"Matt Barrow" wrote in message
... According to a radio show last night, the lasers have been all "green" except one. Sounds like it might be the laser pens, but do those have enough strength to light up a target several thousand feet away? I have a bunch of high power visible lasers. All except one are Argon or Argon / Krypton Gas Ion lasers. Argon produces a mixture of blue and green colours and Krypton generally produces red. They range in output from 3 to 13 watts. The largest is a mixed gas Argon / Krypton. The same laser with an Argon tube can produce over 20 watts. But they're *big*. The power supply is the size of a small refrigerator. The head is over 7 feet long and weighs about 200 lbs. They require 480V AC service and draw about 50 amps. They also require water cooling at a rate of about 3 US gallons per minute. Hardly portable. And, they cost at least 25K for a decent used one. A high level of technical expertise is required to operate them. Go here and look for "Ion Lasers". http://www.cohr.com/ There are portable systems that can produce power in these ranges though. More later. I used to have one near the top of the CN Tower in Toronto. It was a large frame Argon laser and produced about 20 watts. It was focused on the ground about 3 miles away. I can't remember what the power level was at the ground. But it was well below 2.5 mw/cm (the safety limit for brief exposure). However, even at that level it's still bright enough to temporarily affect night vision after a brief exposure. The reports indicate a green beam. There are a few types of solid state lasers that produce green at high power. Here's one of the largest: http://www.laserfantasy.com/products_i2000.asp Again, it requires a fair bit of power and water but I've seen portable versions of them. They're expensive (~50K US) and require technical expertise to operate. So I don't think they're practical for covert terrorist activities. On the small scale, there is a device (I happen to have one) that could be used as a turbocharged pointer. Go to http://lasers.mellesgriot.com/default.asp and look at "Diode Pumped Solid State Lasers". These produce about three watts of green and only draw about 150 watts. They could easily be powered by a small Inverter in an automobile. Cost is about 12K US new. Now for a reality check. To actually blind someone at a distance of several miles is practically impossible. It would require a very high power laser and sophisticated tracking equipment. Even then, one would have to intentionally stare at the offending beam for permanent damage to occur. The same tracking system with a smaller (~2 watt) laser could be used to make it impossible to carry out the visual portion of an approach. But, and anyone experience with laser shows will tell you, holding a beam steady at a distance of miles is really tricky stuff. However, I think that an amateur, armed with a 3 watt DPSS laser could cause some serious problems just by sitting in a vehicle at the end of a runway and eyeballing shots at incoming planes. Now, in anticipation of the question, here's what it feels like to get zapped by one of these things at a distance. (It's happened to me many times.) You will be momentarily blinded. It won't incapacitate your vision for more than a few seconds, assuming that you blink. You will want to abort the approach, not because you won't be able to land, but because the same thing might happen again. Obviously you'll want to alert the police and FSS or Tower. If the idiot shining the beam leaves it on, you should be able to see their location. The colour produced by these devices is an odd sort of green that doesn't occur in nature an is unmistakeable. Here's some links on laser safety. http://www.laserist.org/Laserist/Safety.html http://www.laserfx.com/Science/Science4.html moo |
Well, Happy Dog, I suspect I speak for most everyone here when I ask: What the heck do you *do* for a living? :-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message news:TijCd.614532$wV.146573@attbi_s54... I have a bunch of high power visible lasers. Well, Happy Dog, I suspect I speak for most everyone here when I ask: What the heck do you *do* for a living? Doesn't involve mutant sea bass, does it? |
I have a bunch of high power visible lasers. Well, Happy Dog, I suspect I speak for most everyone here when I ask: What the heck do you *do* for a living? www.libertygrand.com www.eventservices.ca www.aerobatics.ca www.bovinesexclub.com The terrorist thing is just a hobby. :-) moo |
Happy Dog said about all that needs to be said about the topic. These are
unlikely to cause any serious injury. It is just like the mass hysteria that followed the craze of pointing red LASER pens at people. (a) You are not going to be blinded by one of these (b) Are you *really* frightened that somebody is pointing a gun at you? Get over it. Aviation is cause for a little more concern as even becoming distracted at a critical moment can lead to or contribute to an accident chain...but will not likely be the only cause. Sure, perhaps somebody with a military grade LASER can aim it at you, the light attracts you to look at it (natural response) and in the few milliseconds that you actually look at it, your eye balls melt and both you and your co-pilot are blind. Wasn't this also the topic of a Clancy novel and/or movie? I also heard a rumor that we tested a weapon like this once. A giant LASER with a mirror for high speed aiming powered by a huge diesel generator was driven out onto the battle field and blinded a bunch of the enemy in desert storm...so the story goes. But this source says they existed and were never used.... ["Laser Weapons. The United States also has developed advanced laser weapons, which are designed to blind opponents or disable weapons' firing optics, and are equipped its Army with it. Rupert Pengelley, technical editor of Jane's Information Group, was quoted by an Associated Press report as saying that the laser weapons also might see their first use by US forces in Iraq. The US Army equipped its Bradley Fighting Vehicles with laser weapons in the 1991 Gulf War, but they were never used, the report said, quoting sources in the Federation of American Scientists. Human Rights Watch urged a ban on laser arms in 1995, calling it "unnecessarily cruel and injurious." But media quoted Pengelleyas saying that the US military, which has been developing lasers for roles that include missile defense and air-ground attacks, believes it "can now use this in a fitting and legal manner on the battlefield." ] http://english.people.com.cn/200303/...9_114207.shtml Guess I had a little to say too... |
"Slip'er" wrote in message
Aviation is cause for a little more concern as even becoming distracted at a critical moment can lead to or contribute to an accident chain...but will not likely be the only cause. Sure, perhaps somebody with a military grade LASER can aim it at you, the light attracts you to look at it (natural response) and in the few milliseconds that you actually look at it, your eye balls melt and both you and your co-pilot are blind. Wasn't this also the topic of a Clancy novel and/or movie? I also heard a rumor that we tested a weapon like this once. A giant LASER with a mirror for high speed aiming powered by a huge diesel generator was driven out onto the battle field and blinded a bunch of the enemy in desert storm...so the story goes. But this source says they existed and were never used.... Visible light lasers wouldn't work since the targets can just close their eyes or look away. UV would be more effective since it would fry retinas before the victims could react. Also, UV lasers are available in extremely high power ratings. moo |
![]() "Corky Scott" wrote in message ... Has anyone been following the disturbing (to me anyway) news stories about airliners approaching to land being hit with laser beams aimed at the cockpits? There are several possibilities: 1) There are terrorists out there planning to make airliners crash with laser beams and the government has warned us in the nick of time. 2) Terrorists read the government warning and thought "What a good idea!" and are conducting tests. 3) The local airport haters read the government warning and thought "Revenge at last!" and are trying to shut down airports, hopefully with great loss of life so they can say "See, I told you so! Airplanes are dangerous and a hazard to the community and should be banned forever!" The only difference, of course, between an airport hater and a terrorist is that the airport hater is not generally associated with Islam or extremist political groups. Other than that, both are willing to resort to violence and intimidation in order to achieve their idea of paradise. The news media, law enforcement, and politicians are too cowardly to call a local soccer mom who doesn't like airplanes a terrorist, even if she has repeatedly threatened life and property in public hearings. 4) Kids read the government warnings and thought, "Cool, we can make a plane crash!" and are zapping planes with their laser pointers. 5) Pilots, alert because of government warnings, are over-reacting to accidental contact with legitimate (but possibly careless) users of lasers, including folks who got new telescopes for Christmas. 6) Any combination of the above. Heck, there could even be web sites and Usenet forums devoted to such things. Personally, I doubt that there is one single conspiracy run by some mastermind who is coordinating these attacks. I mean, in any population of nearly 300 million people, there are bound to be some heavily armed random nuts out there. Sooner or later one of them is going to build a nuke, and we can forget all about lasers. |
"C J Campbell" writes:
"Corky Scott" wrote: Has anyone been following the disturbing (to me anyway) news stories about airliners approaching to land being hit with laser beams aimed at the cockpits? There are several possibilities: [snip] 5) Pilots, alert because of government warnings, are over-reacting to accidental contact with legitimate (but possibly careless) users of lasers, including folks who got new telescopes for Christmas. An argument against the idea that it's a new telescope owner is that the green laser pens are typically over $100 (vs. maybe $10-15 for a typical red laser pointer). Also, the green pointers are mostly used in amateur astronomy by someone knowledgable about the sky, who (hopefully) has a bit of common sense. (Of course, this doesn't in any way say that it isn't a newbie; there are people with lots of money who think an Astro-Physics 8" refractor is just right as a first telescope, just like people who do their student training in a Baron because they think a Cessna 150 is for the hoi polloi...) I do hope that this doesn't lead to DHS outlawing the green laser pens. I use one in an astronomy program I run with the National Park Service inside the District of Columbia (in Rock Creek park, under the flight path that choppers follow to and from the VP's residence on the Naval Observatory grounds). And yes, I *am* careful to avoid pointing it anywhere near anyone overflying the area; the program's been running for over 50 years and I would hate to have it shut down. Joe Morris |
![]() "Joe Morris" wrote in message ... I do hope that this doesn't lead to DHS outlawing the green laser pens. I use one in an astronomy program I run with the National Park Service inside the District of Columbia (in Rock Creek park, under the flight path that choppers follow to and from the VP's residence on the Naval Observatory grounds). And yes, I *am* careful to avoid pointing it anywhere near anyone overflying the area; the program's been running for over 50 years and I would hate to have it shut down. I am sure most of us would hate that, too. You never know what the Department of Homeland Fear will come up with next, though. |
![]() Joe Morris wrote: An argument against the idea that it's a new telescope owner is that the green laser pens are typically over $100 (vs. maybe $10-15 for a typical red laser pointer). Another argument against this is the location of some of these incidents. You aren't going to see much of the night sky anywhere close to Teterboro, for example. George Patterson The desire for safety stands against every great and noble enterprise. |
"Laser injures Delta pilot's eye" | Mike | Piloting | 15 | October 1st 04 08:25 PM |
Boeing $241.8 million contract ballistic missile-hunting Airborne Laser | Larry Dighera | Military Aviation | 1 | May 29th 04 12:05 PM |
Laser simulator provides weapons training | Otis Willie | Military Aviation | 0 | August 28th 03 09:58 PM |
