![]() "Jim Burns" wrote in message ... .... and have you ever done it in an airplane without a stall warning indicator or an airspeed indicator that drops to 0 before your wing quits flying? Jim Not a big deal if you know your airplane. My butt and finger tips work better than a stall warning or the pointer on the airspeed indicator down at mca. wrote in message oups.com... Have you ever really taken your aircraft to the bottom edges of its flight ability and airspeed, and flown it with any degree of precision and of more than just a few moments/minutes? Are you comfortable doing it on the edge or nibble of a stall? Can you do it while holding altitude and desired headings within reasonable limits - depending on your experience? |
Yep. My Tripacer.
mike regish "Jim Burns" wrote in message ... .... and have you ever done it in an airplane without a stall warning indicator or an airspeed indicator that drops to 0 before your wing quits flying? Jim |
![]() wrote in message oups.com... Have you ever really taken your aircraft to the bottom edges of its flight ability and airspeed, and flown it with any degree of precision and of more than just a few moments/minutes? Are you comfortable doing it on the edge or nibble of a stall? Can you do it while holding altitude and desired headings within reasonable limits - depending on your experience? When is the last time you did it just to sharpen your skills without prompting by a CFI in the next seat? When is the last time you spent some diligent time doing stalls and the full range of them with your aircraft? Are you honestly comfortable with your abilities? I know I have to think about it every time I go fly and always find some fault with my performance. In a previous post it appeared I aggravated some pilots or CFI's with saying I felt many pilots didn't know how to fly slowly these days. I have seen a slow errosion of what used to be basic pilot skills and level of performance with too many pilots compared with acceptable standards not that many years ago. Now if that won't open a bucket of worms I'll be surprised. Fact is, just making the FAA minimums doesn't necessarily make you safe or even a good pilot. Care to weigh in on the issues? I'll be polite in my responses in accordance to the way they are presented to me. No axe to grind, no ego to inflate (its big enough already thank you) just a sincere desire to make pilots think a little more about what they are doing when they go flying. You need to make your own mistakes to hopefully learn from them and avoid repetition. Ol Shy & Bashful I would not have posted in this thread had you not referenced the other thread peripherally in your comments. Your points are well taken, and have validity. It's true that there are many pilots out here who don't spend nearly enough time in the left corner of the envelope, and doing so would make them much safer pilots. I see only one difference between my approach to flying and what you have stated here. I have a problem with your sentence as follows; "You need to make your own mistakes to hopefully learn from them and avoid repetition." In my end of the business thinking like this will kill you. It's for this reason that I never taught my students, both primary and aerobatic, to think this way. Although it's fine to learn from a mistake, and by all means, pilots should learn from mistakes if they live through that mistake, but my thinking on this leans heavily toward the prevention of mistakes, rather than learning from them. Most good pilots I know have no problem understanding that time spent in the left corner is time well spent, and most CFI's doing the job properly spend plenty of time exploring slow flight and flight at and near CLmax with their students. This is especially true of aerobatic instructors. Plainly put, if instructors are not doing this, they are not doing the job properly. It behooves all pilots to stay current by practicing flight in the left corner, and what you have said about that is highly relevant to flight safety. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/CFI Retired for private email; make necessary changes between ( ) dhenriques(at)(delete all this)earthlink(dot)net |
Dudley
Thank you for your reply. On the issue of making mistakes....if a pilot never makes one, what have they learned that will take care of them when the inevitable mistake occurs? Certainly our goal is to show pilots how to avoid mistakes but I can't divorce myself from the knowledge I learned from all those I have made. How to get out again safely is the goal isn't it? Cheers Rocky |
![]() wrote in message oups.com... Dudley Thank you for your reply. On the issue of making mistakes....if a pilot never makes one, what have they learned that will take care of them when the inevitable mistake occurs? Certainly our goal is to show pilots how to avoid mistakes but I can't divorce myself from the knowledge I learned from all those I have made. How to get out again safely is the goal isn't it? Cheers Rocky I think it has to do with the way you approach both teaching one to fly and learning to fly, which by the way, I've always considered one in the same :-) You are absolutely correct that learning from mistakes is critical. This is something you ingrain into every new pilot from the gitgo. But there's another level you can strive to attain, and I believe the sooner you make the transition from the obvious, (learning from mistakes) into the development of the mental attitude that defines for you a doctrine of prevention as your PRIMARY approach to flying, the safer you will be in the long run. Just because a pilot is thinking prevention doesn't take him out of the learning from your mistakes level. That also exists, it just doesn't exist in the pilot's mental attitude as job one. Job one remains prevention. Many pilots never actually manage to make the transition into the prevention mode, and remain virtually static in the approach they bring to the flying table. Many fly entire careers without ever REALLY developing an action rather than reaction mental attitude toward flight safety. Your post on developing expertise in the envelope left corner is actually typical of the prevention approach to flying. I commend you for using it and attempting to spark a fire under others to do the same. In my opinion, the prevention approach to flight safety is the only approach. Never in one's flying career is this more relevant than when transitioning out of simple airplanes into more high performance airplanes. Never is this also more relevant than when a pilot begins doing things with airplanes that require an ever increasing level of performance. I believe the mental attitude a pilot develops during his/her initial phases of flight training will remain with that pilot all through their career in flying. It's for this reason that the role of the primary instructor is so important to a new pilot. If the CFI is lacking in his/her desire to instill in a new pilot the importance of a prevention approach to flight safety, that omission can have disastrous results down the road. In my world of demonstration flying, I have seen 32 of my fellow friends and professional associates die in accidents. Many of these could have been prevented. No...there are many professions in this life where one can afford the luxury of leaning on axioms like "If I make a mistake, I'll be sure to learn from it" I just believe that flying airplanes just might not be the best venue for this type of thinking. I much prefer to turn out a pilot who's attitude has been drilled into him by my constant reminder to him that, "You will never reach perfection in your flying, but every second you spend in the air should be spent TRYING to reach it. Learn from a mistake by all means, but put your entire effort....your entire concentration, toward PREVENTING that mistake from happening in the first place". Every pilot who has ever been trained by me, ESPECIALLY the instructors, have left with this drummed into their heads if I've taught them nothing else. All the best Dudley |
I also fly a PA28 (180C). During pre-departure checklist at night my
wife (sitting in the right seat, and not a pilot) reached up to set the upper door latch as I got to that part of the checklist. I thought she had latched it for me. OAT was -5C on the ground. We were cleared to depart IFR and as I got to 800 AGL and switched freqs, the upper door seals gave way and wind in the plane became so bad that I couldn't hold a chart unless I had on gloves (which I didn't). So I made the mistake of opening the side latch in an attempt to re-shut the door and get both latches to latch. Neither latch could be operated at that point, and ATC could hardly hear me over the wind noise -- and I certainly couldn't hear them. Thankfully it was VMC (because my approach plates were flying around the cabit) and I could do an immediate 180. I was at an IAS of 35MPH with the wheels on the runway before I was able to get the door shut and the latches done. I think I want to try this slow flight, at altitude, and see if by slipping I can get that door shut and latched bottom and top. And would you suggest using full flaps at that point? Also, I have several speed mods on this plane, so its actual stall speed is about 10 MPH less than the stall light is set to come on. Later, Steve.T PP ASEL/Instrument |
![]() steve.t wrote: I think I want to try this slow flight, at altitude, and see if by slipping I can get that door shut and latched bottom and top. And would you suggest using full flaps at that point? I've done this several times in a Cherokee 180 and it works just fine. Just slow down, extend full flaps and bring the airspeed go just above the stall (pretend you're doing minimum controllable airspeed on the private pilot PTS). At that speed, you won't even need to slip. Just push the door into the (now light) slipstream and give it a firm pull. It should close without a problem. At that speed, low pressure will not be exerting much pull on the door and you should be able to secure the top latch easily. Caveat : If the door pops with a passenger, I highly recommend that you have the passenger lean back while you close it yourself. I had a passenger last year that got over-excited about getting the top latch closed and he twisted it right off (while latching it in the process). When we got back to the airport, I had to crawl out the baggage compartment door and let him out using the exterior latch. The fix cost about $150 with parts and labor. |
In article .com,
" wrote: steve.t wrote: I think I want to try this slow flight, at altitude, and see if by slipping I can get that door shut and latched bottom and top. And would you suggest using full flaps at that point? I've done this several times in a Cherokee 180 and it works just fine. Just slow down, extend full flaps and bring the airspeed go just above the stall (pretend you're doing minimum controllable airspeed on the private pilot PTS). At that speed, you won't even need to slip. Just push the door into the (now light) slipstream and give it a firm pull. It should close without a problem. At that speed, low pressure will not be exerting much pull on the door and you should be able to secure the top latch easily. Has anyone here ever successfully performed (or even attempted) this maneuver in a Cirrus? rg |
On 14 Jan 2005 13:27:11 -0800, "steve.t"
wrote in .com:: I also fly a PA28 (180C). During pre-departure checklist at night my wife (sitting in the right seat, and not a pilot) reached up to set the upper door latch as I got to that part of the checklist. I thought she had latched it for me. I usually give the door a firm shove when that checklist item comes up. But this time it was warm, and I wanted to wait until cleared to take the runway before latching the door. [...] I think I want to try this slow flight, at altitude, and see if by slipping I can get that door shut and latched bottom and top. My experience revealed that kicking in a bunch of rudder had no effect on getting the door to latch. Of course, that may have been due to the cabin vents being open. It would be interesting to know the results of your tests. And would you suggest using full flaps at that point? Well, you can fly slower with flaps deployed, and they may add a bit of stability while mushing along. Also, I have several speed mods on this plane, so its actual stall speed is about 10 MPH less than the stall light is set to come on. The reduced stall speed with the indicator still set for the pre-mod stall speed probably causes you to ignore it most times. I wonder what the FAA and speed-mod manufacturers recommend? |
Interesting. Life history of John Lear (Bill's son) | Big John | Piloting | 7 | September 20th 04 05:24 PM |
Interesting Resume (V Long) | Bob Chilcoat | Piloting | 24 | September 13th 04 06:44 AM |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
