Sport Pilot Final
Old July 20th 04, 05:30 PM
Gilan
Default Sport Pilot Final
http://www.flyinggators.com/news/LSA/SPrule.html
Have a good day and stay out of the trees!
See ya on Sport Aircraft group
http://groups.yahoo.com/group/Sport_Aircraft/
Old July 20th 04, 06:06 PM
Richard Isakson
Also at:
PDF:
http://www.sportpilot.org/sportpilot_rule.pdf
WORD:
http://www.faa.gov/avr/arm/rulemakin...otRule7_19.doc
Basically:
From PART 1-DEFINITIONS AND ABBREVIATIONS
Light-sport aircraft means an aircraft, other than a helicopter or
powered-lift that, since its original certification, has continued to meet
the following:
(1) A maximum takeoff weight of not more than--
(i) 660 pounds (300 kilograms) for lighter-than-air aircraft;
(ii) 1,320 pounds (600 kilograms) for aircraft not intended for operation on
water; or
(iii) 1,430 pounds (650 kilograms) for an aircraft intended for operation on
water.
(2) A maximum airspeed in level flight with maximum continuous power (VH) of
not more than 120 knots CAS under standard atmospheric conditions at sea
level.
(3) A maximum never-exceed speed (VNE) of not more than 120 knots CAS for a
glider.
(4) A maximum stalling speed or minimum steady flight speed without the use
of lift-enhancing devices (VS1) of not more than 45 knots CAS at the
aircraft's maximum certificated takeoff weight and most critical center of
gravity.
(5) A maximum seating capacity of no more than two persons, including the
pilot.
(6) A single, reciprocating engine, if powered.
(7) A fixed or ground-adjustable propeller if a powered aircraft other than
a powered glider.
(8) A fixed or autofeathering propeller system if a powered glider.
(9) A fixed-pitch, semi-rigid, teetering, two-blade rotor system, if a
gyroplane.
(10) A nonpressurized cabin, if equipped with a cabin.
(11) Fixed landing gear, except for an aircraft intended for operation on
water or a glider.
(12) Fixed or repositionable landing gear, or a hull, for an aircraft
intended for operation on water.
(13) Fixed or retractable landing gear for a glider.
And from 61.23 Medical certificates: Requirement and duration
[A medical is not required for gliders and ballons - RWI]
(c) Operations requiring either a medical certificate or U.S. driver's
license. (1) A person must hold and possess either a valid medical
certificate issued under part 67 of this chapter or a current and valid U.S.
driver's license when exercising the privileges of-
(i) A student pilot certificate while seeking sport pilot privileges in a
light-sport aircraft other than a glider or balloon;
(ii) A sport pilot certificate in a light-sport aircraft other than a glider
or balloon; or
(iii) A flight instructor certificate with a sport pilot rating while acting
as pilot in command or serving as a required flight crewmember of a
light-sport aircraft other than a glider or balloon.
(2) A person using a current and valid U.S. driver's license to meet the
requirements of this paragraph must--
(i) Comply with each restriction and limitation imposed by that person's
U.S. driver's license and any judicial or administrative order applying to
the operation of a motor vehicle;
(ii) Have been found eligible for the issuance of at least a third-class
airman medical certificate at the time of his or her most recent application
(if the person has applied for a medical certificate);
(iii) Not have had his or her most recently issued medical certificate (if
the person has held a medical certificate) suspended or revoked or most
recent Authorization for a Special Issuance of a Medical Certificate
withdrawn; and
(iv) Not know or have reason to know of any medical condition that would
make that person unable to operate a light-sport aircraft in a safe manner.
Rich
Old July 20th 04, 07:34 PM
cj
"Richard Isakson" wrote in message
application
Rich
This is the part that affects me. I applied for a third-class about four
years ago while taking lessons. However, the FAA asked for information from
my cardiologist about my blood pressure medicine. He ignored their specific
points and wrote a rambling memo that I was fit to fly. Because I had
stopped taking lessons (we bought a house and the money got spent on silly
stuff like mortgage), I never submitted his memo. The FAA never denied me
and until a year or so ago the FAA web site showed I had submitted an
application with not additional action.
However, because I once submitted an application -the rule says "...most
recent application" - I have to get a third-class medical. Then, I can let
it lapse and start using a driver's license to fly as a sport pilot. But,
if I had bought the house a few months earlier, never applied for a
third-class medical, I could declare myself fit to fly as a sport pilot as
long as I have a driver's license.
I think someone else called this "government goo".
-cj
Roger Long
So you're OK to be in the other lane passing within six feet of me at a
closing rate of 120 miles an hour and repeating the event a hundred or so
times an hour but not to be off buzzing around over a field several thousand
feet away in a much lighter and more crushable machine.
Yup, makes about as much sense as anything else the government does.
Roger Long
"cj" wrote in message
application
Rich
from
specific
let
-cj
Old July 20th 04, 08:32 PM
Dr. Bob Lade
I have heard conflicting reports as to whether the Ercoupe 416C would be
eligible as a LSA or not. Anyone know for sure? I see it listed as having a
t/o weight of 1260 lb. under the 1320 lb. in the newly published FAA
rules...
Dr. Bob Lade
Lade's Internet Service, Inc.
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
239-772-1663 v/f 239-560-1631 m
"Gilan" wrote in message
nk.net...
Old July 20th 04, 09:09 PM
Dr. Bob Lade
I meant the Ercoupe 415C, of course g.
Dr. Bob Lade
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
"Dr. Bob Lade" wrote in message
news
a
rules...
Dr. Bob Lade
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
nk.net...
Old July 20th 04, 11:01 PM
ET
Dr. Bob Lade
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
news
be eligible as a LSA or not. Anyone know for sure? I see it listed as
having
a
rules...
Dr. Bob Lade
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
Looks to me like your in....
Stall speed (clean) 48mph
LSA stall speed 45knots = approx 48.6 mph
ET
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Old July 20th 04, 11:33 PM
Rich S.
"ET" wrote in message
That would be closer to 51.7864910 mph.
Rich "The Devil is in the details" S.
Old July 21st 04, 11:27 AM
Cub Driver
The FAA is saying that you will need a "special issuance" and that
they will "work with" you on this. I don't know if that's good news or
bad, but it sounds as if they are willing to be more lenient this time
around.
There are several views on this posted at www.aero-news.net
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
Expedition sailboat charters www.expeditionsail.com
Old July 21st 04, 11:33 AM
Cub Driver
It's not too difficult to get a medical if you are taking blood pressure
medication. You mainly have to show that your blood pressure is under
control and your system is tolerating the drug well. The extra tests do
drive the cost up though,
Most of the FAA's prohibited BP medicines bring a smile to the face of
the family doctor, who says that nobody ever prescribes them any more.
I take Diovan and the one with the long name, HCTZ I think it is
(cheap! wow! $1.85 for 90 days!). I used to take Cardura along with
the Diovan. I required no tests, only a statement from my doctor with
a list of periodic BP readings (which I took at home and gave to him)
and a list of my prescriptions. The simpler this stuff is, the better.
I had a lengthy delay before the certificate came through, four months
I think. But my following two flight physicals were completed in the
flight surgeon's office.
Actually, the FAA now seems more interested in my exercise-induced
asthma than in my blood pressure. At next physical I am to submit a
"narrative" from my doctor on this subject.
The Warbird's Forum
Sport pilot - International? Rich S. Home Built 5 August 24th 04 08:55 AM
Sport Pilot cuts off special issuance at the knees Juan~--~Jimenez Home Built 40 August 10th 04 01:19 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
