Class III vs. Class II medical
Old February 7th 05, 09:56 PM
Doug Vetter
G. Sylvester wrote:
Any reason I should get a Class II or should not get a class III?
to me it sounds like get a Class II and at worst, it cost me an
extra 15 minutes.
Gerald,
I have a congenital / functional heart murmur (actually the most mild
form recordable, but whatever). It was picked up by my AME (who used to
screen pilots for the military...surprise, surprise) during my first
medical evaluation 15 years ago, shortly after I started flying.
The FAA wanted an EKG to determine the severity of the murmur even
though I was only going for a Third Class. The Cardiologist who
performed the EKG ultimately said everything was fine, so right off the
bat I knew I could pass an EKG and the First Class medical. Good thing
I knew this, because my intention at that time was to fly
professionally. Had I continued with training and not been able to pass
anything beyond a Third Class, I would have wasted a lot of time and
money. For that reason, I recommend you go for the most stringent
medical you foresee needing in your aviation career and maintaining that
until you really need it.
FYI, I have a CFI and must maintain at least a Second Class, but have
continued to get First Class medicals because my AME has charged the
same amount for medicals not requiring an EKG and because I still have
this crazy notion that I may fly professionally after I pick up my ATP
this year (only 80 hours to go...wahoo!!). I turned 35 last year and
had to do an EKG for an extra $20, but I won't have to do another one
until I turn 40, which will be NEVER, of course. :-) So, until you
turn 40, there should be no significant cost differences between the
various medical classes.
As far as failing a medical goes, if your AME is reasonable he'll submit
paperwork for the highest class of medical you can pass, rather than
submitting paperwork he knows will result in a rejection. It's bad
business and doesn't help you when / if you choose to go for waivers.
If I ever find myself in that situation, I'm sure having a long history
of First Class medicals won't hurt me, either.
Oh, and if you're wondering what doctors can diagnose using an EKG,
check this out. Pretty interesting stuff.
http://www.ecglibrary.com/ecghome.html
Hope this helps,
-Doug
Doug Vetter, CFIMEIA
http://www.dvcfi.com
Old February 8th 05, 07:41 PM
No, it isn't 'dead'. I went through this exact problem this last year,
when my application for a renewed Class II medical had to be sent over
to OK City, due to a medication I was taking. I still had 2 years
remaining on the 'Class III' component of my medical. I talked to the
AOPA, and they said they have case law as well as an FAA opinion
supporting the contention that the Class III component remains viable;
the AME concurred, as did one of the most experienced DEs in the
country, with whom I took my CFI checkride while the medical was under
review. In fact *he* had a nearly identical experience before, and said
he had talked to the regional Flight Surgeon, who concurred that the
remaining component was valid.
Look on your medical certificate itself. On the back, it states
"Unless reversed or otherwise limited in duration, this certificate, in
accordance with 61.23 (14 CFR part 61) becomes valid for the time
limits specific below."
There is a huge difference betewwn a 'denial' and a 'deferral'. 99% of
the time when an AME punts up the chain, he defers the decision. He
does not physically take your medical certificate away. He does not
'deny' you a certificate. He does not 'reverse' it. The FAA does not
send you a registered letter indicating the suspension or reversal of
the certificate. If it isn't in the FARs (it isn't), and it isn't on
the medical (it isn't), and it isn't on anything you sign or agree to,
how on earth could the FAA make a case that the remaining component was
invalid? Where is the regulatory basis for that assertion?
Please find me *any* 'black letter' documentation in Part 67 or part 61
of the FARs that supports the notion that as soon as you apply for a
new medical, your old one becomes invalid. You won't, because it
doesn't exist.
I think your AME told you wrong.
Cheers,
Cap
Steve.T wrote:
Uh, it isn't. In fact, I found out that your existing medical is
*DEAD*
upon filling out the official form for a new medical. I found that
out
when I had to report an irregular heart beat and had to do the Holter
monitor, Stress EKG and echo-cardiograph (they use a sonogram to
examine your heart to see if it has valve problems, etc.).
I had thought that my old Class III was still valid and was flying
with
it. The senior AME that had to review all the records I took him
informed me that my old medical was dead the moment my pen hit the
new
official form!
And because I had all the paperwork already done (thank you AOPA) and
was able to submit it to that Sr AME, he decided to issue the Class
III
and make the FAA Medical people issue a cancellation -- because it is
only noticeable by me at rest!
Later,
Steve.T
PP ASEL/Instrument
ps. I just have an irregular heart beat. But now that I've gone
through
all this, I should easily pass the Class I.
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 01:29 AM
Question Medical Captain Wubba Piloting 5 June 11th 04 06:12 AM
Antidepressants and 3rd Class Medical Tim Howell Piloting 16 July 21st 03 04:36 PM
