Cub Driver wrote:
Since I had to get a SODA to fly with monocular vision (left eye blind for all practical purposes), I have to believe that a deaf pilot also has a SODA, and that it restricts what airspace he can enter. My club has two of our aircraft at an untowered airport, which is a little unusual around here. As a result, we entertained a deaf pilot considering membership a number of months ago. Actually, it was more the other way around. He spoke to us (through a sign interpreter) about his unique experiences. My understanding is that an instrument rating and such is an impossibility for him, and that he is restricted - as you suggested - to airspace which doesn't require communication. I don't whether anyone thought to ask whether he could fly into class D airspace given the proper light-gun signals. But given the frequency of clubs at class D airports around here, I'd have to guess "not". BTW, I recently spoke to another pilot that used a hearing aid. I was surprised to hear that he cannot pass a class two physical. Apparently, while it is permissible to require corrected vision, corrected hearing is not permissible. Anyone know why? Is it the electronic/powered nature of the correction? Something else? - Andrew |
![]() "Steve R." wrote in message ... That's for communications with the control tower at a controlled field airport, not ATC! It's not ATC that staffs control towers? Maybe, Maybe it's not ATC that staffs control towers? Who do you think staffs them? but if the guy is 20 miles out and needing clearance to enter the airport traffic area, he's not going to be able to "see" the signal lights very well, is he? What is this airport traffic area that requires clearance to enter at 20 miles out? What if he needs to transit a Class B airspace to get to the controlled field? Then he's almost certainly outta luck. ATC must separate all traffic in Class B airspace and it's rather hard to do that without communications. If he can't hear, he can't communicate with ATC, thus, he can't get clearance. I've got to wonder if this one isn't a scam. The question was, "How does one communicate with ATC when one is deaf?" It's a simple question. One CAN use light gun signals. Can you think of any others? Incidentally, there was a time when most aircraft had no radios and light gun signals were the main form of pilot/controller communications at towered fields. Signal lights are for short range, visual communications and there's no use for them outside the airport traffic area. That's all true. So what's your point? Incidentally, we haven't had Airport Traffic Areas in the US for almost eleven years now. |
When a private company like Phillips Petroleum operates the control tower is
it still considered a control tower? They offer advisories but caution you they are not controlling traffic at Bartlesville, Oklahoma. Neither are they part of ATC, however they will open and close clearances as a courtesy. Things may have changed because I haven't been there in a while, but there are still privately operated towers around the country aren't there? -- Jim Carter "Steven P. McNicoll" wrote in message nk.net... "Steve R." wrote in message ... That's for communications with the control tower at a controlled field airport, not ATC! It's not ATC that staffs control towers? Maybe, Maybe it's not ATC that staffs control towers? Who do you think staffs them? but if the guy is 20 miles out and needing clearance to enter the airport traffic area, he's not going to be able to "see" the signal lights very well, is he? What is this airport traffic area that requires clearance to enter at 20 miles out? What if he needs to transit a Class B airspace to get to the controlled field? Then he's almost certainly outta luck. ATC must separate all traffic in Class B airspace and it's rather hard to do that without communications. If he can't hear, he can't communicate with ATC, thus, he can't get clearance. I've got to wonder if this one isn't a scam. The question was, "How does one communicate with ATC when one is deaf?" It's a simple question. One CAN use light gun signals. Can you think of any others? Incidentally, there was a time when most aircraft had no radios and light gun signals were the main form of pilot/controller communications at towered fields. Signal lights are for short range, visual communications and there's no use for them outside the airport traffic area. That's all true. So what's your point? Incidentally, we haven't had Airport Traffic Areas in the US for almost eleven years now. |
![]() "Jim Carter" wrote in message ... When a private company like Phillips Petroleum operates the control tower is it still considered a control tower? Yes. There are many Non Federal Control Towers and FAA Contract Towers in the US operated by private companies. They follow the same rules as FAA and military towers, their controllers are issued a Control Tower Operator certificate by the FAA. They offer advisories but caution you they are not controlling traffic at Bartlesville, Oklahoma. Neither are they part of ATC, however they will open and close clearances as a courtesy. Things may have changed because I haven't been there in a while, but there are still privately operated towers around the country aren't there? If they don't control traffic it's not a control tower, for that's what control towers do. From the Pilot/Controller Glossary: TOWER- A terminal facility that uses air/ground communications, visual signaling, and other devices to provide ATC services to aircraft operating in the vicinity of an airport or on the movement area. Authorizes aircraft to land or takeoff at the airport controlled by the tower or to transit the Class D airspace area regardless of flight plan or weather conditions (IFR or VFR). A tower may also provide approach control services (radar or nonradar). The link below will open to a portion of the Kansas City Sectional showing Bartlesville. Bartlesville Municipal Airport is depicted as a nontowered field. http://makeashorterlink.com/?I11143169 |
"Steven P. McNicoll" wrote in message ink.net... "Steve R." wrote in message ... How does one communicate with ATC when one is deaf? Via light gun signals. That's for communications with the control tower at a controlled field airport, not ATC! It's not ATC that staffs control towers? Maybe, but if the guy is 20 miles out and needing clearance to enter the airport traffic area, he's not going to be able to "see" the signal lights very well, is he? What if he needs to transit a Class B airspace to get to the controlled field? If he can't hear, he can't communicate with ATC, thus, he can't get clearance. I've got to wonder if this one isn't a scam. Signal lights are for short range, visual communications and there's no use for them outside the airport traffic area. From a practical matter, how does the deaf pilot report 10 miles out without steeping on other transmissions? Is there a device for this? -Robert |
"Steven P. McNicoll" wrote in message link.net...
"bryan chaisone" wrote in message om... How does one communicate with ATC when one is deaf? Via light gun signals. I thought the medical exemption for deaf pilots stipulated no flight when communication with ATC is required. -Robert |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore | Otis Willie | Military Aviation | 2 | February 22nd 04 03:33 AM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Wm Buckley on John Kerry | Big John | Piloting | 22 | February 7th 04 02:19 AM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
