Gerritjan wrote:
Many pilots here use petrol-guzzling sport-utility vehicles to tow their trailers. I'm trying to get some input as to whether my new VW Jetta turbo-diesel is up to the task. You forgot to tell us the weight of your trailer incl.discus... I'm towing a trailer, total weight 780 kg, with a VW-caddy TDI 66kW, max. trailer weight 1000 kg. according the manual. Empty weight of the car is 1140 kg. Great combination, more than enough power. GJ You can check VW's information...for example, I'm not supposed to tow more than 2000lbs with my Subie Outback... john |
European turbo diesels are very performant compared to their size (for tax
and petrol price reasons) You should NEVER use a turbo for towing. Turbos are only ment for intermittent operation - towing puts them into near continuous operation, leading to premature failure. Of course there will be those that disregard this claiming they have never had a problem (you never do until you do). |
Nonsense - most of the trucks in the World are turbo diesels. I towed for
years with a Saab turbo (petrol) and never had a problem. Diesel turbos are recommended for towing in Europe. "Tom Seim" wrote in message om... European turbo diesels are very performant compared to their size (for tax and petrol price reasons) You should NEVER use a turbo for towing. Turbos are only ment for intermittent operation - towing puts them into near continuous operation, leading to premature failure. Of course there will be those that disregard this claiming they have never had a problem (you never do until you do). |
I tow with Saab turbos ever since, and when I'm driving up the Nufenen pass
(8000ft) with the Calif (2400lbs) I use every single hp and I'm pretty often at 5000rpm. No problems whatsoever. Turbos have come along quite some way since their introduction. My last Saab had still the first turbo and was doing fine after 350'000km when I decided that a car with CD player and ABS would be nice. For Andreas - the BMW 5 and 3 I've been driving in the US felt pretty much the same as in Europe. -- Bert Willing ASW20 "TW" "Tom Seim" a écrit dans le message de om... European turbo diesels are very performant compared to their size (for tax and petrol price reasons) You should NEVER use a turbo for towing. Turbos are only ment for intermittent operation - towing puts them into near continuous operation, leading to premature failure. Of course there will be those that disregard this claiming they have never had a problem (you never do until you do). |
Tom Seim wrote:
European turbo diesels are very performant compared to their size (for tax and petrol price reasons) You should NEVER use a turbo for towing. Turbos are only ment for intermittent operation - towing puts them into near continuous operation, leading to premature failure. Of course there will be those that disregard this claiming they have never had a problem (you never do until you do). This doesn't match my experience, nor what I heard about that. I owned 10-15 years ago a Renault R11 with a turbo (petrol), the turbo died after about 75000 km, the nest one survived a little longer (~ 100000 km) then I replaced the car rather than the turbo. The man who replaced the first turbo said I was lucky as they rather fail after 50000 km. I used the car mostly at maximum speed since most of my usage was on highways and almost never in towns. Somebody explained to me that what kills turbos is stopping and starting the car rather than using it. This, according to this person, is due to the way they are lubricated. No oil can stand the temperature found in a working turbo, so the only way to keep them lubricated is to make a constant flow of oil trough them which is cooled outside so the temperature never reach the temperature of the turbo. But when you stop it the temperature is still high and there is no more flow, so the remaining oil is cooked and produces a solid residue. This residue is broken at the next start, causing friction and wear at this time. I don't kown if this is a valid explanation, but it is consistent with the life time of my both turbos, as well as the way they died, i.e. wear of the bearings. |
Two turbo vehicles later (one petrol one diesel) I must differ.
The turbo diesel vehicles are designed for long hard use and it is not uncommon for them to last longer than you would want (My brother's SAAB 9-5 was replaced in mint condition at 260,000km). If turbochargers were unsuitable for hard continuous use surely the heavy truck fleet and construction vehicles would use a different technology. Where I live we have had some problems with turbocharger related failures. in the late 1990s we had a spate of Isuzu 2.8L turbo diesels with blown piston crowns, generally caused by aftermarket kits to increase the maximum boost pressure - you get what you pay for. Make it possible to overstress your engine, then drive at overboost for extended periods and something will break. Factory standard engines regularly get 500,000km making them very popular with the farmers. BMW 320Ds with failed turbines - the upgraded engine introduced in 2001 had an engine management map that allowed the turbine inlet temperature to go too high in our hot and high environment.(30+ centigrade @ 5000" MSL) Coupled to our long open roads and their drivers habit of driving for hours at full throttle and the little turbine wheels melted. One electronic change and a cooling system upgrade and the failures stopped. All handled under warranty. Second hand European and Japanese imports with corroded injectors and fuel pumps - this was a problem before 2002 when low sulphur fuel became available. The jungle juice we had before had far too much sulphur and some private imports died. The turbo models died quicker because of higher temperatires I suspect. Again - ignore the manufacturers specifications and problems are likely - if the manufacturer does not offer the model locally there might be a reason. For what it is worth my Isuzu 2.8l Turbo diesel was the best tow vehicle I have ever owned. Pity it was stolen. |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Home Built | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | General Aviation | 1 | January 4th 04 04:04 AM |
Diesel Jodel information..........and .........diesel plane groups | Roland M | Owning | 1 | January 4th 04 04:04 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Home Built | 3 | September 13th 03 12:44 AM |
Diesel engines for Planes Yahoo Group Jodel Diesel is Isuzu Citroen Peugeot | Roland M | Rotorcraft | 2 | September 13th 03 12:44 AM |
