Reduce RPM to "coast" in long descent?
Old September 3rd 04, 05:42 AM
Roger Halstead
On 29 Aug 2004 04:14:44 GMT, (WIACapt) wrote:
(Robert M. Gary)
In my Mooney I'll often begin my
let down 40-50 miles out (although I'm flying a bit higher than you
mention here in this post). In the Mooney its fun because you can keep
I was lined up on the glide slope at Port Columbus. The instructor
told me to take the foggles off and look to my left. There off our
wind was a 737 and it was staying in position, that is until we hit
the outer marker and I lowered the gear. :-))
up with the biz jets as long as you don't level off.
-Robert
Those Mooneys must really be fast
Figure 200 MPH. That is 3.33 miles per minute. At a 500 fpm rate of
descent you need 3.33 miles for each 500 foot, so IF you want to
descend from 7000 to 3000 it will take 4000/500 = 8*3.33, or 26.64
miles. From 9000 to 3000 is 6000/500 = 12*3.33, or basically 40
miles. BUT you also have to slow down. I have to slow from 200 MPH to
120 MPH and that takes a good mile in level flight. A lot more while
coming down hill. OTOH leveling off AND a power reduction will get me
there in 2 miles, but 3 gives a comfortable margin.
The FAF for the VOR - A into 3BS is 5.5 NM out and figuring I need to
be down and slowed down comfortably before the FAF I'd figure a
minimum of 3 miles. So 5.5 + 3 + 40 would mean I'd have to start down
48.5 miles out. OTOH 180 is 3 miles per minute so from 9000 to 3000 =
12 * 3 = 36 miles to get down and 5.5 + 3 or 44.5 miles.
Figuring 120 MPH and 2 miles per minute would change that to 12 * 2 =
24 miles to get down and 3 + 5.5 or 32.5 miles including the
approach.
At 200 MPH I'd still have to start down soon enough to be at pattern
altitude and slowed to pattern entry speed to safely enter the
pattern. That would only let me nock off 3 or 4 miles compared to the
instrument approach.
The Mooney OTOH has to slow even more to get the gear down so although
he can go like a bat coming down hill it's going to take him longer to
get that slippery airplane slowed to gear down speed. So he is going
to need to start down even farther out than I do.
They aren't kidding when they say you have to learn to think much
farther ahead when flying a high performance retract.
www.rogerhalstead.com
Old August 27th 04, 08:28 PM
Newps
Stuart Grant wrote:
This will take about half an
hour. My economy cruise will be max 22.5" MP or WOT and 2200 RPM. Any
advantage to reducing the RPM to 2000 or lower during the long
descent? Does it save gas?
A 200 rpm reduction will save you 2 gallons per hour in the 470. So you
will save 1 gallon.
Is it better to reduce MP and leave RPM at
2200?
Every two inch reduction in MP also saves you 2 gallons per hour.
I know the prop acts like a brake a high RPM-fine pitch. Is low
RPM and coarse pitch-more like feathering when you are going downhill?
In my 182 I always fly balls to the wall on a cross country. WOT minus
a little to tickle the needle and 2450 RPM. When it comes time to
descend I do not touch power and just roll in a turn of trim, that gets
me 500 fpm down and an extra 15-20 knots. I will reduce MP as necessary
to stay at the top of the green, but you don't have to that living out
here in the west where 26" is all there is anyways.
Old August 28th 04, 12:33 AM
AJW
2200?
In my Mooney I like VFR decents at whatever speed I had been cruising. It's my
habit in cruise to keep the RPM low, almost always going a little 'oversquare'
(MP in inches a bit higher than RPM in hundreds). I don't like speeding up in
the decent, and consider the altitude energy in the bank, I spend it on haaving
the MP lower.
Old September 3rd 04, 07:36 PM
AJW
2200?
my
'oversquare'
in
haaving
the MP lower.
But your giving up all the speed you should have gotten back from the
climb. You fly slower in the climb but get it back when you start
down. Pulling power back just gives it all up
I admit to not running the numbers on that. I figured I chose an airspeed that
made sense, save a little fuel on the decent, and even if I come down from
11500 at 500 fpm it's what -- 21 minutes to pattern altitude. At 150 kts +
wind, that means I start down about 50 miles out. If I come down at an average
of say 165 ktsI'd be starting down maybe 8 miles sooner. Maybe it's as much
this as anything -- I mostly do XC under IFR, and like to keep whatever is the
filed airspeed.
Old September 3rd 04, 10:13 PM
Peter Duniho
"Robert M. Gary" wrote in message
om...
down. Pulling power back just gives it all up.
It's just a matter of what you want to get back. You are right, you are
sacrificing speed (energy banked during the climb), but you get in return
fuel efficiency (energy banked during the climb).
Which is, essentially, what AJW wrote in the first place.
You don't lose the energy. You just use it differently, depending on your
power setting. Thermodynamically speaking, the lower power setting also
produces the more efficient use of the energy, but of course flying isn't
always about what's most efficient.
Pete
Old September 3rd 04, 06:41 PM
Robert M. Gary
Newps wrote in message ...
minus
I pull the throttle back just enough to maintain the same MP as I come
down (adjusting every 2000 feet or so). If you forget to roll the
throttle back, you'll end up pulling 30" in the pattern.
-Robert
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
Simpy One of Many Stories of a Time Not So Long Ago Badwater Bill Home Built 40 March 16th 04 06:35 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
