On Wed, 16 Feb 2005 22:02:08 GMT, Larry Dighera
wrote: On Wed, 16 Feb 2005 12:43:05 -0700, Ed Rasimus wrote in :: On Wed, 16 Feb 2005 17:50:56 GMT, Larry Dighera wrote: In the unlikely event of property damage due to an Air Force activity, the Air Force has established procedures for damage claims. I'm sure that is a great comfort to Ms. Jacques Olivier and her daughter: http://www.ntsb.gov/ntsb/brief.asp?e...12X22313&key=1 How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The USAF's statement regarding claims procedures for "damage due to Air Force activity" is probably inadequate to replace Ms. Oliveier's late husband. And, your arguments citing a mishap in Florida relating to a MOA change in New Mexico are inadequate to address the training requirements of combat forces in high performance tactical jet aircraft. I'm deeply sympathetic to Ms Olivier or Oliveier, but I'm also sympathetic to the surviving wives and families of quite literally hundreds of USAF, USN and USMC tactical aviators who died or were imprisoned when lost in military flight operations in the service of their country. The November 16, 2000 fatal F-16/Cessna 172 MAC occurred at 3,000' at subsonic speed. I believe the expansion of the MOA relates to low-level supersonic military operations within "5,000 to 6,000 feet above ground level (AGL)". So, creating a MOA which would advise all aircraft operators of the intended operations would not be as good as operating in non-special use airspace as was being done in the Florida accident? These mishap rates do not consider combat losses due to enemy action. F-16C aircraft have flown more than 3,336,700 hours since the aircraft entered the Air Force inventory during Fiscal Year 1985. Over that period, 120 Class A mishaps have occurred and 113 aircraft have been destroyed. That would be an average of one F-16C non-combat Class A mishap every two months! Dunno about your math skills here, Perhaps you'll be good enough to assist me in calculating the number of F-16C non-combat mishaps per month given the USAF's statement, that 120 Class A mishaps have occurred to date (Jan. 2005) since the 1985 Fiscal Year. My point was that 3.3 MILLION hours per 120 mishaps (which aren't all mid-airs or even aircraft losses and which didn't all occur in special sue airspace) is a statistic that is better viewed as mishaps/100k flight hours rather than mishaps/month. but I just read about 120 class A mishaps during the period from FY 1985 to the present--that's a bit more than 20 years of experience and doesn't begin to address rates per 100,000 flying hours which for the F-16 (all models) are significantly lower than previous single-seat, single-engine tactical aircraft. Be that as it may, I was commenting on the number of F-16C non-combat mishaps per month. Which means what relative to training airspace in NM? The numbers might confirm the contention that flying high performance tactical aircraft is somewhat dangerous and therefore some airspace reservation is a good idea. I agree, that it tends to confirm the danger involved in flying USAF F-16C's in a non-combat environment. In ANY environment. Whether or not additional reserved airspace for low-level supersonic military operations will improved the F-16C's non-combat Class A bimonthly mishap rate is a speculative matter at best. Precisely! The mishap rate and the need for training airspace are not related to each other! IFR traffic would require ATC clearance to transit the active MOA. However, VFR traffic could transit the active MOA using the “see-and-avoid” concept. The USAF's suggestion that VFR traffic employ see-and-avoid techniques to avoid mid-air collisions with supersonic military fighter aircraft reveals a their desire to mislead. It isn't "the USAF's suggestion", it is the basic concept of Visual Flight Rules. Yes. It is the 'law' of VFR operations, however in this case it was suggested as a _viable_ means of transiting the proposed MOA while low-level supersonic military operations are in progress! First, note that the tactical applicability of supersonic operations at high or low altitude is very limited. Second, note that most PLANNED supersonic operation is done at high altitude, such as high-speed intercept training. Third, note that UNPLANNED supersonic operation can occur momentarily during air combat maneuver/BFM training and that might be at relatively low altitude (although most tactical training employs a 10k or 5k AGL "floor"). Fourth, note that most training in which supersonic operations are planned or highly likely will be conducted in restricted airspace rather than MOA. Fifth, note that transiting of MOAs by VFR traffic while allowed is discourage; by IFR traffic is not allowed when the MOA is in use. Nothing misleading about it--the idea of VFR is to provide simple rules for flight in VISUAL conditions and without need for a flight plan or clearance or external third-party deconfliction. The NAS is a system. As such, it is dependent on each aspect of its implementation to be functional in order for the whole to function properly. FARs are part of that system. The prohibiting of flight in excess of 250 knots below 10,000 feet is a FAR. The military has exploited the "SPEED AUTHORIZATION GRANTED TO DOD May 18, 1978" which states: The regulation grants an exception to aircraft having flight characteristics which preclude safe operation at speeds below 250 knots by providing that if the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed, the aircraft may be operated at that minimum safe airspeed. When the speed of aircraft below 10,000 feet exceeds 250 knots as mandated by FAR § 91.117(a)*, the integrity of the NAS is compromised as evidenced by at least two of the three military/civil mishaps, and corroborated by the military's own study which concluded, that out of each 20 seconds of flight below 250 knots, 17 seconds must be dedicated to scanning for conflicting traffic and 3 seconds remained for scanning cockpit gages; this was for "highly trained" military pilots. So it is evident that see-and-avoid is completely impracticable for maintaining aircraft separation when aircraft are traveling in excess of Mach one. You confirm my asssertion of cluelessness. Some military aircraft don't function very well at 250 KIAS unless in landing configuration. They burn fuel at high rates and are restricted in their agility. For that reason the FARs have waivered the 250 max exactly for the reason you quote "minimum SAFE airspseed". Let's take this to an example you are probably more familiar with: driving your car. How much time when driving do you spend looking out the window versus staring at your speedometer? Ditto for airplanes. Look out the window and don't bump into things in front of you. Oh, if it were only so simple. Don't knock it if you haven't tried it. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. Of course, the military has found a way around that speed restriction. (see above) And, you can take it to the bank that they will continue to do so. Is that an additional airspace grab? "Additional"? If there were not similar airspace adjustments going on all the time with both increases and reductions in airspace. If there are so many adjustments occurring, it should be easy to provide several examples of _reductions_ in military airspace, please. Did you read previous posts? Walker AFB, Roswell NM. Williams AFB, Chandler AZ. Webb AFB, Big Spring TX. Wendover AFB, Wendover UT. Wurtsmith AFB....and those are just W's--all closed within the last 30 years, all with airspace which was no longer needed. That the USAF can muster the audacity to suggest that see-and-avoid would be a successful technique for separating _supersonic_ aircraft is hubris beyond comprehension. Guess what? Civilian aircraft operating under "see-and-avoid" run into each other at subsonic speeds with much greater frequency. That may be due to the relative number of aircraft and the number of operational hours between the military and civil fleets. And, it may even be due to private pilots being clueless about where they are. Or maybe they are talking on their cell phones. And, when the military is involved in any mishap an investigation is conducted, reported in the public domain and blame is assigned. Actually, the same thing occurs for civil mishaps; the NTSB finds and reports probable cause. The specific action taken by the FAA against a civil pilot is a matter of public record. Here's what occurred in the case of the November 16, 2000 fatal MAC in Florida: Air Force officials said the mistakes [sic] Lt. Col. Parker made leading up to the crash over Manatee County deserved only "administrative action" — a written or verbal reprimand. He will also retain his officer's pension. The decision regarding Parker was made by Brig. Gen. John Rosa, commander of Moody Air Force Base in south Georgia, where the F-16 pilots were stationed at the time of the crash. Citing confidentiality laws, Air Force officials would not elaborate on what form of administrative action was taken. They also would not say which of the mistakes he made the day of the crash led to the reprimand, the Sarasota Herald-Tribune reported... -- Associated Press If you read the accident report you would find a clear detailing of the "mistakes" and you would learn whether they were primary, secondary or lesser causes. As for the "administrative action" it could range from corrective training to removal from flight status to loss of pay to mandatory retirement. But, the mere fact that he didn't have his sword broken, his buttons cut off and his epaulets removed before hanging in the public square MIGHT mean he wasn't guilty of anything significant! The "hubris beyond comprehension" here is your flogging of the issue with little apparent background and a total unwillingness to acknowledge any of the alternatives to your pronouncements. When the government perpetrates injustice, it is the prerogative of a citizen of a free nation to publicly air his views. I believe I have provided evidence of reasonable background knowledge, and haven't seen any alternative "pronouncements" to which you refer. Injustice? Going through a public hearing process before designating special use airspace is now "injustice"? And, reread my sentence above: "unwillingness to acknowledge any of the alternatives to your pronouncements"--that's not "alternative 'prounouncement'". Posters have given you blocks of information regarding special use airspace refuting your basic position opposing expansion of the MOA. You continue to throw stuff at the wall hoping that some sticks, regardless of relevance. What of the reduction of property values do supersonic military aircraft operations above 30,000' feet over the affected area? For aircraft the size of F-16s, sonic booms above 30,000 feet are usually not heard on the surface. That's why most supersonic airspace in the US is at high altitudes. The proposed MOA enlargement is to permit supersonic operations at between 5,000' and 6,000' as stated in the USAF EIS. Why are you referring to 30,000' feet? That is the current, not proposed, altitude floor in the MOA for supersonic operations. I'm referring to 30,000 feet BECAUSE YOU REFERRED TO 30,000 FEET!!!!! That's YOUR quote above mine. Oh, and lest I forget....screw you, Larry. You're clueless. Ed Rasimus Well, it would appear one of us is. But at least I'm not forced to profane a fellow airman due to lack of reasonable arguments. Excuse me? I've got more time in the Beak MOA inverted than you've apparently got in military jets. And, if you've missed my presentation of "reasonable arguments" you can't read. Oh, and "screw you" isn't profaning you, it's exercising restraint despite the frustration at your apparent inability to make any sense of all of this. If you want profaning of "a fellow airman", I suggest you scan recent posts from Dudley--he's proven a master at it. But, I can stoop if need be. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
"Ed Rasimus" wrote in message ... How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The Florida midair did not occur on a low-level training route. You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. That's not correct. Aircraft below 10,000 feet MSL cannot exceed 250 KIAS unless the minimum safe airspeed for any particular operation is greater than that speed, the aircraft may then be operated at that minimum speed. |
On Sat, 19 Feb 2005 20:43:01 GMT, "Steven P. McNicoll"
wrote: "Ed Rasimus" wrote in message .. . How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The Florida midair did not occur on a low-level training route. It didn't occur in a MOA, didn't involve supersonic operations, and, the incident is not relevant to the discussion of the proposed changes to airspace in New Mexico were my points. You are correct, the midair did not take place on an LLN route. Feel better now? You might also note that aircraft below 10,000 MSL (except in some special use airspace) is already restricted to airspeeds below 250 KIAS. That's not correct. Aircraft below 10,000 feet MSL cannot exceed 250 KIAS unless the minimum safe airspeed for any particular operation is greater than that speed, the aircraft may then be operated at that minimum speed. You're entering this a bit late. Your additional phrase regarding operational necessity has been discussed in some detail here. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
wrote in et:: "Ed Rasimus" wrote in message .. . How does expansion of a MOA for operations above 10,000 feet in New Mexico relate to a mid-air collision in Florida on a low-level training route? The Florida midair did not occur on a low-level training route. He didn't say it did. It occurred in Class C airspace en route to a MTR. |
"Larry Dighera" wrote in message ... Does the military _ever_ return its airspace to public use? Sure, every time they cease using it. ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. About 40 civilian flights per day would require rerouting? I wonder how that was determined? "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. Dangerous? How so? Safety is the reason SUA is established, to either separate nonparticipating aircraft from hazardous activities or to warn them of potential hazards. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." Perhaps, but giving the area alone makes it appear bigger. |
Larry Dighera wrote: Does the military _ever_ return its airspace to public use? ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." http://www.avweb.com/eletter/archive...ll.html#189168 I have to add an international flavour (flavor) to this disucssion of controlled airspace. http://www.caa.co.uk/docs/7/DAP_EIS03.pdf (Somewhere beneath the mishmash of controlled airspace depicted on page 2 of the document apparently lies a map of the UK) And another showing low level military flying areas: http://www.mod.uk/linked_files/uk_lfas.gif Did a lot of flying in CO and NM I think you've got it easy! Best wishes David |
On Wed, 16 Feb 2005 12:41:48 GMT, Larry Dighera
wrote: On 16 Feb 2005 01:52:38 -0800, wrote in s.com:: Larry Dighera wrote: Does the military _ever_ return its airspace to public use? ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." http://www.avweb.com/eletter/archive...ll.html#189168 I have to add an international flavour (flavor) to this disucssion of controlled airspace. http://www.caa.co.uk/docs/7/DAP_EIS03.pdf (Somewhere beneath the mishmash of controlled airspace depicted on page 2 of the document apparently lies a map of the UK) Most of Europe operates under a combination of (maybe it's changed since I was in the business, but I doubt it), OAT "Operational Air Traffic" and GAT "General Air Traffic" control. This means there are two over-lapping (and hence competing) systems of air traffic control with regulations, airspace, controllers, radars, etc. On the one hand, it helps the military get the mission done, on the other, it makes GA flying a bit more complicated for the little guy. The airlines aren't much impacted. That's interesting. Virtually the entire US lies under controlled airspace; there is very little Class G. That's true, but don't confuse that "controlled airspace" with special use airspace or military requirement. "Area positive control" is the airspace above a certain altitude MSL that is ALL controlled airspace meaning you can only enter if on an IFR flight plan. So, no VFR there, but it ISN'T military special use. And another showing low level military flying areas: http://www.mod.uk/linked_files/uk_lfas.gif Given the current trend, I would expect the US to be totally blanketed with military airspace, like the UK appears to be, if the military thought they could get away with it. Dare I suggest a bit of inflammatory hyperbole there? We've already pointed out that with the reduction of military installation in the last thirty years there have been huge cancellations and eliminations of no-longer needed military airspace. And, we've also discussed at great length the fairly easy accessibility of a lot of airspace which is designated special use, but open when not active. What parts of this have you not understood? Did a lot of flying in CO and NM I think you've got it easy! Absolutely! Big sky theory applies. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
Ed Rasimus wrote: On Wed, 16 Feb 2005 12:41:48 GMT, Larry Dighera wrote: On 16 Feb 2005 01:52:38 -0800, wrote in s.com:: Larry Dighera wrote: Does the military _ever_ return its airspace to public use? ------------------------------------------------------------------- AVflash Volume 11, Number 7a -- February 14, 2005 ------------------------------------------------------------------- GA PILOTS TAKE ON MILITARY IN N.M. New Mexico has some wide-open skies, but apparently there is not enough room there for all the military and civilian pilots who want to fly. The U.S. Air Force wants to add 700 square miles to the 2,600 square miles now used by the F-16 Falcons based at Cannon Air Force Base. The airspace expansion would mean rerouting about 40 civilian flights per day, and intrude onto GA routes between Albuquerque and Roswell. "They've grabbed up so much airspace, it's going to be dangerous for small, civilian aircraft," U.S. Pilots Association President Steve Uslan told The Albuquerque Journal. "And that's a long way around, and that means a lot of fuel and a lot of time wasted." http://www.avweb.com/eletter/archive...ll.html#189168 I have to add an international flavour (flavor) to this disucssion of controlled airspace. http://www.caa.co.uk/docs/7/DAP_EIS03.pdf (Somewhere beneath the mishmash of controlled airspace depicted on page 2 of the document apparently lies a map of the UK) Most of Europe operates under a combination of (maybe it's changed since I was in the business, but I doubt it), OAT "Operational Air Traffic" and GAT "General Air Traffic" control. This means there are two over-lapping (and hence competing) systems of air traffic control with regulations, airspace, controllers, radars, etc. On the one hand, it helps the military get the mission done, on the other, it makes GA flying a bit more complicated for the little guy. The airlines aren't much impacted. That's interesting. Virtually the entire US lies under controlled airspace; there is very little Class G. That's true, but don't confuse that "controlled airspace" with special use airspace or military requirement. "Area positive control" is the airspace above a certain altitude MSL that is ALL controlled airspace meaning you can only enter if on an IFR flight plan. So, no VFR there, but it ISN'T military special use. And another showing low level military flying areas: http://www.mod.uk/linked_files/uk_lfas.gif Given the current trend, I would expect the US to be totally blanketed with military airspace, like the UK appears to be, if the military thought they could get away with it. Dare I suggest a bit of inflammatory hyperbole there? We've already pointed out that with the reduction of military installation in the last thirty years there have been huge cancellations and eliminations of no-longer needed military airspace. And, we've also discussed at great length the fairly easy accessibility of a lot of airspace which is designated special use, but open when not active. What parts of this have you not understood? Did a lot of flying in CO and NM I think you've got it easy! Absolutely! Big sky theory applies. and long may it continue! David |
wrote and long may it continue! David Please, please, take the time to snip out most of the preceding post. Failing to do so is very rude. -- Jim in NC |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Piloting | 12 | April 26th 04 07:12 PM |
| bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 05:26 PM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
