On 17 Aug 2003 17:12:58 GMT, Ian Cant
wrote: Martin,=20 I just can't resist a good argument. Sorry, but your vector diagram as described gives AOA with sign = reversed. I must respectfully disagree. If you fly into a rising airmass from a neutral or sinking one your instantaneous sinking speed is reduced by the vertical velocity of the new air mass - hence the reduced AOA. On encountering a rising airmass from stabilized flight, the = instantaneous effect is an increase in AOA - the relative wind that was = flowing from straight ahead is now flowing from ahead and below. This = increase in AOA gives added lift at the wing and reduced pushdown at the = tail. Since the CG is ahead of both CL and tail, both give a nosedown = moment. The aircraft attitude is disturbed and it pitches nosedown. Errrm. The CG may be ahead if the wing's CL, but it certainly is not ahead of the CL of the entire aircraft: if that was the case you'd soon be flying vertically downward! An aircraft operating at its trimmed speed in still air has no pitching moment about its CG. However, the CG is certainly ahead of the NP (Neutral Point [1]) by the MSS (Margin of Static Stability) and this must be so for stable flight. The size of the MSS controls the rate of oscillation after disturbance: too small MSS and recovery tends to deadbeat or no recovery (unstable) and to large MSS can cause oscillation and divergent behaviour. This is true for both aircraft with download on the tail (most manned aircraft) and free flight duration models, which usually have a lifting tail and rearward CG. A lifting tail may be unsuitable for a manned plane but as a way of getting minimum sink from a fixed speed, fixed trim unmanned aircraft its the best. However, the same NP stability calculations apply to both of these - and to canards and flying wings. Now the inherent stability starts to work through a series of = transients. The pitch down reduces the AOA and the aircraft accelerates = because the gravity vector is closer to where the nose is now pointing. = The reduced AOA and the increased drag gradually restore the aircraft to = its original stable attitude [maybe after a few oscillations, it is far = from a deadbeat system] and sink rate through the airmass. The final = result is an aircraft flying at exactly the same attitude, speed, L/D = etc in the new airmass, but with a sink rate relative to the ground = equal to the old value less the upward velocity of the new airmass. Agree with your conclusion, just can't help nitpicking the argument.. Going back to the original question, whether to fly constant speed or = constant attitude, both are difficult to achieve when hit by a gust. = But if you are skilful enough to stop the nose drop then your attitude = will remain constant and your speed will also be constant if the gust is = vertical. If the gust is horizontal, there wil be relatively little = change in AOA but an increase/decrease in total energy will be reflected = in the vario and your airspeed will change. Holding attitude will let = the aircraft stabilize itself, but trying to regain airspeed is a better = bet. If the gust gives a speed increase, a little nose up will turn = your inertia into more altitude sooner, and if the gust gives a speed = decrease you might want to nose down a little to avoid a wind-shear = stall situation. In my case, gusts are always some unknown combination of vertical and = horizontal, and my reactions are too slow to hold anything truly = constant... Agreed, but we can work on it. :-) One of the neatest demonstrations I've seen of vertical vector addition is when, running a cloud street, you meet a region where the vertical air velocity increases steadily over a relatively long distance and you can continue to cruise for a surprisingly long time while climbing with nose-high attitude and constant airspeed: certainly long enough to look round and see your tailplane is on the horizon - in a Pegasus that means at least 5 degrees of pitch up. Ain't gliding fun! [1] The NP is Lw * Mw - Lt * Mt = 0 at the current trim condition where Lw = lift from the wing Mw = moment from wing CL to the NP Lt = lift from tail Mt = moment from tail CL to the NP Free Flight model designers tend to think of the NP as a fixed point because they always design for the minimum sinking speed (FF is a pure duration contest, remember) but it isn't - in reality its trim dependent and so will move with the trimmed airspeed. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
On Sun, 17 Aug 2003 21:34:19 +0100, Martin Gregorie
wrote: On 17 Aug 2003 17:12:58 GMT, Ian Cant wrote: Martin,=20 I just can't resist a good argument. Sorry, but your vector diagram as described gives AOA with sign = reversed. I must respectfully disagree. If you fly into a rising airmass from a neutral or sinking one your instantaneous sinking speed is reduced by the vertical velocity of the new air mass - hence the reduced AOA. Not so at the instant the airmass is entered. After some time - about 0.75 to 2.5 seconds the glider will be close enough to equilibrium in the new airmass. On encountering a rising airmass from stabilized flight, the = instantaneous effect is an increase in AOA - the relative wind that was = flowing from straight ahead is now flowing from ahead and below. This = increase in AOA gives added lift at the wing and reduced pushdown at the = tail. Since the CG is ahead of both CL and tail, both give a nosedown = moment. The aircraft attitude is disturbed and it pitches nosedown. If like most sailplanes the longitudinal stability isn't excessive this effect may not be all that large but yes the glider will tend to align itself with the local airflow but this effect only lasts for a short time. This can also be masked by mass balancing or lack thereof in the elevator control system, not just the elevator and how hard you are holding on to the stick. In any case you are probably going to try to hold the attitude constant unless you are cruising at high speed and decide to take the thermal. I seem to remember the SB13 flying wing had a problem with this when first flown at forward C of G. The low moment of inertia in pitch resulted in unpleasant characteristics as the glider flew through lift and sink. Mike Borgelt |
At 15:54 19 August 2003, Finbar wrote:
.....'There's a timing difference between the main wing and the tail. Entering lift there is a transition region where the lift is growing stronger as the glider moves forward. The main wing will be about 15 feet ahead of the tail. As a result the main wing will be at a higher angle of attack than the tail during the transition into the lift, creating a pitch-up tendency until the aircraft has gone through the transition region. This would tend to offset the pitch-down tendency that's been discussed. I've personally flown aircraft that pitched down, others that pitched up. Flex-wing hang gliders tend to pitch up very strongly on entering lift. However, I used to fly a rigid-wing hang glider (flying wing) that pitched down. I never could explain the difference. I can confirm that, at least in the Discus and Duo Discus flying with mid to aft C of G , if you simply cruise with a rigidly fixed elevator position - set for a reasonable median cruise speed of your choice - then the glider slowly pitches up and slows under positive acceleration as you enter regions of lift and pitches down and speeds up under reduced acceleration as you enter regions of sink. I have often flown this way in the last few years since reading about the technique as an aside in Reichmann (seventh edition in English, pages 64 and 133). He discusses it in connection with methods of trying to optimize g loading in transitional phases of flight between lift and sink and refers to it as 'the near optimal solution of simply flying with the controls locked'. I have often wondered why it works when the Yates effect would at first sight tend to have the opposite effect so thanks to Finbar for the obsevation above. Flying fixed elevator results in very nice gentle speed variation without the divergence you get flying hands off but it takes a surprising amount of concentration to keep the elevator fixed. (Perhaps a little 'dead man's handle' on the stick that temporarily fixed the elevator control alone would help.) It works best when the lift and sink are continually changing because if there is a long period of steady lift or sink without vertical acceleration from the airmass then the airspeed tends to settle back at the cruise speed for the elevator setting chosen. In those circumstances you need to depart from the fixed elevator. John Galloway |
| PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 05:41 AM |
| Constant speed props | GE | Piloting | 68 | July 3rd 04 05:08 AM |
| Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 04:41 AM |
| Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 03:42 AM |
| Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 11:08 PM |
