"C J Campbell" wrote in message ...
-snip- That wing will have a higher angle of attack than the other; it will stall without warning and the airplane will immediately begin to roll into a spin, possibly even inverted. -snip- Remember, it's not really established in the spin until you've made at least a couple of turns (it's all about inertia). A simple wing drop and roll/yaw excursion is just a spin entry or incipient spin. The question about the Cirrus' recovery characteristics is still open IMHO. If you manage to get the airplane stalled and drop a wing in a big way, will it still just fly out of the stall if you apply aggressive forward stick? How about after a half turn? What about a full turn? While it's possible that the airplane will not recover from a developed spin, that does not mean to me that one couldn't recover from a stall-wing-drop-roll scenario with just an authoritative push and roll to upright. (Ever crossed over from an upright to inverted spin by using a 'normal' entry and then driving the nose through as the wings roll knife-edge? If you're not positive on the controls, it can just wallow along and fall out into a mushy dive.) -Dave Russell 8KCAB The old fashioned way works fine for me.... strap the 'chute to your ass instead of the airplane. It makes the "pull or not to pull" question easy (if you are in free-fall, pull). |
![]() "Dave Russell" wrote in message om... "C J Campbell" wrote in message ... -snip- That wing will have a higher angle of attack than the other; it will stall without warning and the airplane will immediately begin to roll into a spin, possibly even inverted. -snip- Remember, it's not really established in the spin until you've made at least a couple of turns (it's all about inertia). A simple wing drop and roll/yaw excursion is just a spin entry or incipient spin. The question about the Cirrus' recovery characteristics is still open IMHO. If you manage to get the airplane stalled and drop a wing in a big way, will it still just fly out of the stall if you apply aggressive forward stick? How about after a half turn? What about a full turn? While it's possible that the airplane will not recover from a developed spin, that does not mean to me that one couldn't recover from a stall-wing-drop-roll scenario with just an authoritative push and roll to upright. (Ever crossed over from an upright to inverted spin by using a 'normal' entry and then driving the nose through as the wings roll knife-edge? If you're not positive on the controls, it can just wallow along and fall out into a mushy dive.) Right. It is not necessarily true that a stall will result in a spin. The Cirrus requires considerable force to enter a spin. It can be done, as was demonstrated, but it is not easy. I don't think it is far wrong to say that some other planes would break up in flight if subjected to the same types of forces. In this case the buffeting was so severe that the pilot probably had little to no control over the airplane. Stalls are usually benign and the ailerons remain effective throughout a normal stall. Cirrus training now emphasizes using CAPS the moment that the airplane enters a spiral or spin. The maneuver limitations say this: Maneuver Limits Aerobatic maneuvers, including spins, are prohibited. .. Note . Because the SR22 has not been certified for spin recovery, the Cirrus Airframe Parachute System (CAPS) must be deployed if the airplane departs controlled flight. Refer to Section 3 - Emergency Procedures, Inadvertent Spiral/Spin Entry. This airplane is certified in the normal category and is not designed for aerobatic operations. Only those operations incidental to normal flight are approved. These operations include normal stalls, chandelles, lazy eights, and turns in which the angle of bank is limited to 60°. Cirrus does have procedures for practicing and recovering from stalls: Stalls SR22 stall characteristics are conventional. Power-off stalls may be accompanied by a slight nose bobbing if full aft stick is held. Power-on stalls are marked by a high sink rate at full aft stick. Power-off stall speeds at maximum weight for both forward and aft C.G. positions are presented in Section 5 - Performance Data. When practicing stalls at altitude, as the airspeed is slowly reduced, you will notice a slight airframe buffet and hear the stall speed warning horn sound between 5 and 10 knots before the stall. Normally, the stall is marked by a gentle nose drop and the wings can easily be held level or in the bank with coordinated use of the ailerons and rudder. Upon stall warning in flight, recovery is accomplished by immediately by reducing back pressure to maintain safe airspeed, adding power if necessary and rolling wings level with coordinated use of the controls. .. WARNING . Extreme care must be taken to avoid uncoordinated, accelerated or abused control inputs when close to the stall, especially when close to the ground. |
Right. It is not necessarily true that a stall will result in a spin. The Cirrus requires considerable force to enter a spin. It can be done, as was demonstrated, but it is not easy. I don't think it is far wrong to say that some other planes would break up in flight if subjected to the same types of forces. What?!?! Last time I checked, the Cirrus was only certified to the same limits as everybody else's airplanes. Why should it hang together better than everyone else's? (And if you think they designed in an extra 3g's and didn't tell anybody about it, I've got a bridge to sell you.) And why do the spins require "considerable force"? Force on what? The wing is stalled (or very nearly so), meaning not too much stress on them, at least. I bet one can pitch up to, say 30 degrees above the horizon with a bunch of nose-up trim, then let go of everything and she'll stall right out from under you with no pilot input at all! Once you've got that down, try giving her a big boot full of left rudder and hammer in the throttle just as she breaks. I'd bet she'll do a very pretty spin entry from there.... 8- (And, btw, there's really very little stress on the airframe when you do this. Otoh, it might be stressful for the pilot.) |
Cirrus Deploys Chute Safely | m alexander | Home Built | 40 | September 28th 04 12:09 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Another Cirrus BRS deployment: | Dan Luke | Piloting | 111 | April 19th 04 04:34 AM |
Cirrus BRS deployment | Dan Luke | Piloting | 37 | April 14th 04 02:28 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
