A Q (another) only a non-aviator can ask :)
Old November 19th 04, 05:40 PM
G.R. Patterson III
Bill Denton wrote:
I've seen "negative flaps" mentioned on spec sheets before.
A guess would be flaps extending upward and killing lift necessitated by the
STOL nature of the aircraft.
Am I even close?
Yes and no. Yes, the flaps extend upwards. No, it doesn't have anything to do
with STOL. It's used to reduce drag and increase the cruise speed. I've found
that it is counterproductive above a certain altitude (somewhere around 8,000').
When -7 results in a nose-high attitude, I go back to 0 degrees. I don't often
get that high.
As far as using them for landing is concerned, it allows the pilot to
"three-point" the aircraft at a higher rate of speed. This gives you better
directional control during crosswind landings. Note that the "three-point"
landing under those circumstances is actually a two-point landing, but the
points are the tailwheel and the upwind main.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old November 19th 04, 03:35 PM
OtisWinslow
Interesting. I thought this was more of a cruise thing. May I open
the can of worms and ask why?
"Maule Driver" wrote in message
m...
Sometimes it's best to land without flaps.
In my particular a/c, landings with *negative* flaps are advised. You
don't
want to go there.
Old November 19th 04, 03:56 PM
Scott Skylane
m...
don't
want to go there.
He meant to say "landings with negative flaps are *not* advised"
Happy Flying!
Scott Skylane
Old November 19th 04, 05:41 PM
G.R. Patterson III
No, Maule advises that landing with negative flaps is advised in strong
crosswinds.
George Patterson
Old November 19th 04, 05:31 PM
G.R. Patterson III
Ramapriya wrote:
Is it possible to land without using the flaps at all? Just a
combination of the throttle (forward thrust too, perhaps?), elevator
and ailerons...
Yes. The plane touches down at a higher rate of speed and, consequently, takes
more runway to stop. In my aircraft, for example, I will touch down at about 60
mph with 0 degrees of flaps and 45 mph with 40 degrees of flaps.
Some airliners would risk tire failure if they landed without flaps.
George Patterson
Old November 19th 04, 05:50 PM
Dean Wilkinson
I thought that terrorists didn't care about landing...
"Ramapriya" wrote in message
om...
and ailerons...
I know this will sound like a shocker but I'd appreciate a definitive
NO, so that at least one doubt is bedded
Ramapriya
Old November 19th 04, 09:43 PM
Morgans
"Dean Wilkinson" wrote in message
Don't start that sh*t again!
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.797 / Virus Database: 541 - Release Date: 11/16/2004
Old November 19th 04, 06:27 PM
ShawnD2112
Of course! Flaps are for girls, anyway!! :-)
Shawn
Taylorcraft BC-12D
Pitts Special S-1D
om...
and ailerons...
Ramapriya
Old November 19th 04, 07:00 PM
Journeyman
and ailerons...
throttle == thrust. Throttle controls the engine. The engine
generates both energy and thrust (not the same thing, but two
sides of a coin, depending on which view you need).
You're out of luck :-) As pointed out, some aircraft don't even
have flaps at all.
Flaps generally control how much drag you have (to a degree, they
also change the shape of the wing so you can generate the same lift
at slower speeds). You can also control the drag by flying sideways
a bit. This is called slipping.
It is not approved to do both unless you get the official tee shirt. :-)
Followups to rec.aviation.student.
Morris
