My first in-flight mechanical failure
Old September 27th 04, 02:18 PM
Peter R.
A Lieberman wrote:
snip
My rational for this would be why change a configuration for what appeared
to be a good running engine especially when you were able to cool the
engine temperature with mixture?
A valid point. I had typed this wordy response, but looking back at the
incident, it was much more simple: Given the severe clear, nearby
airports, and high altitude, I believed I had many options in the event
of a complete engine failure and didn't see the risk in testing the
mags.
One only need to recall the Alaska Air accident off the coast of
California to understand that too much troubleshooting can sometimes be
fatal.
I am curious, had it been hard IFR, would you have check the mags???
Hmmmm... I would be *much* more conservative in hard IFR. In fact, I
most likely would have declared an emergency. The key point to
understand in my actual scenario is that I had many options. In hard
IFR, I would not have had but a few.
Peter
Old September 27th 04, 02:26 PM
Peter R.
Ron Rosenfeld wrote:
Although you were not in a DISTRESS situation, as defined by the AIM, you
were clearly in an URGENCY situation. And BOTH are reasons for declaring
an emergency.
Perhaps. In my case, I received exactly what I needed to end the
flight: Direct to the airport and remain high with pilot discretion to
descend when I felt it was safe to do so.
Had ATC deviated from my plan or (as I replied to Alan), had it been
hard IFR, I would have declared an emergency.
Peter
Old September 27th 04, 02:28 PM
Peter R.
Sorry, Allen not Alan.
Peter
Old September 27th 04, 02:39 PM
Peter R.
I wrote:
snip
OK, there's the problem, a dead mag.
I just received a call from my trusted mechanic early this morning.
He discovered that a capacitor failed in-flight, which in turn grounded
the mag.
This is a bit beyond my limited knowledge of aircraft mechanics and I
cannot correctly explain what a capacitor does, but the good news is
that it is much cheaper to replace a capacitor than a mag.
Peter
Old September 27th 04, 08:54 PM
Marco Leon
I'm with you on that one Peter. I didn't get the impression that you were
hesitant to declare an emergency for any other reason than you didn't really
think it was an emgergency. You received the same results (i.e. service from
ATC) and that's what counts.
Thanks for the post. I hope I'm able to act the same way if I ever encounter
a similar situation.
Regards,
Marco
"Peter R." wrote in message
Peter
Old September 27th 04, 10:07 PM
JohnMcGrew
In article , Peter R.
writes:
Not knowing what to
expect, I was pleasantly surprised to discover that the engine continued
to deliver with no roughness.
Landing was uneventful...
Good show. That's why they give you two of those.
Years ago, had an emergency in a SuperCub when a hydraulic valve lifter
assembly went fubar at 6000 agl. Performance was slowly deteriorating, and
streaks of oil started appearing on the windscreen. We declared an emergency
and arrived over FUL with over 3000 feet to spare. The clowns in the tower
wanted to vector us off towards Disneyland to decend so that they wouldn't have
to mess up the traffic in the pattern. Still not knowing the exact cause of
the problem and being concerned that the engine might quit at any moment, we
didn't think that flying away from a made airport was a good idea, and in no
uncertain terms declined the instruction. The traffic was cleared and after a
few tight circles we landed with no problem. We cleared the runway and shut
down.
Later we found out that the tower guys had a bet going on wether or not we had
run low on fuel. After landing, they had expected to see us sneak over to the
fuel pit. They didn't expect to see us imediately shut down off the taxiway.
When one of the ground workers came over and saw oil dripping out of the
engine, their contest was resolved.
John
Old September 27th 04, 10:34 PM
Michael
the mag.
In case you ca
Most mag installations in modern (read - designed for electrical
systems and radios) aircraft have a capacitor between P-lead and
ground. This absorbs some of the electrical noise, and generally
reduces static on the radios.
These capacitors fail with depressing regularity, but they usually
fail 'open' - that is, they stop doing their job and radio noise
increases, but the mag keeps working. This is the first time I've
heard of one failing 'shorted' - but if one does fail shorted, you
ground the P-lead and it's as if you turned the mag off.
Glad that worked out for you - those things ARE cheap - should be
about $30 for the part and 30 minutes to change it.
Michael
Old September 28th 04, 12:14 AM
Peter R.
Michael wrote:
In case you ca
Of course I care. Hence the secretly placed bait, which you
thankfully took!
Very interesting. Over the last three months I have been having mag
noise problems (pop-pop-pop on frequency) whenever I used the Garmin
G430 com radio and full power, almost exclusively when tuned to a higher
frequency (130.00 or above). This interference did not occur with the
older B/K comm radio I use as my second radio, so I would end up using
the B/K radio during cruise.
When I asked a trusted avionics shop about this, they explained that the
mag itself was causing the interference and that the Garmin circuitry
was more sensitive to the interference than the older B/K radio. Based
on your explanation, I wonder now if it was really this capacitor
showing signs of imminent failure?
Good to know.
That is almost word-for-word how my mechanic explained the mag failure.
Thank you for your explanation.
Peter
Old September 28th 04, 12:16 AM
Peter R.
run low on fuel.
Nice to see someone casually betting on what could be a life or death
situation. Unlike a coach betting on his own team, though, at least the
controller gave you what you needed to have a successful outcome,
regardless of the side they chose in the bet.
Peter
Old September 28th 04, 12:57 AM
Andrew Gideon
Which would yield an unexpectedly "hot" prop with the switch in the "off"
position, yes?
- Andrew
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 28th 04 12:49 AM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 08:13 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 05:24 AM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
