![]() Dave wrote: Sorry Sylvia, My bad, I apologise, it was not my intent... I quoted the article pattern incorrectly. The actual author of the words was "nobody" (as near as I can determine). My server is missing a couple of posts in this thread, but I do not offer that as an excuse.. Sorry... (Dave hangs head and is shuffling feet) No worries. I've done it myself too, to my shame. Sylvia. |
![]() "Dave" wrote in message ... Sorry Sylvia, My bad, I apologise, it was not my intent... I quoted the article pattern incorrectly. The actual author of the words was "nobody" (as near as I can determine). My server is missing a couple of posts in this thread, but I do not offer that as an excuse.. Sorry... (Dave hangs head and is shuffling feet) Please reply so I will know you have seen this.... Dave On Thu, 28 Oct 2004 09:57:21 +1000, Sylvia Else wrote: Dave, please take a bit more care not to make it look as if I said something that someone else said. Following the normally accepted practice of bottom posting will limit the chances of such confusion. Ralph Nesbitt Professional FD/CFR/ARFF Type |
Dave wrote:
Coming out of a very low (legal) ceiling, the rny was not directly under the a/c, and the crew tried to correct laterally and doing so, the decent rate increased. They started the go around to late, the AC slammed down on the rny hard, the nose gear ripping the control functions as it rammed vertically up through the floor above. The TSB report clearly stated that the pilots initiated a go around WITHOUT LANDING, with airspeed that would have required landing before speed was high enough to climb again. Upon starting to climb again, the skidoo did regain some altitude before stalling, after which it fell to the ground where its recessive skidoo genes became dominant again. One problem is that the flight director had not been programmed to handle such a situation, neither had Bombardier foreseen/simulated situations such as those. While the FO (PIC) was trying to climb according to normal climb rates provided by the flight director, the captain did not realise that the newbie co-pilot wasn't aware of the very low airspeed. The throttles were stuck at high power, directional control was lost, and everybody was along for the ride into the trees WAY off to the right of rny 15 way past the intersection. One engine was STILL producing substantial power as the equipment arrived. The A/C was ON THE SURFACE, engines pushing it along for the entire trip, impact point to the pucker brush. (the damage from the nose gear severed the the throttle controls so the crew were unable to retard the thrust). It DID NOT "stall into the trees"...and it did not "travel through the forest". - It was stopped cold by the 1st tree (a rather large and very strong tree), at the edge of the cleared area, the tree still standing in the middle of the fwd cabin where the (severe) injuries occurred. Hence the "skidoo " story, - the track of the A/C was continuous along the snow... Add to this some really bonehead PR work by Air Canada.. Oh... thats another story... sorry... Dave On Wed, 27 Oct 2004 00:46:30 -0400, nobody wrote: Sylvia Else wrote: That accident actually has a lot of commonality with the Air Canada flying skidoo accident at Fredericton. Plane put at low altutude with engines at low speed. In both cases, pilots decide to rev up engines to regain altutude (for the airbus, pilot was just showing off, for the skidoos, the pilot aborted landing). In both cases, engines took some time to spin up and produce necessary thrust (nature of turbine engines). In the case of the flying skidoo, because of no FBW, the pilot stalled the aircraft as he tried to climb above trees, and it fell in the snow and traveled in the forest until it hit a tree. In the case of the 320, the computer didn't allow the pilot to raise the nose, avoiding a deadly stall. But the computer didn't know trees were ahead, so plane traveled into the trees. Had the pilot increased thrust earlier, the plane might have regained suffiencty speed to be able to start climbing without stalling and nobody would have noticed anything. |
![]() "nobody" wrote in message ... Dave wrote: Coming out of a very low (legal) ceiling, the rny was not directly under the a/c, and the crew tried to correct laterally and doing so, the decent rate increased. They started the go around to late, the AC slammed down on the rny hard, the nose gear ripping the control functions as it rammed vertically up through the floor above. The TSB report clearly stated that the pilots initiated a go around WITHOUT LANDING, with airspeed that would have required landing before speed was high enough to climb again. Upon starting to climb again, the skidoo did regain some altitude before stalling, after which it fell to the ground where its recessive skidoo genes became dominant again. One problem is that the flight director had not been programmed to handle such a situation, neither had Bombardier foreseen/simulated situations such as those. While the FO (PIC) was trying to climb according to normal climb rates provided by the flight director, the captain did not realise that the newbie co-pilot wasn't aware of the very low airspeed. FBY is a great concept, but in practice not every conceivable situation/set of circumstances, with all potential variables/responses can be foreseen & programmed into the computer. The only "Computer" I know of that even comes close to dealing with UNK/UNK (unknown/unknown) has 1 mouth, 2 legs, 2 arms, 2 eyes, 2 ears, & when it gets into allows A/C tog get into situations that can't be recovered from is known to emphasize the impossibility of recovering from the situation with a emphatic"OH ****". Ralph Nesbitt Professional FD/CFR/ARFF Type |
Ralph Nesbitt wrote:
programmed into the computer. The only "Computer" I know of that even comes close to dealing with UNK/UNK (unknown/unknown) has 1 mouth, 2 legs, 2 arms, 2 eyes, 2 ears, & when it gets into allows A/C tog get into situations that can't be recovered from is known to emphasize the impossibility of recovering from the situation with a emphatic"OH ****". However, the flying skidoo accident at Fredericton was purely pilot induced. It is in fact one perfect example of FBW's advantages. Pilot's workload was too much for him to handle, and he didn't have the time to monitor airspeed as well as climb angle at same time. Stalled the aircraft as a result. Had there been FBW, with the computer limiting climb rate until engines were producing sufficient thrust, would the plane still have been able to climb sufficiently to avoid trees ? Maybe, maybe not. But the odds would have been better. |
"Ralph Nesbitt" wrote in message m...
"nobody" wrote in message ... Dave wrote: Coming out of a very low (legal) ceiling, the rny was not directly under the a/c, and the crew tried to correct laterally and doing so, the decent rate increased. They started the go around to late, the AC slammed down on the rny hard, the nose gear ripping the control functions as it rammed vertically up through the floor above. The TSB report clearly stated that the pilots initiated a go around WITHOUT LANDING, with airspeed that would have required landing before speed was high enough to climb again. Upon starting to climb again, the skidoo did regain some altitude before stalling, after which it fell to the ground where its recessive skidoo genes became dominant again. One problem is that the flight director had not been programmed to handle such a situation, neither had Bombardier foreseen/simulated situations such as those. While the FO (PIC) was trying to climb according to normal climb rates provided by the flight director, the captain did not realise that the newbie co-pilot wasn't aware of the very low airspeed. FBY is a great concept, but in practice not every conceivable situation/set of circumstances, with all potential variables/responses can be foreseen & programmed into the computer. The only "Computer" I know of that even comes close to dealing with UNK/UNK (unknown/unknown) has 1 mouth, 2 legs, 2 arms, 2 eyes, 2 ears, & when it gets into allows A/C tog get into situations that can't be recovered from is known to emphasize the impossibility of recovering from the situation with a emphatic"OH ****". Ralph Nesbitt Professional FD/CFR/ARFF Type except paul nixon of course |
OK...
So according to the TSB report, did the stall occour before the 1st impact (on the rny and the nose gear failing) or before the 2nd impact after climbing again? The Emergency crews indicated the next day, and it was still visible) , the skidoo track was continuous from the rny to the trees... although the engine thrust could have made the track as well, it was not as well defined the following day, in daylight.... Although I can stand corrected, as my info is from the guys on the response crew (known to me) the following day, I have not seen the whole report... (Fredericton is my home base airport) Thanks! Dave On Wed, 27 Oct 2004 21:00:13 -0400, nobody wrote: Dave wrote: Coming out of a very low (legal) ceiling, the rny was not directly under the a/c, and the crew tried to correct laterally and doing so, the decent rate increased. They started the go around to late, the AC slammed down on the rny hard, the nose gear ripping the control functions as it rammed vertically up through the floor above. The TSB report clearly stated that the pilots initiated a go around WITHOUT LANDING, with airspeed that would have required landing before speed was high enough to climb again. Upon starting to climb again, the skidoo did regain some altitude before stalling, after which it fell to the ground where its recessive skidoo genes became dominant again. One problem is that the flight director had not been programmed to handle such a situation, neither had Bombardier foreseen/simulated situations such as those. While the FO (PIC) was trying to climb according to normal climb rates provided by the flight director, the captain did not realise that the newbie co-pilot wasn't aware of the very low airspeed. |
Dave wrote:
So according to the TSB report, did the stall occour before the 1st impact (on the rny and the nose gear failing) or before the 2nd impact after climbing again? The aircraft did not touch gound before stall. The pilots decided to go around prior to touching ground, but were already going too slow to start climbing right away, but they started to climb right away and stalled. Once plane touched ground, its energy dropped below sustainable flight. It may have bounced during its snow excursion.Don't remainer that detail. But the TSB specifically stated that the plane had begun to climb and gained a tiny bit of altitude before stalling after which, that was it. |
On Tue, 26 Oct 2004 18:12:20 -0700, Jay Beckman wrote:
Is that due to the crash at the Paris Airshow several years back? IIRC, the pilot commanded a flight attitude in the landing config that the software wouldn't allow and that led to the aircraft settling into the trees. Only crash at a Paris airshow that I know of was of a Tu144. No Airbus ever crashed in Paris. |
![]() devil wrote: On Tue, 26 Oct 2004 18:12:20 -0700, Jay Beckman wrote: Is that due to the crash at the Paris Airshow several years back? IIRC, the pilot commanded a flight attitude in the landing config that the software wouldn't allow and that led to the aircraft settling into the trees. Only crash at a Paris airshow that I know of was of a Tu144. No Airbus ever crashed in Paris. I remember the incident though. An A320 full of passengers doing something it shouldn't have at an air show, and ending up descending into trees at the end of the runway. Aircraft destroyed, but incredibly, only one fatality. Sylvia. |
Military: Pilot confusion led to F-16 crash that killed one pilot | Otis Willie | Military Aviation | 0 | September 1st 04 12:30 AM |
P-51C crash kills pilot | Paul Hirose | Military Aviation | 0 | June 30th 04 05:37 AM |
Fatal plane crash kills pilot in Ukiah CA | Randy Wentzel | Piloting | 1 | April 5th 04 05:23 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
