"zero" versus "oscar" versus "sierra"
Old December 17th 04, 06:03 PM
Jose
[ zero poppa and sierra poppa]
Can you apply for a completely new identifier?
Jose
Freedom. It seemed like a good idea at the time.
Old December 17th 04, 07:56 PM
Peter R.
Ron Garret ) wrote:
It happens that there's another airplane at my airport with the exact
same identifier identifier except that it ends in "SP". In the air it
turns out that "zero poppa" and "sierra poppa" sound an awful lot alike
(try it), which has occasionally led to confusion when both planes are
in the pattern.
I trained in a C172 that ended in 0LP (Zero Lima Poppa). Most times
when I used the abbreviated callsign, the controller would almost always
hear "Zero Juliet Poppa" and call back to ask which call sign it was.
Those two also sound similar over the radio when 0LP is spoken a bit too
fast.
Peter
Old December 17th 04, 08:49 PM
Bill Denton
As a former disc jockey, let me give you a hint. By and large, the
understandability of a communication is not really dependent upon how fast
the words are spoken.
To avoid miscommunication, you want to strongly "attack" each word, make
sure you say the entire word with no trailing off at the end, and make sure
you leave a slight space between words.
Fast or slow, "zerolimapappa" will never be as intelligible as "ZEEro -
LEEma - PAppa".
A couple of more hints. Spend a little time "over pronouncing" words, where
you make sure you are saying every syllable. It will sound really "stilted"
for a while, but if you keep practicing, in a short time you will develop a
natural rhythm. Listen to a good radio or television announcer and you will
see what I'm talking about.
And try to more or less snap out the word, like they do in the military when
they say something like: "Yes - Sir".
I'm a Suthunah, and when I got into radio I first had to learn how nawmul
people tawk when they're talking sloppy, then put a little polish on it. It
took me about six months total to do it. bit it's really not that hard to
do, just make it a point to be constantly conscious of how you are
pronouncing and pacing words, and you'll pick it up in no time...
"Peter R." wrote in message
in the pattern.
fast.
Peter
Old December 17th 04, 10:18 PM
Peter R.
snip
I'll give it a try. Thanks for that, Bill.
Peter
Old December 17th 04, 11:55 PM
Ben Jackson
LEEma - PAppa".
When I bought N8674P I found that I was getting a lot of incorrect
readbacks from ATC. This prompted me to use a very crisp, deliberate
style like you describe. My experience was that it was pretty much a
wash. If you slow down too much it seems to be harder for the controller
to recall the sign. I get the best results with a crisp enunciation but
at full speed.
Ben Jackson
http://www.ben.com/
Old December 17th 04, 09:00 PM
Schmoe
Ron Garret wrote:
I fly an airplane whose last two digits in its identifier are "0P"
(indicating that it's an OurPlane aircraft). Of course, OurPlane
would have liked it to be "OP" instead, but the FAA won't allow
"oscar" in aircraft identifiers, only "zero".
What kind of planes are both?
Old December 17th 04, 09:19 PM
Dan Luke
"Ron Garret" wrote:
In the air it
"SIERRA" is a failure as a phonetic letter and should be changed, IMO.
"SUGAR" was better, but it is too much of an oddball pronunciaton to be
successful internationally. How about "SUPER?"
in the pattern. (I've taken to saying a very exaggerated version of
ZEEEEEE-ROW-OOOO when I'm flying.)
Some pilots with "SIERRA" in their tail #s get sick of the continual
confusion and substitute "SUGAR." Controllers always accept it, even use it
themselves sometimes. Normally I am opposed to non-standard phraseology but
I make an exception in this case. "SIERRA" sucks.
Dan
C-172RG at BFM
Old December 17th 04, 11:00 PM
AJW
In the air it
Dan
C-172RG at BFM
Man, just call yourself oscar pop!
Old December 18th 04, 06:10 AM
BTIZ
that's about as bad as Kilo and Quebec... Q in the military jargon was
pronounced KayBec..
don't know how many times I would write down a K instead of a Q and have to
go back and check it when decoding messages..
BT
"Dan Luke" wrote in message
"Ron Garret" wrote:
In the air it
it
but
Dan
C-172RG at BFM
