A Level 1 AOA clarification
Old December 26th 04, 06:54 AM
Peter Duniho
"Ramapriya" wrote in message
Getting back to basics, wings produce lift only when wind hits them,
i.e. when the aircraft starts moving. This keeps increasing until the
airspeed is adequate enough to produce a total lift that can levitate
the aircraft. Since the angle of the wings can't be varied,
See my reply to George. The angle of the wings CAN be varied, and doing so
is essential to the art of flying.
ignoring
flaps momentarily, I can't see how the stall AOA can be independent of
airspeed. What then is 'stall speed' of an airplane?
The stall speed of an airplane is the airspeed at which the airplane will
stall, assuming straight and level unaccelerated flight. Any published
stall speed is actually specific to a certain weight (most popular stall
speeds to know are for maximum weight), and for a specific configuration
(for example, gear and flap extension both can change stall
speed...especially flaps).
If stalling AOA is reached, adding engine power before the plane goes
into a stall will prevent the stall by increasing airspeed, right?
Sort of. By the time you are down to stall speed, what additional engine
power actually does is to allow you to fly at *lower* airspeeds. However,
yes...commonly when one is near stalling and doesn't want to be, increasing
engine power is one part of the recovery. If not combined with a reduction
in pitch attitude, all that more power will do (assuming everything else is
held constant) is to cause the airplane to climb.
Pete
Old December 27th 04, 04:46 AM
CV
By reducing the AOA actually, which happens as a consequence of
increasing airspeed. But see below also.
And it is interesting how that actually happens. The vertical component
of thrust takes a bit of the load off the wings which helps reduce the
AOA and keep it under the limit of the stall. Part of the weight is
in fact hanging by the propeller, like a helicopter.
CV
Old December 27th 04, 05:58 AM
Peter Duniho
"CV" wrote in message
No. Increased airspeed happens as a result of reduced angle of attack, not
the other way around. Airspeed has no direct effect on AOA, though it does
have indirect effects (since changes in airspeed affect what AOA you need
for a given performance goal, whether that's turning, climbing, descending,
or whatever).
Thrust does contribute, yes. But the primary reason for requiring
additional power is that, while the wing is capable of generating the
necessary thrust at a lower airspeed, higher angle of attack (all the way up
to the stalling AOA of course), the higher angle of attack results in higher
drag, requiring higher thrust.
Pete
Old December 26th 04, 04:27 AM
Ramapriya
Andrew Sarangan wrote:
a. is dependent on its airspeed, and is independent of its weight
and
weight distribution, and
No, the stall AOA is independent of both airspeed and weight.
Too confusing
the aircraft. Since the angle of the wings can't be varied, ignoring
b. varies, for a given airspeed, with the air density (altitude)
No the stall AOA does not vary with density.
The stall AOA is determined by the shape of the wing. It is
independent of
weight and airspeed. However, the airspeed vs AOA relationship
depends on a
variety of factors, such as weight and density. This is why stall
speed is
somewhat a misleading quantity. AOA would be a better quantity.
Unfortunately there is no direct way to measure the AOA in most
aircraft,
so we use the airspeed as an indirect indication of the AOA.
Don't know much yet about this but I'm sure I saw the AOA indicated in
an A320 cockpit recently. I thought the pitch itself indicated AOA but
when the captain showed me the actual AOA reading, it varied by a wee
from the aircraft's pitch. He had to punch some buttons into the flight
computer to get the AOA reading.
Need to read up John Denker's book and the FAA material a lotttt more,
I guess :\
Ramapriya
Old December 26th 04, 03:03 PM
Andrew Sarangan
ups.com:
and
Too confusing
I see where you are getting the misconceptions from. You are thinking of
the takeoff and landing as the start and end of flight. Just because an
aircraft is on the ground does not mean it is stalled. Instead, picture
an aircraft in mid flight. Then imagine what happens if you increase the
angle of attack. The airflow over the wings will start to break up. This
is the start of stall.This point is only related to the angle at which
the airstream strikes the wing.
Think of the AOA as the difference between the angle where the aircraft
is pointing and where it is going.
independent of
depends on a
speed is
aircraft,
flight computer to get the AOA reading.
True, some of the larger aircraft and military jets have an AOA
indicator. Most small aircraft do not have an AOA indicator. There is a
good reason for this. In a large aircraft, the weight can vary
substantially over its flight envelope. This will result in a large
variation in stall speed. In a small aircraft, the stall speed variation
is rather small, and a single stall speed can be used safely.
I guess :\
No, you need to take a couple of flying lessons.
Old December 26th 04, 03:42 PM
Hilton
IMHO, there is no good reason for not having an AOA indicator on GA
aircraft. Stall/spin is a leading cause of death among GA pilots and
passengers. Best glide (potential emergency situation) is determined by
AOA. Put an AOA sensor on GA planes with a hand that smacks the pilot on
the head when the AOA approaches the critical AOA and a lot fewer people
will die while having fun on the weekends.
Hilton
Old December 26th 04, 04:42 PM
tom418
"Hilton" wrote in message
link.net...
Hilton
The April, 1973 (yeah, that's a while ago) issue of FLYING had a great
article about Safe Flight's AOA indicator. Peter Garrison described it as
"phenomenally useful", after flying a Beech Sierra equipped with one.
Old December 26th 04, 05:14 PM
Greg Esres
passengers.
Caused by the pilot not paying attention. Will having another
instrument that he's not paying attention to really help?
Best glide (potential emergency situation) is determined by AOA.
A few knots either way isn't going to make much difference. Plus, how
often is maximum glide range critical in an engine out situation? How
closely is the pilot really maintaining one airspeed (or AOA) during
an emergency?
the head
Some studies I've seen have shown that pilots are often oblivious to
warning horns and lights, though stick shakers are effective.
My prediction: put an AOA indicator on every airplane in the fleet
and you won't see much change in the accident rate due to stall spin.
Old December 27th 04, 05:14 AM
Andrew Sarangan
I agree that AOA is a nice instrument to have, but I am not convinced if
that is going to reduce the number of stall spin accidents. Most stall spin
accidents despite all stall indications, such as low airspeed, buffet and
descent rate. Having another instrument on the panel is not going to change
the situation.
"Hilton" wrote in news:5_Azd.10136$9j5.3520
@newsread3.news.pas.earthlink.net:
Hilton
Old December 27th 04, 02:40 PM
Denny
Well, not to dispute the thrust of your argument, but your statistics
are wrong... CFIT is the leading cause of injury and death in GA...
Stall/spin crashes in vfr flight are down the list a ways..
Now, if the pilot is incapable of noticing the air speed indicator well
down into the white arc, or is incapable of noticing that the nose is
well up, or that he is pulling G's while stomping top rudder, what
makes us suspect that he will notice the AOA needle in the red?
Denny
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Altimeter setting != Sea Level Pressure - Why? JT Wright Piloting 5 April 5th 04 01:04 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
flight level in Flight simulator Robert Piloting 3 August 20th 03 07:37 PM
