![]() " Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com Sounds like a good book, Ed. I look forward to reading it some day.... |
![]() Larry Dighera wrote: Does the military _ever_ return its airspace to public use? Yes it does. ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. snip It's hard to form an opinion on this without knowing what sort of airspace they're looking for. Restricted? Prohibited? MOA? The U.S. Pilots Assoc. (whoever they are) has decided that this will be "dangerous for small, civilian aircraft", but doesn't really say why. John Galban=====N4BQ (PA28-180) |
![]() wrote in message oups.com... It's hard to form an opinion on this without knowing what sort of airspace they're looking for. Restricted? Prohibited? MOA? The U.S. Pilots Assoc. (whoever they are) has decided that this will be "dangerous for small, civilian aircraft", but doesn't really say why. Safety concerns are frequently cited by those that oppose some activity. Such claims are often bogus. |
![]() "Larry Dighera" wrote in message ... Does the military _ever_ return its airspace to public use? ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." http://www.avweb.com/eletter/archive...ll.html#189168 Go to www.cannon.af.mil . There is a 421 page .pdf of the proposed areas. The proposal creates a new MOA on the flight path. I lived in Roswell for 10 years. MOA's and Restricted areas pretty much encircle it. Try getting out west bound, you have to fly to Albuquerque or El Paso before you can go on to say, Phoenix. Roswell (Walker AFB) used to be a SAC base until the Johnson years, when it was closed down. It is kind of neat flying eastbound in the springtime. You can see outlines of ships and swastikas that have been graded into the dirt for targets. Watch out for the 5,000' towers though ![]() Allen |
On Mon, 14 Feb 2005 18:58:00 GMT, "Allen"
wrote: Go to www.cannon.af.mil . There is a 421 page .pdf of the proposed areas. The proposal creates a new MOA on the flight path. I lived in Roswell for 10 years. MOA's and Restricted areas pretty much encircle it. Try getting out west bound, you have to fly to Albuquerque or El Paso before you can go on to say, Phoenix. Roswell (Walker AFB) used to be a SAC base until the Johnson years, when it was closed down. It is kind of neat flying eastbound in the springtime. You can see outlines of ships and swastikas that have been graded into the dirt for targets. Watch out for the 5,000' towers though ![]() A lot would depend upon when the ten years were. Roswell airport used to be Walker AFB a long time ago. Dunno if they still do it, but after Walker was closed and it became the Roswell industrial air park, they did 747 training there for a number airlines. You're right about airpace restrictions to the west, but most of that is Holloman AFB space, not Cannon. Cannon stuff is almost all to the N. The MOAs for Holloman don't start until about thirty miles W. of Roswell or about thirty miles S. They have fairly high floors so VFR traffic can transit quite comfortably (and the do, particularly enroute to and from Ruidoso.) W. of US highway 54, N. of Alamogordo you get into the White Sands Missile Range which is restricted, not MOA. That goes from surface to the moon, but transit is often allowed on weekends when it isn't in use. S. of Alamogordo on both sides of US 54 from Alamogordo to El Paso is restricted airspace, but used by the missile range, not by flying operations. A block down along I-10 from ELP to Las Cruces is used by the air defense training at Ft. Bliss. There were a number of low level routes, fewer since Walker and Biggs closed, since SAC operations were reduced, and fewer again since Cannon converted from F-111s. But, they are warning not restricted. The targets you mentions seeing aren't for live weapons delivery unless you really penetrated some restricted airspace like Oscura range. They probably date back to WW II. Dunno I ever saw a 5,000' tower anywhere while flying in that country. Since the surface elevation is over 4,000, you might be reading the MSL of the tower--look in the parentheses to see the actual tower height. Get much above 1200 feet and you've got a pretty significant tower. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
wrote in :: "Larry Dighera" wrote in message .. . Does the military _ever_ return its airspace to public use? ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." http://www.avweb.com/eletter/archive...ll.html#189168 Go to www.cannon.af.mil . There is a 421 page .pdf of the proposed areas. The proposal creates a new MOA on the flight path. Many thanks for that link. Here are some excerpts from the USAF EIS with my comments interspersed: DRAFT ENVIRONMENTAL IMPACT STATEMENT FOR NEW MEXICO TRAINING RANGE INITIATIVE a. Responsible Agency: United States Air Force b. Cooperating Agency: Federal Aviation Administration c. Proposals and Actions: This Draft Environmental Impact Statement (EIS) analyzes the potential environmental consequences of a proposal to modify the training airspace near Cannon Air Force Base (AFB), New Mexico. The proposal would improve airspace for training primarily New Mexico-based pilots. The existing airspace no longer suffices to train aircrews in all of the tactics they will be expected to use in combat. The Proposed Action and two action alternatives are comprised of four elements: modifying the configuration of existing airspace (including expanding the size, operational altitudes, and usefulness of the Pecos Military Operations Area [MOA] and associated Air Traffic Control Assigned Airspace [ATCAA], and moving Jet Route J-74 [J-74] and deconflicting commercial traffic five to seven nautical miles (nm) north of the modified training airspace); creating new airspace (the Capitan MOA/ATCAA to connect the existing Beak MOA and the expanded Pecos MOA); flying at supersonic speeds above 10,000 feet above mean sea level (MSL) or approximately 5,000 to 6,000 feet above ground level (AGL) in the airspace; and extending the use of defensive countermeasures (chaff and flares) to the new and modified airspace. Alternative A modifies the airspace configuration, establishes the Capitan MOA/ATCAA, includes supersonic flight above 10,000 feet MSL, and expands defensive chaff and flares use. Alternative A does not move J-74. Under Alternative A, other deconfliction methods could be instituted to route commercial traffic around active Pecos North ATCAA airspace. Alternative B modifies the Pecos MOA/ATCAA airspace, reroutes J-74 traffic, includes supersonic flight above 10,000 feet MSL, and extends use of defensive chaff and flares. The Capitan MOA/ATCAA would not be created under Alternative B. Under the No-Action Alternative, aircrews would continue to train in the existing airspace, fly at supersonic speeds above 30,000 feet MSL, and use defensive chaff and flares. If proposed alternative A or B were implemented, would the military airspace above 10,000' be returned to civil use? d. Comments and Inquiries: Written comments on this document should be directed to Ms. Brenda Cook, New Mexico Training Range Initiative EIS Project Manager, HQ ACC/CEVP, 129 Andrews Street, Suite 102, Langley AFB, VA 23665-2769. Telephone inquiries may be made to Cannon AFB Public Affairs at (505) 784-4131. ... Under No-Action, aircrews would be required to travel to bases or locations with adequately sized airspace for training with current weapons and tactics. This would both reduce training opportunities and increase costs. ... Under the Proposed Action and Alternative B, rerouting commercial traffic from the current J-74 and other directly routed civilian aircraft would add one to two minutes of additional flight time for a re-routed aircraft. ... The increase in sonic booms from one per five days under No-Action to two per three days under the Proposed Action or Alternatives A or B would not be expected to affect wildlife or livestock behavior. ... Predicted peak overpressure noise from sonic booms would not be strong enough to cause damage to structures in good condition. ... Sonic booms are not expected to occur at pressure levels that could damage structures, although older windows or objects on shelves could be vibrated or damaged. Change in sonic booms from one per five days to two per three days or any chaff or flare residual materials would not be in amounts that would affect property values or land use. The added risk of flare-induced fire in the affected area, compared to other potential sources of fire, would be very low. Therefore, no effects on socioeconomic resource are expected from the Proposed Action or Alternative A or B. In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 An annual total of 60,770 chaff bundles and 40,286 flares would continue to be authorized throughout the new, modified, and existing airspace. ... About 5 million chaff strands are dispensed in each bundle of chaff. ... These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! ... Under the airspace, 14 percent is lands managed by the Bureau of Land Management (BLM), 16 percent is state land, and 69 percent is private. ... There are seven counties underlying or partially underlying the training airspace. ... Record searches of both the New Mexico State Register of Cultural Properties and the NRHP indicate that there are NRHP-listed properties in one county underlying project MOAs and proposed expansion areas. As Table 3.6-1 indicates, listed properties in De Baca county include the De Baca County Courthouse, which was constructed in 1917; the Fort Sumner Railroad Bridge, which was constructed in 1906; the Rodrick Drug Store; the Fort Sumner Women’s Club; and the Fort Sumner Ruins. ... Towns within the study area range in population from less than 200 to about 1,900 (University of New Mexico [UNM] 2000). The majority (78 percent) of the land under the airspace is privately held. The majority of the public land that would be affected by the Proposed Action is administered by the BLM. ... Approximately 71 percent of all land under the restricted airspace is held in private ownership, 21 percent are state lands, and 8 percent is administered by the Air Force (Air Force 2001e). ... One high-altitude Jet Route, J-74 (J-74), provides direct east-to-west routing between the Texico VORTAC and the Corona VORTAC. Jet routes are established under Federal Aviation Regulation (FAR) Part 71 in Class A airspace to designate frequently used routings. Jet routes extend from FL 180 to FL 450, inclusive. They have no specified width; width varies depending on many aeronautical factors (FAA Order 7400.2 2000). J-74 passes over the Pecos North High MOA, through the northern portion of the Pecos ATCAA, and over the restricted airspace associated with Melrose AFR. Currently, the Pecos ATCAA is capped at FL 300, and does not conflict with civil traffic generally at FL 310 or higher. Commercial traffic routed via direct or using J-74 fluctuates from light to heavy, depending on the time of day. Most traffic involves operations to and from Dallas-Fort Worth, Texas. Peaks normally occur during mid-morning and mid to late afternoon (personal communication, Semanek 2004). The 27 FW seldom requests authorization to use this airspace because it is unavailable for military use even though it is greatly needed for training. The lack of access has “conditioned” the 27 FW to constantly work around this capped airspace, which diminishes the area for realistic training. ... IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. ... Currently, J-74 provides routing between the Texico Very High Frequency Omni-directional Radio Range and Tactical Air Navigation Aid (VORTAC) (east of the New Mexico Training Range Initiative [NMTRI] airspace) and the Corona VORTAC (west of the NMTRI airspace). This route passes through the northern portion of the Pecos ATCAA. Conflicting use of this airspace is resolved by Air Traffic Control (ATC). J-74 would be moved under the Proposed Action. This could be accomplished by establishing a way-point north of the ATCAA, and the route would be divided into two segments. ... Rerouting J-74 and direct traffic to the north encroaches on the utilization of another jet route further to the north. This is the area of J-72 ... ... The average time between aircraft ranges from 2.7 minutes to 20.9 minutes. The peak hour demand, which occurs on Thursday from 11:00 a.m. to noon, would increase peak traffic from 19 flights per hour to 30 flights per hour (see Table 4.1-1). The Air Force believes that scheduling and coordination are required to prevent over-extension of the National Airspace system. ... The Air Force believes the likely number of aircraft requiring air traffic control service from FAA controllers falls within their ability and expertise to deconflict in the area north of the Pecos MOA/ATCAA complex. To fully unencumber active available airspace for military training, IFR traffic transiting this active airspace must file their flight plans to avoid the Pecos airspace complex through the Aeronautical Information System Replacement system. The existing Pecos MOA complex would be expanded laterally and vertically under the Proposed Action. The MOAs would be expanded laterally to conform with the lateral boundaries of the ATCAA overlying the complex. This expansion would include a southerly expansion of the Pecos South Low MOA, thus adding additional low altitude military airspace in that region (down to 500 feet AGL). Is that an additional airspace grab? The proposed westward expansion of the Pecos complex would result in the MOA overlying portions of one Federal Airway, V-291. This airway provides routing between the Corona VORTAC and Roswell. The proposed MOA expansion would not totally prohibit use of this airway. ... The proposed southerly expansion of the Pecos South Low MOA, into the area of the previously defined “Roswell Shelf,” would result in lowering MOA airspace in that region from 11,000 feet MSL to 500 feet AGL. ... Expansion of the Pecos MOA complex could interact with traffic on the “Worth-3” SID. ... Depending on which airspace were active for training, rerouting could require flying around the entire Pecos MOA/ATCAA complex. The more likely effect to private pilots would be to schedule a flight at a time other than the hours during the typical two days per month when the Capitan MOA/ATCAA was in use. As is always the case, if an emergency, such as a life-flight were required, the Air Force would immediately shift or end training to accommodate the emergency. ... The increase in sonic booms from supersonic activity would be noticeable and can be intrusive. They will occur on average two times in three days ... Public concerns expressed during scoping include annoyance of people who are startled by booms, possible damage to structures (particularly brittle objects like older windows) and potential adverse effects on domestic and wild animals. ... Sonic booms under the Proposed Action are not expected to damage viable structures, such as foundations, buildings, windmills, radio towers, or water tanks. ... Not all structures are in good condition. Brittle elements such as windows and plaster can weaken with age, and become susceptible to breakage at low boom levels. ... Nonetheless, the presence of susceptible structures, for whatever reason, means that some damage attributable to sonic booms is to be expected. ... Short-term reactions to new noises may include temporary shifts in habitat use or activities. For example, prairie dogs and swift foxes might spend more time in their burrows, where they would be somewhat insulated from noises (Francine et al. 1995). Lesser prairie-chickens are known to cease lekking activities for several minutes to several hours in response to noise disturbances (Giesen and Connelly 1993); therefore, a sudden onset low-level noise event from an aircraft overflight could disturb lekking prairie-chickens. ... Under the Proposed Action, a greater number of sorties would include supersonic flight and supersonic flight would occur at lower altitudes than under existing conditions. Consequently, animals would be exposed to louder noise levels from sonic booms than they are at present. ... Several special-status species are rare in New Mexico, but could be present during spring and fall migration, particularly along the Pecos River (NMDGF 2002a, 2002b). These are brown pelican, piping plover, mountain plover, black tern (Chlidonias niger), interior least tern, peregrine falcon, bald eagle, and Baird’s sparrow. These temporary visitors may not be habituated to aircraft noise. Migrating birds require quality stopover habitat to rest and eat. Noise disturbance, therefore, could cause individual special-status birds and other migratory birds (e.g., ducks and geese) to leave their stopover area prematurely. However, negative impacts to special-status populations would not be expected. ... Wintering bald eagles are sensitive to noise disturbance (Grubb and King 1991) and may be disturbed by aircraft noise However, because of the short duration of a noise event occurring at a particular location on the ground, any resulting physiological or behavioral disturbance would be short-lived. ... Noise from supersonic flight would increase in all parts of the airspace, but at levels that would not be expected to significantly impact biological resources. Resident wild animals and livestock experiencing new noise levels may initially experience negative effects and may temporarily shift habitat use or activities as a result (Harrington and Veitch 1991). ... Under the Proposed Action, the number of supersonic events throughout the airspace would increase relative to current conditions. Supersonic flights at 10,000 feet MSL could increase the frequency and intensity of sonic booms. ... The proposed MOA expansions and new airspace would not prohibit general aviation use. MOAs are joint use airspace and both military and civil pilots are required to operate under see-and-avoid rules of flight. Clearly, see-and-avoid failed to separate military and civil aircraft at _subsonic_ speeds in these military-civil mishaps: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2 That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Other socioeconomic factors, such as business activity, employment, interest rates, and land scarcity (or availability) are much more likely to affect property values than an altitude redistribution of flight pattern changes in existing training aircraft overflights. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? The New Mexico Air National Guard (NMANG) is proposing to create the Smitty MOA underneath the current CATO MOA, which is 60 miles southwest of Albuquerque. An EA analyzing this action is underway. Creation of this new MOA would not affect Cannon AFB or its airspace Is this yet another attempted military airspace grab? |
On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera
wrote: I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. The numbers might confirm the contention that flying high performance tactical aircraft is somewhat dangerous and therefore some airspace reservation is a good idea. IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. Look out the window and don't bump into things in front of you. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. The existing Pecos MOA complex would be expanded laterally and vertically under the Proposed Action. The MOAs would be expanded laterally to conform with the lateral boundaries of the ATCAA overlying the complex. This expansion would include a southerly expansion of the Pecos South Low MOA, thus adding additional low altitude military airspace in that region (down to 500 feet AGL). Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. The proposed MOA expansions and new airspace would not prohibit general aviation use. MOAs are joint use airspace and both military and civil pilots are required to operate under see-and-avoid rules of flight. Clearly, see-and-avoid failed to separate military and civil aircraft at _subsonic_ speeds in these military-civil mishaps: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2 That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Corrective action to eliminate those accidents in the future is part of the process. The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. Other socioeconomic factors, such as business activity, employment, interest rates, and land scarcity (or availability) are much more likely to affect property values than an altitude redistribution of flight pattern changes in existing training aircraft overflights. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? For aircraft the size of F-16s, sonic booms above 30,000 feet are usually not heard on the surface. That's why most supersonic airspace in the US is at high altitudes. The New Mexico Air National Guard (NMANG) is proposing to create the Smitty MOA underneath the current CATO MOA, which is 60 miles southwest of Albuquerque. An EA analyzing this action is underway. Creation of this new MOA would not affect Cannon AFB or its airspace Is this yet another attempted military airspace grab? Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
Much as it pains me to agree with a fighter dood, I have to go along with that remark. Dick Former MATS/MAC AC |
On 16 Feb 2005 12:39:23 -0800, "Dick L." wrote
in . com:: Oh, and lest I forget....screw you, Larry. You're clueless. Much as it pains me to agree with a fighter dood, I have to go along with that remark. Dick Former MATS/MAC AC I'll take your agreement with Ed's remark as an admission, that you have no valid argument to present on the subject proposed MOA expansion. |
On Wed, 16 Feb 2005 12:43:05 -0700, Ed Rasimus
wrote in :: On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera wrote: In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The USAF's statement regarding claims procedures for "damage due to Air Force activity" is probably inadequate to replace Ms. Oliveier's late husband. The November 16, 2000 fatal F-16/Cessna 172 MAC occurred at 3,000' at subsonic speed. I believe the expansion of the MOA relates to low-level supersonic military operations within "5,000 to 6,000 feet above ground level (AGL)". These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, Perhaps you'll be good enough to assist me in calculating the number of F-16C non-combat mishaps per month given the USAF's statement, that 120 Class A mishaps have occurred to date (Jan. 2005) since the 1985 Fiscal Year. but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. Be that as it may, I was commenting on the number of F-16C non-combat mishaps per month. The numbers might confirm the contention that flying high performance tactical aircraft is somewhat dangerous and therefore some airspace reservation is a good idea. I agree, that it tends to confirm the danger involved in flying USAF F-16C's in a non-combat environment. Whether or not additional reserved airspace for low-level supersonic military operations will improved the F-16C's non-combat Class A bimonthly mishap rate is a speculative matter at best. IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Yes. It is the 'law' of VFR operations, however in this case it was suggested as a _viable_ means of transiting the proposed MOA while low-level supersonic military operations are in progress! Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. The NAS is a system. As such, it is dependent on each aspect of its implementation to be functional in order for the whole to function properly. FARs are part of that system. The prohibiting of flight in excess of 250 knots below 10,000 feet is a FAR. The military has exploited the "SPEED AUTHORIZATION GRANTED TO DOD May 18, 1978" which states: The regulation grants an exception to aircraft having flight characteristics which preclude safe operation at speeds below 250 knots by providing that if the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed, the aircraft may be operated at that minimum safe airspeed. When the speed of aircraft below 10,000 feet exceeds 250 knots as mandated by FAR § 91.117(a)*, the integrity of the NAS is compromised as evidenced by at least two of the three military/civil mishaps, and corroborated by the military's own study which concluded, that out of each 20 seconds of flight below 250 knots, 17 seconds must be dedicated to scanning for conflicting traffic and 3 seconds remained for scanning cockpit gages; this was for "highly trained" military pilots. So it is evident that see-and-avoid is completely impracticable for maintaining aircraft separation when aircraft are traveling in excess of Mach one. * http://ecfr.gpoaccess.gov/cgi/t/text....2.4.9&idno=14 Look out the window and don't bump into things in front of you. Oh, if it were only so simple. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. Of course, the military has found a way around that speed restriction. (see above) The existing Pecos MOA complex would be expanded laterally and vertically under the Proposed Action. The MOAs would be expanded laterally to conform with the lateral boundaries of the ATCAA overlying the complex. This expansion would include a southerly expansion of the Pecos South Low MOA, thus adding additional low altitude military airspace in that region (down to 500 feet AGL). Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. If there are so many adjustments occurring, it should be easy to provide several examples of _reductions_ in military airspace, please. The proposed MOA expansions and new airspace would not prohibit general aviation use. MOAs are joint use airspace and both military and civil pilots are required to operate under see-and-avoid rules of flight. Clearly, see-and-avoid failed to separate military and civil aircraft at _subsonic_ speeds in these military-civil mishaps: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 http://www.ntsb.gov/ntsb/GenPDF.asp?...1FA028A&rpt=fi http://www.ntsb.gov/ntsb/brief.asp?e...26X00109&key=2 That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. That may be due to the relative number of aircraft and the number of operational hours between the military and civil fleets. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Actually, the same thing occurs for civil mishaps; the NTSB finds and reports probable cause. The specific action taken by the FAA against a civil pilot is a matter of public record. Here's what occurred in the case of the November 16, 2000 fatal MAC in Florida: Air Force officials said the mistakes [sic] Lt. Col. Parker made leading up to the crash over Manatee County deserved only "administrative action" — a written or verbal reprimand. He will also retain his officer's pension. The decision regarding Parker was made by Brig. Gen. John Rosa, commander of Moody Air Force Base in south Georgia, where the F-16 pilots were stationed at the time of the crash. Citing confidentiality laws, Air Force officials would not elaborate on what form of administrative action was taken. They also would not say which of the mistakes he made the day of the crash led to the reprimand, the Sarasota Herald-Tribune reported... -- Associated Press Corrective action to eliminate those accidents in the future is part of the process. Well, at least the USAF tries to give the impression that that occurs: Thursday, June 21, 2001 Associated Press BRADENTON — Military aircraft on low-level training missions in civilian air space should fly at the slowest possible speed, the Air Force says following an F-16 crash that killed a civilian pilot. The Air Force has updated flight manuals and safety procedures on high-speed, low-altitude flights after reviewing the collision of the F-16 Fighting Falcon and a Cessna 172 over Manatee County on Nov. 16, military officials said Tuesday. Pilots on training maneuvers in civilian air space now are required to fly at the slowest possible speed although not less than 250 knots, or 287.5 miles per hour. In an official review of the crash, released in March, the Air Force downplayed the F-16's 480 mph speed as a factor. The pilot was flying 180 mph faster than federal and Air Force guidelines then allowed for military jets in air space near Sarasota-Bradenton International Airport. The updates are written in general terms and refer to slowing the aircraft and reviewing training routes near congested flying areas. The report, overseen and released by Air Force Chief of Staff Gen. Michael Ryan, comes more than seven months after the F-16, flown by Capt. Greg Kreuder, collided with the Cessna, killing its pilot, Jacques Olivier, 57, a [ATP rated] flight instructor from Hernando County. "We can't speculate on whether these recommendations would have affected the outcome of the crash had they already been in place," said Air Force spokeswoman Maj. Cheryl Law. "We always consider safety as our highest priority." ... The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. When the government perpetrates injustice, it is the prerogative of a citizen of a free nation to publicly air his views. I believe I have provided evidence of reasonable background knowledge, and haven't seen any alternative "pronouncements" to which you refer. Other socioeconomic factors, such as business activity, employment, interest rates, and land scarcity (or availability) are much more likely to affect property values than an altitude redistribution of flight pattern changes in existing training aircraft overflights. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? For aircraft the size of F-16s, sonic booms above 30,000 feet are usually not heard on the surface. That's why most supersonic airspace in the US is at high altitudes. The proposed MOA enlargement is to permit supersonic operations at between 5,000' and 6,000' as stated in the USAF EIS. Why are you referring to 30,000' feet? That is the current, not proposed, altitude floor in the MOA for supersonic operations. The New Mexico Air National Guard (NMANG) is proposing to create the Smitty MOA underneath the current CATO MOA, which is 60 miles southwest of Albuquerque. An EA analyzing this action is underway. Creation of this new MOA would not affect Cannon AFB or its airspace Is this yet another attempted military airspace grab? Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Well, it would appear one of us is. But at least I'm not forced to profane a fellow airman due to lack of reasonable arguments. Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Piloting | 12 | April 26th 04 06:12 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
