The FAA report gives the position of his last radio contact as 2 miles east
of Manteca. This is right in the middle of the California Central Valley - flat farm land, about 50' MSL that stretches uninterrupted north to south for more than 350 miles. It is probably the longest emergency landing strip west of the Rockies. There is no shortage of real airports either. I would assume that either the spin was not recoverable, or the pilot simply followed the instructions to use the BSR in the event of a spin. The real question is how you could get into a spin from turbulence in cruise flight in the first place. However, there were some mean thunderstorms in the area at the time (2" of rain fell in Sacramento earlier in the day and the weather was heading SW towards the accident area). Basically it was a mean cold front that swept through the area about the time of the accident- and it certainly wasn't forecast to be as wild as it turned out (wild by CA standards that is). I would think he more than likely got caught up in some of that convective activity. |
Peter R. wrote:
Glad the chute worked, but what would cause an airplane to stall at 16,000 feet, then encounter turbulence that would send it into a spin at 15,000 feet? My take on the article, based on past news media aviation ignorance, is that the engine most likely quit at 16,000. Ah! And the engine out caused the plane to fall out of the sky... Stefan |
Anyone know what the service ceiling of the aircraft is?
![]() "Cockpit Colin" wrote in message ... Anyone know what the service ceiling of the aircraft is? A spec sheet on Avweb in 2002 says 17K, so he was pushing the limit. The Cirrus site seems to hide such info very well. |
There's a William K. Graham listed as a certified training instructor
on the Cirrus Design web site. He's from San Diego. Anyone want to bet that is the same guy in the article? If so, Mr. Graham is a CFI and is instrument rated, which makes the description of the incident all that more puzzling. |
("Ace Pilot" wrote)
There's a William K. Graham listed as a certified training instructor on the Cirrus Design web site. He's from San Diego. Anyone want to bet that is the same guy in the article? If so, Mr. Graham is a CFI and is instrument rated, which makes the description of the incident all that more puzzling. From the Duluth News Tribune story - reporting on the Sept 10th Park Falls, Wisconsin crash. http://www.duluthsuperior.com/mld/du...or/9723097.htm Byron "Buzz" Oyster, a flight instructor from Duluth who was also in the plane, sustained critical injuries and remains hospitalized at St. Joseph Hospital in Marshfield, Wis. His condition was listed as "fair" Tuesday. Flight instructor from Duluth? Wonder if this fellow is connected with the factory? Montblack |
![]() "Ace Pilot" wrote in message om... There's a William K. Graham listed as a certified training instructor on the Cirrus Design web site. He's from San Diego. Anyone want to bet that is the same guy in the article? If so, Mr. Graham is a CFI and is instrument rated, which makes the description of the incident all that more puzzling. Not really. He did exactly what I would expect a flight instructor to do. When he got into an emergency, he followed the manual, not the theories of a bunch of armchair pilots on Usenet who think they know better than the aircraft designer on what to do when a Cirrus spins. The only real question is why he was flying there in the first place, which has nothing to do with whether he was flying a Cirrus -- a point that is lost on some around here. |
![]() "Michael 182" wrote in message news ![]() Glad the chute worked, but what would cause an airplane to stall at 16,000 feet, then encounter turbulence that would send it into a spin at 15,000 feet? At that height it would seem a stall should be pretty simple to recover from, although, once again, I can't imagine what would make the plane stall in the first place during cruise. The airplane was near the service ceiling and may already have been at a high angle of attack. Flying slowly because of the turbulence may have increased the angle of attack still further. If the turbulence is severe the airplane could exceed the critical angle of attack. Picture the airplane in a straight and level attitude but descending straight down and you get the idea -- very high angle of attack. This would especially be true if the airplane was in a rapid descent because of the turbulence and the pilot was trying to maintain altitude or even a straight and level attitude. If the airplane is uncoordinated then the stall could turn into a spin. Picture again the airplane moving straight down in a level attitude, but now one wing is moving backward relative to the other. That wing will have a higher angle of attack than the other; it will stall without warning and the airplane will immediately begin to roll into a spin, possibly even inverted. Of course, the turbulence would have to be pretty bad to cause this, but in the Central Valley in the vicinity of thunderstorms, I can believe it. The stall resistant Cirrus might hold out longer than other airplanes, but it is not invulnerable. Cirrus deliberately limited rudder and elevator travel to prevent stalls and spins. This has the effect, however, of making it more difficult or even impossible to recover once a spin develops. There is not enough rudder authority to recover. The Cirrus has never demonstrated a spin recovery, though it has been tried. The only way the airplane could receive certification was to require deployment of the parachute in the event of a spin. There seems to be a pattern of Cirrus aircraft entering stalls and spins in turbulence at high altitudes. It may be a training problem -- pilots taking Cirrus airplanes into conditions that they would not try in other airplanes. For now, I think that if you take a Cirrus into turbulence at high altitude there is a certain risk that the airplane will be lost. That risk may be more or less than other types, but it is there. |
C J Campbell wrote:
impossible to recover once a spin develops. There is not enough rudder authority to recover. The Cirrus has never demonstrated a spin recovery, though it has been tried. The only way the airplane could receive certification was to require deployment of the parachute in the event of a spin. I didn't know this. Personally, I don't like the idea at all wouldn't buy a plane that can't be recovered by the standard procedure. But then, I'm maybe just old fashioned. Stefan |
Stefan,
I didn't know this. Because it is not true. Cirrus chose to comply with the spin certification by installing the parachute. This was NOT done after spin recovery in the traditional way had been tried unsuccesfully, as CJ implies. It was done in order to save money by not doing traditional spin recovery testing at all. Thus, the official spin recovery testing requried for certification wasn't done. This says nothing about whether the aircraft is recoverable from a spin by traditional methods. It was NOT tried, at least not to the extent necessary for certification. Instead, the parachute was installed and accepted by the FAA (and EASA) as a certifiable means of dealing with spins. -- Thomas Borchert (EDDH) |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
Cirrus BRS deployment | Dan Luke | Piloting | 37 | April 14th 04 02:28 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
