On Sat, 21 Aug 2004 19:56:55 GMT, Orval Fairbairn
wrote: In article , Mark Smith wrote: Kathryn & Stuart Fields wrote: Why not the "Belt and Suspenders" approach? Tie both ends down. Stu Fields (Helicopters have problem with just tying down the rear blade) "Icebound" if you expect really bad winds, support the tail, AND tie it down, And, ductape some makeshift spoilers to the wings: some 8 ft pieces of 2x2, taped ahead of the spar line, secured with about 8, 2 ft strips of 2" ductape (top surface) will secure it, provided that there is no dirt on the wing. A couple years ago when we had high winds in Anchorage and a bunch of airplanes were lost, the weak point on tube and fabric types seemed to be the rear wing strut. In addition to extra tiedowns, lots of guys would lash and/or duct tape a 2x4 to the strut to brace it and prevent buckling. ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply |
Kathryn & Stuart Fields wrote: Why not the "Belt and Suspenders" approach? Tie both ends down. Yeah, you want to make a stationary target for all of the other planes on the ramp that break loose. -- Ben Jackson http://www.ben.com/ |
![]() Icebound wrote: Thus I wonder if leaving the tail loose, and tieing down at the nose gear would make more sense. I don't see this as putting more pressure on the wing-tiedowns because I feel that a tied-down tail would have given way anyway, long before the wings reach any sort of critical point. Leaving the tail loose will allow a wind from the rear to push the plane over. The wind will be able to exercise a tremendous amount of leverage on the horizontal stabilizer. I normally keep 1/2" nylon tiedowns on my taildragger. When we get hurricane warnings, I add a set of 3/8" nylon ropes from the tiedown rings to the wing struts. for the last serious storm, I tied lift spoilers to the tops of the wings. I've been here over 20 years. So far, our storms haven't been as serious as the worst of the Florida storms. We rarely see winds higher than 100 mph. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
"Icebound" wrote in message ...
Does anybody know of any wind-tunnel tests for analysis of tie-down behaviour? I tried a google search without much success. Having seen the Charley pictures from Orlando Executive and Punta Gorda, I'm wondering if we are doing the right thing. I can tell you from recent experience that the only way to safe guard your plane in winds exceeding 50knots, is to move it to some place safe. There are pictures on three websites that will show you planes that were tied down and still damaged, some still tied down and damaged in place. http://www.flyinggators.com/news/hurricane/exec.htm http://www.floridascubadiver.com/hurricane_charley.htm http://www.avweb.com/news/features/187931-1.html David (KORL) |
An old bush pilot told me they used really long wing tie downs to a
single point and left the tail untied in high winds in Alaska. This allowed the aircraft to lift off and weathervane in high winds. The aircraft were staked out far enough apart that they wouldn't collide with each other. I'd be interested to know if anyone's actually witnessed that method. A Cozy owner told me that by retracting the nosegear of a Cozy or Long EZ, it could withstand 60 knot winds without being tied down. I don't know how much truth there is to that one, either, but there obviously aren't very many airplanes that CAN'T withstand 100mph+ winds. Icebound wrote: Does anybody know of any wind-tunnel tests for analysis of tie-down behaviour? I tried a google search without much success. Having seen the Charley pictures from Orlando Executive and Punta Gorda, I'm wondering if we are doing the right thing. The standard for tricycle gear GA planes seems to be wings and tail. Having been to my own airport, I can see that most of the tail ropes are usually the rattiest you can find. Besides, ev -- John Kimmel I think it will be quiet around here now. So long. |
On Sun, 22 Aug 2004 04:35:24 GMT, guynoir
wrote: An old bush pilot told me they used really long wing tie downs to a single point and left the tail untied in high winds in Alaska. This allowed the aircraft to lift off and weathervane in high winds. The aircraft were staked out far enough apart that they wouldn't collide with each other. I'd be interested to know if anyone's actually witnessed that method. Did the old bush pilot start out by saying "now this ain't no bull****"? ================================================== == Del Rawlins-- Unofficial Bearhawk FAQ website: http://www.rawlinsbrothers.org/bhfaq/ Remove _kills_spammers_ to reply |
The hurricane hitch should be able to withstand winds of 150 knots, given
rope of adequate strength. This is the only knot that should be used for tieing down aircraft, yet my personal observation is that fewer than one pilot in 50 knows how to tie it. The knot is described in E.F. Potts' book on bush piloting. Chains are worse than inadequate as tiedowns. They cannot be attached without some slack remaining, and sudden stretching of the chain will cause it break when it snaps taught. Loose and broken chains are also dangerous in and of themselves. A rope can be made tight, so that all stretching is continous and there is no sudden stop. Aircraft owners should carry their own lines and ensure that they are in good condition. They should also make sure that their tiedown rings are in good condition and, if strong winds are expected, should consider reinforcing the tiedown by giving the line a couple turns around the strut as well as running it through the tiedown ring. Even tieing an airplane down is not a guarantee against damage. Winds may still generate enough lift that the airplane could be damaged anyway. There is one picture of a severely damaged Bonanza that pulled the concrete tiedown blocks completely out of the ramp, collapsing the nose, wrinkling the wings, and probably damaging the wing spars in the process! Tied down airplanes can still be damaged by flying debris (such as improperly tied down airplanes) as well as by severe hail and other things caused by the weather. Cessna recommends tieing aircraft down at both nose and tail, though this is rarely done and few tiedowns have provision for doing this. A gust striking an airplane that is tied only at the tail and wings can still send the tail slamming down hard on the concrete, breaking it off. Gusty winds can make the airplane bounce on its nose gear, too, possibly damaging the nose gear, firewall, engine mount, propeller and engine. The airplane can also be set on its tail by heavy snow or ice. |
"C J Campbell" wrote in message ...
The hurricane hitch should be able to withstand winds of 150 knots, given rope of adequate strength. This is the only knot that should be used for tieing down aircraft, yet my personal observation is that fewer than one pilot in 50 knows how to tie it. The knot is described in E.F. Potts' book on bush piloting. It's actually FE Potts, and everything you ever need to know about tie downs can be found he http://www.fepco.com/BF.images.gentle.breeze.html |
You can get much more tension from a Versatackle:
http://www.geocities.com/roo_two/Versatackle.html Once you get the loops placed correctly for your setup, you can leave the loops in place unless you need to use the rope for something else. |
Orlando Executive airport after Charley hit | Gilan | Owning | 28 | August 29th 04 05:22 AM |
Orlando Executive airport after Charley hit | Gilan | Piloting | 28 | August 29th 04 05:22 AM |
Yeah! I'm back online..No thanks to Charley. | CFLav8r | Piloting | 10 | August 24th 04 04:14 AM |
Is Charley telling us anything about A/C tie-down? | Icebound | Home Built | 22 | August 23rd 04 07:38 PM |
GA Airport center for Charley relief | Bob Chilcoat | Piloting | 4 | August 19th 04 04:04 PM |
