The regulator's sensing is usually taken directly from the
alternator's output terminal, not the bus, and voltage variations at the bus may not be present at the alternator's sense terminal so it might not respond to a seemingly low system voltage. This could happen if there's a bad connection between the alternator output and bus, such as the crimped connections in the output cable, connections at the alternator output breaker, or the breaker itself. None of these are unusual, and the voltage will usually drop further as load is applied and the resistance in the connections makes itself known. That said, the regulator is often overlooked in the search for alternator problems. The regulator controls the field current in the alternator, and if it's not doing it well the output voltage will be off or erratic. Lots of alternators have been replaced for no reason other than a bad or misadjusted regulator. Dan |
![]() G.R. Patterson III wrote: "Robert M. Gary" wrote: a volt reader in the panel. According to AC 43.13-1A -- "The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage, when the generator is carrying rated current or the battery is being charged at the 5-minute rate. The following tabulation shows the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment." It's interesting that if I take the alternator and regulator to the bench I can hold 100amp without dropping below 14v. I guess the in-airplane application is a lot different than the bench environement. -Robert |
In looking for some 43.13 in html, I found this thread. Just had to
comment... 1A was quoted, 1B is current and the relevant passage is in Section 5, 11-66.b According to AC 43.13-1B -- "The voltage drop in the main power wires from the generation source or the battery to the bus should not exceed 2 percent of the regulated voltage when the generator is carrying rated current or the battery is being discharged at the 5-minute rate. The tabulation shown in table 11-6 defines the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment ground." Two different current paths are being addressed; one from the generation source to the bus, and a second from the bus to the load. Dissecting that sentence a bit to get two, one for the generation source and one for the battery. 1) The voltage drop in the main power wires from the generation source to the bus should not exceed 2 percent of the regulated voltage when the generator is carrying rated current. 2) The voltage drop in the main power wires from the battery to the bus should not exceed 2 percent of the regulated voltage when the battery is being discharged at the 5-minute rate. Two totally different statements. The current in the gen/alt circuit should never exceed it's charging capacity; hence that limitation, however the discharge current from the battery to the bus (in a fault condition) could approach that 5-minute rate they speak of. That's the rate where you have a dead battery in ~5 minutes and approximates the battery ampacity*12. For most of the small batteries, say a size 35, the 1C rate is in the low 20's. The Concorde 25 size is rated 21Ah; the 35 size at 25Ah. 21*12=252. That's a lot of current! It's not exactly linear either, the actual current is less, but I haven't seen too many published 12C rates. So the first sentence says you cannot exceed 2% drop from the generation source to the BUSS, at rated current. For most of us with 14V (pick your reference) systems that is ~ 0.28V. That statement is for the circuit to the generator/alternator, only and is not too difficult to comply with with a 50 or 60A source. Even with the 100-150mV or so of drop across the gen/alt breaker, you still have a bit over 100mV of drop in a wire to work with. Fifty amps through ten feet of AWG-2 is about 85mV. This is the easy part to comply with. That second one is the killer, especially for those with an aft mounted battery. Assume the 5-minute discharge rate isn't really 252A, but (for ease) only 200A. Ohms law R=E/I 0.28V/200A=0.0014 ohms. That's only a bit over eight feet of the #2 cable, and if you have an ammeter shunt in the battery cable, subtract another 50mV from your budget and shorten up that cable even more. The last statement, "The tabulation shown in table 11-6 defines the maximum acceptable voltage drop in the load circuits between the bus and the utilization equipment ground." clearly states voltage drops between the bus and equipment ground; effectively from the breaker unique to the equipment to the ground connection for the piece(s) connected to that breaker (powered from the bus). For most loads these are easy; 0.5V continuous and 1.0V intermittent, for 14V systems. Only high current loads are much of a problem; heated pitot tubes, gear/flap motors, landing/taxi lights and such. Most all under 20A. So back to the question, acceptable bus voltage. The comments on regulator stability are prime, especially for charging, and (I think), the intent of the question, as the AC reads "2 percent of the regulated voltage". What is the regulated voltage? As was posted earlier, depending on temperature Concorde suggests 13.7514.75V so that 0.28V should be decent estimate for a 14V system. Measure your alt/gen terminal voltage (under load directly across the terminals) and to be legal per 43.13 your bus should not be more than 0.28V less, and your battery should charge... My apologies for my long (and first) post. I hope to create no ire from the group and hopefully contribute something of value for those interested. Ron '73 BL17-31ATC |
![]() "Robert M. Gary" wrote in message oups.com... I guess my question is; do all planes generate about 13.6v with accessories on? I also teach in a large variety of planes, but none have a volt reader in the panel. When I was reading your original post, I thought I read 12.6. I was reading what I thought was abnormal, but now looking at it, I see I was not. ?.? 13.8 volts is considered normal, so 13.6 is not so bad after all. Are you getting any warnings, or anunciatiors at the 13.6? The next question is, are you able to complete a flight with everything on, and come back and still be reading the same battery voltage (engine off) that you started with? If so, no worries! -- Jim in NC |
There are six diodes in the common three-phase alternator.
Dan |
Normal voltage drop | Robert M. Gary | Owning | 19 | January 3rd 05 04:12 AM |
C182 - Intermittent Alternator | WinstonCup | Owning | 9 | November 12th 04 12:22 AM |
no RPM drop on mag check | Dave Butler | Owning | 19 | November 2nd 04 02:55 AM |
Cessna 210 charging problem | John Clonts | Owning | 9 | July 14th 04 03:08 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
