On Tue, 28 Dec 2004 at 03:56:41 in message
, G.R. Patterson III wrote: If I leave the flaps at 0 degrees, slow down to 60 mph indicated and raise the nose enough to stall, the aircraft will be climbing just prior to the stall. The relative wind will be "coming from above", since that is the direction in which the aircraft is traveling. I think the question here is "Above What?" If the aircraft is flying then the relative wind will be coming from a direction in which the velocity vector of the aircraft is pointing (assuming we are talking still air). But it will not be coming from "above the aircraft". A normal angle of attack sufficient to satisfy the required lift vector must still exist. The lift required when climbing is normally somewhat less than that required in steady horizontal flight. -- David CL Francis |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
flight level in Flight simulator | Robert | Piloting | 3 | August 20th 03 07:37 PM |
