airplanes should suggest to you what a disaster the FAA-mandated professional engineering is. Amateurs can do almost as well working in their garages. Well can anyone do BETTER than FAA certified airplanes? Who in your mind can produce an airplane with a more reliable engine than an FAA certified engine? -------------------- Richard Kaplan www.flyimc.com |
"Richard Kaplan" wrote
So why hasn't someone developed an inexpensive, reliable turbine engine for experiental airplanes? First off, that's in process. There's already an RV-4 flying with one, and there's a company now developing them. sufficient mechanical stability, so everything moves too much. Note that the two modern aviation piston engines - the Thielert and Orenda - have abandoned that nonsense. What planes are these used in? Do you have any references about these? The Thielert is used in the new Diamond twin. The Orenda is used in certain agricultural aircraft, and is an STC'd replacement for the King Air. Well as one example I experienced a sudden catastrophic engine failure this year in my 1999 Toyota minivan. An engine cooling fan circuit malfunctioned and the engine overheated while driving in a snowstorm. I pulled over right away but nonetheless the engine block had melted and I needed a new block and new cylinders... $8000 in warranty work repairing the engine due to failure of a $125 part. You are the only person I know who has had that happen. It's extremely rare. On the other hand, I can name quite a few such situations with certified engines that happened to people I know. I've had an engine die because a little rust clogged the fuel injectors. Turns out the drain plug in the fuel servo was steel. No, it was not an illegal replacement - it was steel by design. If I were to replace it with non-rusting brass or aluminum, that would be illegal. A friend had an engine die because the drive to his dual-mag sheared. Bad metal. Another had an engine die on takeoff because the scat tube that carried the air collapsed. It was an STC'd installation. When he replaced the scat tube with aluminum, that was illegal. I could go on and on. Well can anyone do BETTER than FAA certified airplanes? Who in your mind can produce an airplane with a more reliable engine than an FAA certified engine? Any professional operation. Toyota, Honda, GM, Ford, Bombadier - ANYONE. But not some guy working in his garage. The fact that some guy working in his garage on a shoestring budget can come close should tell you what a disaster the certified engine is. Michael |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
