Russian jets crash within minutes of each other
Old August 27th 04, 03:02 AM
Kyle Boatright
"David CL Francis" wrote in message
On Wed, 25 Aug 2004 at 20:51:11 in message
, Kyle Boatright
What fuel problem would cause a jet to go down *right now*? Airliners
glide
decently and a crew with even a little training would get off a mayday
call
and try and work the situation in the time it would take a flamed-out
airliner to go down. A back of the envelope figure is that an airliner
probably has a sink rate of 2500 fpm or less in glider mode... Remember
Gimli Glider? It glided for 10-15 minutes before landing, and a Soviet
airliner probably wouldn't do much worse...
More recently wasn't there an Airbus (I forget which type) that lost
fuel over the Atlantic and glided some 70 nm(?) to the Azores and had
enough height left for a circuit before landing? Modern airliners are
efficient partly because they have very good Lift/Drag ratios.
I agree that the sink rate is around 2000 ft/min or so but it is
Lift/drag that gives you the distance. I guess that airliners cruise
around 250 knots IAS and that that is near the optimum Lift/Drag ratio
point.
David CL Francis
David,
Agree with your L/D vs glide range comment. My point went to the idea that
an airliner's sink rate is low enough that even with a complete flame out
(unless the airplane was already at very low altitude), there should be
plenty of time to get off a Mayday call and possibly relate the basics of
the problem to a controller.
KB
Old August 28th 04, 11:52 PM
David CL Francis
On Thu, 26 Aug 2004 at 22:02:30 in message
, Kyle Boatright
In Macarthur Job's book where he describes the events when the BA 747
lost all 4 engines near Java he says that with all engines stopped at
37,000 feet the aircraft should take 23 minutes to sea level.
That certainly reinforces your point! It also suggests a 1600 ft/minute
descent rate. If the speed was 250k then, if I am right, it also implies
a glide L/D of around 15.
Airliners are _not_ bricks! :-)
David CL Francis
Old August 26th 04, 04:44 PM
G.R. Patterson III
"James M. Knox" wrote:
Fuel problem???
No. The BBC reported yesterday that an explosion was seen on one of the aircraft
before it went down and that the other plane sent indications of being hijacked (I
assume something like a transponder code) shortly before disappearing.
The report continued that any sort of mechanical problem would almost certainly have
allowed the flight crew time to radio a message.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
Old August 26th 04, 05:49 PM
Allen
"G.R. Patterson III" wrote in message
Fuel problem???
aircraft
hijacked (I
The reporter I just heard on the news here said someone hit the SOS button
before the plane dropped off radar.
Allen
Old August 26th 04, 07:25 PM
David Herman
"Allen" wrote in message
m...
Hmmm. Exactly which button would that be?
I guess all Russian airliners must have a big, red button in the middle of
the panel marked "SOS" (or maybe it's the little plastic gag "panic button"
that Sporty's sells?).
Sounds like a reliable report to me.
David Herman
N6170T 1965 Cessna 150E
Boeing Field (BFI), Seattle, WA
Visit the Pacific Northwest Flying Forum:
http://www.smartgroups.com/groups/pnwflying
Two more Navy jets crash, one from Virginia Beach Otis Willie Naval Aviation 0 March 30th 04 11:40 PM
best US jet vs Russian jets? ville terminale Military Aviation 86 March 12th 04 05:27 PM
India rejects new Russian jets semi OT Kevin Brooks Military Aviation 19 December 17th 03 09:02 AM
RUSSIAN WAR PLANES IN ASIA James Military Aviation 2 October 1st 03 11:25 PM
Report blames pilots in crash of two Navy jets Otis Willie Naval Aviation 0 September 26th 03 01:27 AM
