![]() "Michael" wrote in message oups.com... This would be because pilots, like all other people, have this idea that authority and responsibility go together. Actually, there are quite a few people that don't understand that. |
On 17 Dec 2004 08:29:29 -0800, "Michael"
wrote: My problem with Class D space is that it seems to impart an inappropriate comfort level to many pilots who don't understand what is (and is not) being provided. This would be because pilots, like all other people, have this idea that authority and responsibility go together. In other words, if the controller has the authority to tell you how to fly your pattern, when to turn, etc - then the responsibility for separation in the air should also be his. Well, it doesn't work that way. THAT is the primary weakness of Class D airspace, and it can't be fixed unless you either make the controller responsible for separation (meaning that unless the pilot disregarded the controller's instructions, it's controller error, not pilot error, in the event of a mid-air or near miss) or you give the pilot the authority to disregard the controller's instructions at will, not just in the event of an emergency (thus making the airspace uncontrolled). But while this is an issue in theory, in practice it's usually not an issue. In reality, at most Class D's most controllers treat separation as if it were their responsibility. That means they issue clear and comprehensible instructions and ask for a readback of the key points, just as if they were issuing clearances. When that happens, pilots treat the instructions as if they were clearances - meaning they question those they don't understand, read back those they do, and comply - and things work OK - a little better than they would if the airspace was uncontrolled. Sometimes you get a bad or overloaded controller, and then things are MUCH worse than they would be if the airspace was uncontrolled. That's when you get the problems. I will be the first to admit that I will let a situation that looks ugly develop a lot further in Class D than I will in Class E or G. I Class E/G, I know there's nobody looking out for me but me, and if I don't have a plan nobody does. So when I see things not going to plan (someone too close for comfort) I take action immediately. Not so in Class D. Unless the controller has given me reason to doubt his competence (by doing things like issuing nonsensical or illegal instructions, chewing out pilots on the frequency rather than calmly giving them a number to call, and generally acting like he lost SA) I'm going to assume he has a plan, and I'm going to stick with his plan until there's just no way. I think most pilots would too. I guess this is what you call inappropriate comfort level. You are of course entitled to your opinion, but I don't consider it inappropriate given the way Class D normally operates. Given the legalities, you have a point. Michael Perhaps a poor choice of works, Michael. By inappropriate comfort level I meant that the pilot may have a false sense of security because he thinks the controller is responsible for more than he really is. Too many pilots lose just a little bit of the edge when they think someone else is watching over their wellbeing. I'm speaking specifically of VFR pilots, all of whom were taught that ATC does not provide separation in the air for VFR aircraft in the Delta, but many have "forgotten". Rich Russell |
Richard Russell wrote:
My problem with Class D space is that it seems to impart an inappropriate comfort level to many pilots who don't understand Exactly. The pilots don't understand. Maybe it wasn't such a good idea to choose a cheapo ground school and do the written by merely learning the questions catalogue by heart and hoping for some luck? (I'm deliberaely exaggerating.) Stefan |
I'll chime in on this with a slight tangent...
My airport - HYX / Saginaw Mi - is an uncontrolled field with a 5,000 foot runway, VOR-A approach, GPS approach, NDB approach, and the brand spanking new ILS is to be turned on 'any day now'... This oughta get good once the jets (and mucho others) start shooting ILS into the field and don't understand that local traffic does N O T listen to ATC - especially the nordo guys... Plus, students will often be shooting crosswind circuits and bangs for practice (3 flight schools on field) - and me too, slow learner... And worse, on nice days the jumpers talk to ATC up until 2 minutes before jumping when their s**t head pilot makes a single announcement on a really busy 122.8... Someday there's gonna be a happening due to that... Meat bombs at 120 mph straight down from 12,000 feet into a busy airport pattern... (arghh) Actually, a jumper hit a hangar in November breaking his leg and denting the hangar, (it used to be my hangar) but I guess you can't blame that on the radios... A Class D would actually be an improvement... Denny |
![]() "Jay Honeck" wrote in message news:fPAwd.586096$D%.508731@attbi_s51... Right -- there is no separation provided in Class D. And no one should expect the controller to maintain separation. So it appears the problem is pilot's understanding of Class D airspace. This is precisely my point, which may be summed up thusly: Class D is "pretend" controlled airspace. It should be regarded as "Barely controlled" or "Semi-controlled"... Controlled airspace means an airspace of defined dimensions within which air traffic control service is provided to IFR flights and to VFR flights in accordance with the airspace classification. Let's call Class D airspace what it is - controlled airspace. |
Jay Honeck wrote:
This is precisely my point, which may be summed up thusly: Class D is "pretend" controlled airspace. It should be regarded as "Barely controlled" or "Semi-controlled"... Perhaps you've not a problem with the airspace, but with the term "controlled". After all, class E airspace is "controlled" too; see the AIM (section 2 defines "controlled airspace", if memory serves). But (I hope!) nobody expects VFR separation there. - Andrew |
Jay Honeck wrote:
This is precisely my point, which may be summed up thusly: Class D is "pretend" controlled airspace. It should be regarded as "Barely controlled" or "Semi-controlled"... But it *is* controlled. Heck, even Class E is controlled airspace! In class D, IFR flights are vectored. In class D, the controller has the right to give instructions even to VFR flights, as in "keep out" or "leave" or "stay west of that river and below 3000 ft". If you can't tell "controlled" from "separation provided", then this isn't a flaw in the concept, but rather in the pilot's knowledge. Stefan |
I doubt you have flown into an environment that was busier than that
segment of time that Mary and I hit Dubuque. Jay, don't be so sure. I fly as many hours in a year that you've flown in ten, based on one of your post to another reader. As I said previously, I was not there and I am in no way judging your actions or implying that you did anything wrong. I was only attempting to suggest possible options for people to consider when things do not go as we might expect. For all I know you may well have considered these as well as others. Next time I get over to that side of the world I'll stop by the Alexis Park Inn and introduce myself. PJ ============================================ Here's to the duck who swam a lake and never lost a feather, May sometime another year, we all be back together. JJW ============================================ "Jay Honeck" wrote in message news:hhtwd.207711$V41.132095@attbi_s52... I have flown into Dubuque a few times so I'm familiar with the area. I have also more frequently fly in and out of much busier Class D airspaces than Dubuque, most all of which have traffic simultaneously on left and right down winds. I have no problem with this. .. I've flown into Oshkosh and Sun N Fun numerous times -- arguably the busiest airspace in the world -- and not seen (and heard) more people landing than we did in Dubuque. It was just a fluke thing, with many students, many simultaneous arrivals, and one doofus pilot all arriving in DBQ at once. Twenty minutes later, eating breakfast, we saw nary a plane landing. I'm sure you've already seen all the "see and avoid is your responsibility, not the controllers" etc etc... I was not there so I am not condemning your actions, but... snip Not to pick on you, PJ, but I always have to laugh at the folks on the newsgroups who immediately swing the old "it's your responsibility to see and avoid" bat whenever I (or anyone else, for that matter) brings up problems with controlled airspace. NO ONE is arguing that it is not our responsibility to see and avoid. NO ONE is advocating any other rule, and NO ONE is abdicating that responsibility. This point of this thread is an entirely separate issue, and ONLY pertains to my perceptions of the weaknesses of the FAA's concept of Class D airspace. For example, did you notify the controller that you 'had the traffic insight" and if you thought he was in the 'wrong' position in the pattern, did you relay your concerns to the controller? IMHO it would be inappropriate to call out "traffic in sight" to a controller who (a) had not called out traffic to me specifically, and (b) was rattling off instructions a mile a minute to half a dozen other planes. Trust me, if the airwaves had been silent, Mary would have been asking ATC what the heck that guy was doing. We are all responsible for proper safety and communication it every bit as important as "see and avoid". Agreed. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
segment of time that Mary and I hit Dubuque. Jay, don't be so sure. I fly as many hours in a year that you've flown in ten, based on one of your post to another reader. You fly 900+ hours per year? As I said previously, I was not there and I am in no way judging your actions or implying that you did anything wrong. I know. Next time I get over to that side of the world I'll stop by the Alexis Park Inn and introduce myself. We'll keep the beacon on for ya! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay,
Yes I do. Actually a bit higher. It was more tempting when I thought you said "We'll keep the bacon on for ya!" PJ ============================================ Here's to the duck who swam a lake and never lost a feather, May sometime another year, we all be back together. JJW ============================================ |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
Negative XPDR - under the outer ring of Class C | bcjames | Piloting | 8 | August 30th 04 11:49 PM |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
Overlapping class C & D | Andrew Sarangan | Piloting | 14 | May 6th 04 04:08 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
