Radio 'altercation' with ATC
Old December 11th 04, 04:53 PM
Newps
Brien K. Meehan wrote:
Newps wrote:
No, the class D tower has no more authority in class E as he does in
class G.
Who says he has no authority in class E or G airspace?
Our rule book.
Old December 12th 04, 07:57 AM
Brien K. Meehan
Our rule book.
I appreciate the hint, but could you be more specific?
Is this a rule book which places regulatory demands on pilots?
Old December 12th 04, 06:28 AM
Steven P. McNicoll
"Brien K. Meehan" wrote in message
I do.
Old December 11th 04, 03:23 AM
BTIZ
Class E airspace in general is UNCONTROLLED.. it is only "controlled" for
IFR traffic.. I can fly in Class E all I want and talk to no one.. as long
as I maintain required visual weather minimums..
BT
91.123 Compliance with ATC clearances and instructions. (b) Except in
an emergency, no person may operate an aircraft contrary to an ATC
instruction in an area in which air traffic control is exercised.
Presumably, the approaching aircraft was in Class E airspace, which is
defined as controlled airspace. Doesn't that obligate the pilot to
follow ATC instructions given to him?
Even if it were Class G airpspace, it's a de facto "area in which air
traffic control is exercised," by the fact that the tower controller is
providing service, and the regulation applies.
It's a given that you have to establish 2-way communication (or make
prior arrangements) before you can enter Class D airspace, and it
follows that if you're not going in to the airspace, you don't need to
contact the controller.
... but once a pilot contacts a controller, isnt' he obligated to
comply whether he's in that controller's jurisdiction or not?
I can't recall any regulation that indicates otherwise.
Old December 11th 04, 05:59 AM
Brien K. Meehan
Everyone knows that.
.... but if you call a controller and ask for service, you ARE talking
to someone. Aren't you obligated to follow instructions given to you
at that point? What regulation indicates otherwise?
Old December 11th 04, 02:42 PM
mike regish
Wasn't the instruction given to maintain visual seperation? Isn't doing a
360 to do that following that instruction?
mike regish
Old December 12th 04, 06:31 AM
Steven P. McNicoll
What instruction do you believe was not followed in this scenario?
Old December 12th 04, 06:27 AM
Steven P. McNicoll
The instruction was to follow the Cherokee. He followed that instruction.
Old December 11th 04, 06:25 AM
tony roberts
Here is a Canadian take on it.
You can do all the 360's that you want to do - when in uncontrolled
airspace - until you communicate with a controller for the purpose of
entering his/her airspace. After communicating with the controller you
should follow their instructions and advise them of any deviation.from
those instructions. As they have the responsibility for maintaining
separation, they have to know where everyone is and what everyone is
doing.
Tony
In article . com,
Howdy,
I was interested in some other pilots' 'takes' on the following. I was
up with a student a few days ago, when another CFI I know (flying out
of the same airport I do) also with a student had an issue with an air
traffic controller. We were both flying out of airport A, which is a
non-towered airport near a fairly large city. Airport B is a class D
(non federal towered) municipal airport about 10 miles South of airport
A. The controllers at airport B have a reputation as kind of prickly.
The following is the jist of the conversation:
Cessna "Airport B tower, this is Cessna 123, 2000 off of airport A, 10
miles North, inbound landing with kilo"
Tower "Roger, Cessna, you will be number 2 for runway 21R, follow
Cherokee traffic at your 11 O'Clock, you also have Cherokee traffic
transitioning at your 2 O'Clock, and Skyhawk traffic inbound on the ILS
for the parallel. Maintain visual separation."
Cessna "Roger, have the Cherokee traffic, will follow him in, visual
separation"
A couple minutes later
Tower "Cessna, what are you doing out there?"
Cessna "Tower, that Cherokee isn't making much progress, we're making a
couple 360s for spacing"
Tower (in a nasty tone) "Negative Cessna! You're following the wrong
Cherokee. You need my permission before making any maneuvers like
that. If you are inbound, you need to be a direct heading *to* my
airport. You can't be doing that kind of stuff without telling me."
[pause]
Cessna "Tower, I was following the Cherokee that was at my 11. Sorry
if I got the wrong one. But sir, I am VFR, *outside* of your
airspace...if I feel the need to do a 360 to maintain safe spacing,
that's exactly what I will do...I'm outside of your airspace. I don't
need your permission to do *anything* until I enter it. Turning 210 for
landing now"
The controller didn't say anything else, expect a gruff 'Cleared for
landing 21R'. I haven't talked to the other CFI about this yet. The
reason I am asking is that my student (already scared to talk to ATC)
is even *more* scared now, and asked me about it.
I told him that the pilot was technically right...if you are in
uncontrolled airspace, and are responsible for maintaining visual
seperation from other aircraft, then you can certainly make 'normal'
maneuvers to do that. And I told him that a Class D tower controller
doesn't have any say about what you do outside of his airspace.
I also told him that it usually wasn't a good idea to have an
altercation like that on the radio. That if the pilot wanted to talk to
the controller about that, he should have waited until he was on the
ground, and called the tower and asked to speak with a supervisor. I
also told him that the other CFI 'probably' should have told the
controller what he was doing as a matter of 'courtesy', and that if he
wasn't absolutely sure which Cherokee to follow, he should have told
the controller that he'd remain outside of his airspace until the tower
told him the traffic was clear, and then turn in. Plus, it isnt a good
idea to alienate the ATC guys in your own area....they can make life
'interesting' sometimes.
But the tower controller didn't tell him to copy a number (altho maybe
he got that on the ground. But I asked a few of the other CFIs I work
with about this..most agreed with me, but a couple thought the pilot
was wrong for various reasons.
So...what is your take on this?
Cheers,
Cap
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old December 11th 04, 07:35 AM
snip
deviation.from
doing.
In the U.S., the class D tower controller is not responsible for
separation in the class D airspace. Only on the runways. That should
give a U.S. pilot more leeway in a situation as described in the
original post. Since the tower controller is not responsible for
maintaining separation between aircraft, I'm more inclined to take
action on my own to ensure that separation is maintained. The caveat
being that I will inform the tower of what I'm doing and why.
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 09:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 11:57 PM
Radio waves vs light waves Jay Honeck Piloting 63 February 22nd 04 06:14 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 01:05 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 04:30 AM
