![]() "RobertR237" wrote in message Wow, in the total scheme of things, how many planes are hit by lightning? If you are that leary of flying and lightning, I would suggest you stay on the ground. Turning a propeller near the freezing level is a sure way to get struck. I took 3 hits in one year (that I know of). For two of them, I wasn't even in the clouds. I was deviating around CBs. One hit knocked both generators off-line. They re-set fine, so it only cost $5000 for a gearbox teardown and inspection. One hit to another crew put a dime sized hole in one prop blade. They weren't in the clouds and didn't know they had been struck until the post-flight walk-around. That cost $27k because you can't replace just one blade. The aerodynamics of some of the fast glass planes give me a raging hard-on. However, I can't bring myself to build one because of the lightning issue. Talking to the kit manufacturers at Sun-n-Fun hasn't brought satisfaction to my angst (basically, the salesmen don't know squat about the issue). I wonder how the helicopter manufacturers protect their composite blades from being damaged by lightning? (Painful image developing) D. There are a whole lot of glass planes out there flying every day, both production and experimental. The reported strikes have been very few. I suspect that the odds of getting killed driving to the airport are far greater than being killed because of a lightning strike in a glass plane. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
"RobertR237" wrote in message There are a whole lot of glass planes out
there flying every day, both production and experimental. The reported strikes have been very few. I suspect that the odds of getting killed driving to the airport are far greater than being killed because of a lightning strike in a glass plane. True- but I haven't been able to find out any meaningful data about how the electrical charges are kept from causing structural damage. None of the salesmen I queried has a clue. Some of the certified models have a full instrument panel but aren't certified for IFR flight, ostensibly because of this issue. Until I do find some meaningful data, I have to go on the theory that I will again be struck by lightning. I don't want to end up like those glider pilots in the UK, especially since they had chutes and I don't). D. |
![]() At least, I KNOW every damned rivet and I KNEW that it wouldn't fall apart at altitude. Do you have the same confidence that the composite "glue" will do the same?? How cold is it at altitude? What happens when you get a lightening strike on that fuselage? With the resistance of the composite fuselage you'll get a tremendous voltage drop across it when the lightening strikes. And Power equals voltage drop times current. How do you think you'll like dissipating a megawatthour of energy in that small area?? I'll stick to metal airplanes... Lightening hits them and simply flows through with little or no voltage drop... John I was in a good mood until I read this. Now I'm suicidal! All bull**** aside John, you bring up some great concerns as usual. I have no idea how it will behave under those conditions. I might just "POP" into another dimension or something. I may hurdle to my death. All I can say is "What the ****...over!" I've probably lived too long already...almost like a cat with 9 lives...I've been sooo close, sooo many times! I want to tell you all something. If I buy the farm in a Lancair Legacy that I built, then I want all of you to rejoice at my life and know that I lived it to the fullest as I came to a screaming halt into the Earth at Mach 0.7 due to a structural failure. I want you to post this post if I punch in doing what I love to do...going fast, taking chances, flying and living life. I don't have a death wish. But, on the other hand, I have no intention of hiding my head under my bed when there are 300 mph airplanes to be built and flown...and finally after 50 years of being a poor Black Jewish Christian Hebrew ******* child from Boulder City, I personally have the means to produce such a machine for my own personal (and Boom Boom's) use. Best Wishes to all, BWB P.S. I will make sure that I put compete EFIS in it so I can roll it continuously without tumbling any gyroscopes. I just pulled a gyro today that I trashed from looping the machine I fly. No more! Not with the Legacy. It will be all EFIS. |
![]() Or, at least, remember that when you see lightening bolts, it's time to head home to Mama... A good idea no matter what kind of small plane you are flying! Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
John Ammeter wrote in message . ..
I read somewhere, and, no, I don't remember where... that you can add a conductive "something" to the aircraft so it can conduct current without blowing up. You might think about that... I'd expect carbon fiber composites to be electrically conductive. -- FF |
On Wed, 07 Jul 2004 00:07:41 +0000, Badwater Bill wrote:
On 6 Jul 2004 12:22:48 -0700, (bryan chaisone) wrote: As I have apologized to you in my response to your private email to me, I apologize to you here publicly. What I said was said in the heat of passion, I humbly apologize. Bryan "The Monk" Chaisone Don't you love it Bryan! I mean the HEAT of PASSION! Hell most of the old ****s here couldn't get their heart rate up of a naked woman walked by them. At least you are alive my man! And to top it all off, he had the guts to admit he was getting passionate about you, BWB. Not many guys would dare to admit that. At least not here where many folks know what you look like ![]() -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
![]() You just might get yours of the ground before my trike. I'm such a procrastinator. Bryan "The Monk" Chaisone Well get off your butt and get to work. Of course you will have to neglect your wife, your two daughter, you job and your drinking (if you drink). This, plus your excessive expenditures for tools and a shop will drive you in to Bankruptcy and you will become an outcast by all of your relatives. You, will however, have lots of friends. Once you have a shop and tools, you'll have no peace of mind, no free time, no moments to be a MONK. You will see, grasshopper, how it goes. Just forget it up front and buy a Cessna so you don't end up leading a tortured life like the rest of us who really do build airplanes. It's not worth it Bryan. Save your soul before it's too late. See my pictures of the new lifting body I installed yesterday in my shop on the Alt.binaries files somewhere when I post it. See the new thread below. Then you'll see a truly tortured individual. BWB |
