More newbie Qs
Old December 31st 04, 12:36 AM
ohfuk24
These are questions that EVERY student pilot has. Hence the reason that you
are a student pilot. You need to talk face to face with an instructor
and/or take a ground school at your local FBO. ALL of your questions will
be answered, as well many other things.
It is ridiculous to think that you can try to get your groundschool
knowledge and studying done by writing to a usenet group. It doesn't matter
how qualified the respondants are, you are wasting your time. You are not
gonna get any sign offs for this studying, if you wanna call it that. Take
the ground school and start flying. Get off your bum and make it happen.
The world will open up and the sun will shine so much brighter on your
knowledge level and you won't be wasting everyone else's time either. By
the way, everything that you don't understand on the ground will be a whole
lot clearer when you are in the air seeing how it works first hand.
"Tobias Schnell" wrote in message
On 30 Dec 2004 02:43:33 -0800, "Ramapriya"
1. How does a pilot get to know the distance to the airport that he has
to land in, so that he plans his descent accordingly, in planes that
don't have an onboard computer? Maps I know would give the distance
between two fixed points, but how does he keep track of distance
covered in flight and that sort of thing? To inquire ground stations
such info would be embarrassing, I guess
What do you mean by "onboard computer"? Most airplanes nowadays (even
small single-engine-ones) have GPS receivers, for which the easiest
task is "tell me the distance to airport XYZ". Modern airliners are
equipped with flight management systems. These derive information
about the airplane's position from various sources (ground-based
navaids, inertia, GPS...), so no problem there, too.
If you don't have all those toys, it is likely that you have at least
a VOR receiver (see below), an ADF or a DME. With those you can also
calculate distances to a fix, but that may require some mental math to
be done.
Airplanes without any onboard electronics are normally flown day-VFR
only, so distance calculation can be made by dead reckoning or
pilotage. But if you are unsure you can of course ask a radar
controller for assistance.
2. What exactly is a VOR? Sounds like it's a constant all-direction
radio transmission from a fixed point on the airport to help locate
where the airstrip is. If so, does it necessarily have to be from *a*
standard designated point in the airfield, right across all airfields
on earth?
VORs are not necessarily located on airports. For technical details do
a google search, I am sue you will find better explanations than what
can be given here in text-only-mode.
Basically a VOR receiver in the airplane tells you the bearing from
the station to the airplane. Pilots are talking about so-called
"radials", e.g. if an airplane is on radial 270 of a VOR, its position
is due west of the VOR.
Most VORs are used for enroute navigation, but there are also
instrument approaches relying on VORs. But as VORs used for approaches
can be located anywhere on the field or even be off-airport, minimums
are usually higher than for an ILS approach.
3. If a pilot needs to land at an airport that doesn't have a control
tower, how does he figure its elevation so that he may plan his
descent?
The elevation of an airport is published. And even non-attended
filelds often have automatic weather reporting that provides an
altimeter setting. If not, you can use the altimeter seting from a
nearby airport which is nomally not too far off.
4. When a pilot says, "Give me a vector", what does he actually mean?
He requests heading instructions from a radar controller, for example
to intercept an ILS or to an airport.
5. When pilots use miles in conversations, does it mean the miles we
normally use, or is it always nautical miles?
Pilots are using nautical miles.
6. The difference between airspeed and groundspeed is that airspeed is
the net of the plane's speed and opposing windspeed, while groundspeed
is just the plane's speed. Right?
If a plane would fly at sea level with an airspeed of 100 kts and
there was a headwind of, let's say 50 kts, its groundspeed would be 50
kts. With calm winds, the groundspeed would also be 100 kts.
When flying higher, air- and groundspeed differ even with no wind, as
the air becomes less dense with altitude, so indicated airspeed
decreases.
Look for "indicated" and "true" airspeed in the books you should have
bought by now ;-).
7. What is "density altitude", and how to compute it? If I'm not wrong,
its use is to plan the length of takeoff roll and angle of climb.
Uh, I'll leave that to someone else now...
Regards
Tobias
Old December 31st 04, 01:24 AM
Bob Moore
that you are a student pilot. You need to talk face to face with an
instructor and/or take a ground school at your local FBO. ALL of your
questions will be answered, as well many other things.
Going back to Ramapriya's first posts, I don't recall him ever stating
that he is/was a student pilot or has any intention of becoming one.
His questions arise from a trip during which he rode in the cockpit of
an Airbus jetliner and overhearing the conversations between the pilots.
Again, (I might be wrong) I don't think that groundschool is his goal.
As a retired airline pilot, I understand where his questions are coming
from. Many of those responding to his questions do so from a Private
Pilot perspective, not understanding that his line of questioning began
with jet Transport Category aircraft... thus many answers that he finds
to be in conflict.
Out of curiosity, I had just as many questions after my first trip to
the cockpit of a Piedmont DC-3 back in 1955. I had no intention of ever
becoming a pilot. Now, after 25 years of airline flying, I'm glad to
answer some of Ramapriya's questions from the Jet Transport perspective
where his series of questions started.
Speak for yourself, not everyone else.
has to land in, so that he plans his descent accordingly,
Three miles out for every thousand feet of altitude works
quite well for most jetliners.
Bob Moore
CFI ATP B-707 B-727
PanAM (retired)
Old December 30th 04, 01:20 PM
Brian
Try the link below for a very simple Simulator of Aircraft Navigation
Instruments.
Even experienced pilots can learn a lot from this simulator.
http://www.vrotate.com/VOR/vor.html
Brian
CFIIG/ASEL
Old December 30th 04, 02:05 PM
Brian
Instruments.
Brian
CFIIG/ASEL
Old December 30th 04, 04:36 PM
Tobias Mock
The best I've found about calculating it is he
http://wahiduddin.net/calc/density_altitude.htm
The author's main interests seem to be "spiritual life" and
"density altitude". Haven't read the "spiritual life" part, but
the "density altitude" part is profound.
Tobias
Old December 30th 04, 05:25 PM
G.R. Patterson III
If the aircraft has no electronic means of determining position, the pilot uses
"pilotage" to keep track of his location. Basically, the pilot notes things on
the chart close to his course that can be seen from the air; these are called
"waypoints". Once in the air, the speed over the ground can be determined by
timing how long it takes to fly between two of these waypoints. The pilot can
then figure out the point at which he wants to start the descent and how long it
will take to reach that point from the closest waypoint to it. Pass over that
waypoint and start your descent at the appropriate time.
Pretty much, except that VORs aren't always (or even usually) located at
airports. The transmitter broadcasts a signal that is modulated in such a way
that the receiver can tell in what direction the transmitter lies. The pilot can
then twist a dial to center a needle on an instrument called a "course deviation
indicator" and read off the direction.
descent?
The elevation is recorded on charts and in airport directories.
He's asking someone to tell him what heading to fly.
In conversation with ATC, we use nautical miles.
Airspeed is the speed the aircraft is traveling through the air. Groundspeed is
the speed the aircraft is traveling over the ground. The speedometer in an
aircraft measures airspeed (with varying degrees of accuracy). This is called
"indicated airspeed". Pilots can correct this for inaccuracies to determine the
actual (or "true") airspeed. Let's say that I'm flying into a 20 knot wind and
my airspeed indicator shows I'm going 100 knots and it's accurate. My
groundspeed will be 80 knots. If I then turn around and go the other way, my
groundspeed will be 120 knots, but my airspeed will not change.
It's a measure of air density and, yes, we use it to calculate the effects of
atmosperic conditions on the performance of the plane. Low pressure, high
temperature, and high humidity all reduce air density and reduce performance. An
airport may be at 90' ASL, but the plane performs as if the airport were at
3,000' ASL if the density altitude is 3,000' (as it may be in high summer).
Usually charts or calculators are used to determine density altitude. I get the
current figures as part of weather briefings.
First, set the altimeter to 29.92 Hg and read the altitude. This is called the
"pressure altitude" and will frequently be different from the actual elevation
of the airport. Then I would use a graph from my pilot's manual to determine the
density altitude for that pressure altitude and the current temperature. It's 7
degrees C at the moment and I am close to sea level. From my graph, that
temperature at that level reduces density altitude by about 800', so an aircraft
will perform better than usual. If the temperature were 30 degrees C, the
density altitude at sea level would be about 2,000' when the air pressure is
29.92 Hg.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old December 31st 04, 12:01 AM
BTIZ
Man.. just sign up for and take a ground school..
Ground school by Newsgroup or Usenet is getting old..
BT
"Ramapriya" wrote in message
I wish you all a very cheery 2005. You really are a nice set of guys
here (those branding me a terrorist notwithstanding), mostly patient
even at clarifying elementary stuff
Some more Qs, if you don't mind.
on earth?
descent?
Cheers,
Ramapriya
Old December 31st 04, 12:07 AM
BTIZ
It's called pilotage, you always know where you are.
on earth?
not on all airfields and not always at airfields..
descent?
he looks up the airport information before he starts out, the control tower
is not going to tell you the airfield elevation unless you ask, and then it
just shows that you did not do your preflight planning., very unprofessional
he needs a heading to fly to get somewhere, normally to get started while he
sorts it out in the cockpit, or the navigational aid he is heading to is to
far away to recieve
professional pilots use nautical, it is one arc minute of latitude on the
navigational charts
you got that backwards, ground speed is the net of airspeed and wind
effect..
airspeed is the speed of the aircraft through the air mass, regardless of
how the airmass is moving in respect to terra firma
there you are correct, density altitude will affect engine, propellor and
wing performance.
it is the air at elevation, normally measured by pressure and affected by
temperature.
high hot and humid is a bad combo
Cheers,
Ramapriya
Old December 31st 04, 02:01 AM
Christopher Brian Colohan
"Ramapriya" writes:
This is not technically an answer to your questions, but I may be able
to answer all of them at once. :-) Go look on ebay.com for some books
on flying. People who have finsihed their training are selling them
all the time for dirt cheap prices. I managed to pick up an outdated
copy of the Jeppesen Private Pilot textbook for $5. This book would
answer every one of your questions, and more, with much more detail
and better pictures than you are likely to find on this newsgroup or
on the web.
You probably don't want an outdated textbook to work from if you are
currently studying for a license, but if you are merely curious, want
more information for playing with flight simulators, or may be
studying flying at some undetermined point in the future when you have
more cash (like me) then it is perfect.
Chris
Chris Colohan Email: PGP: finger
Web:
www.colohan.com Phone: (412)268-4751
Introduction to a newbie Shane O Aerobatics 9 December 31st 04 06:13 AM
Questions from a newbie. Andrew Tubbiolo Home Built 9 September 14th 04 01:40 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 07:47 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
