Which Logger?
Old September 10th 03, 12:55 PM
Ray Lovinggood
As others have said, you will need a gps to send data
to the EW logger. I would suggest a Garmin. It seems
if you show up at a fun-fly or a contest, there may
be others there with EW/Garmin combinations, and getting
turnpoints and doing downloads might be easier if others
are in the same 'group.'
I have a Volkslogger. Compare the cost of it with
the EW/separate gps. (Cost in U.S. Dollars)
1. Volkslogger: $800
2. Goddard power supply and cable: $130 +/- (I forgot
actual cost)
3. Compaq 1520 (from e-bay about three years ago and
I paid way too much. Your mileage may vary. )
4. The 'free-ware', PocketNav, (or whatever it is
called) from Cambridge for the Compaq
5. Software sold by Paul Remde, created by Henri Birecki,
that transfers the Volklogger igc file to the Compaq.
With this $20 piece of software, I don't need a notebook
computer to download the Volkslogger at the field.
However, I won't be able to upload any data to the
Compaq or Volkslogger at the field, unless I borrow
someone's computer. Hopefully, I'll have all the data
I will need (cross my fingers) when I get to the field.
Total cost: $950, not including pda. So yes, you
can get an EW and a gps for less than $950. The good
thing about one model of the EW is that it has the
internal battery. The Volkslogger has no internal
power source and power must be provided via the cable
that also sends and recieves data.
Ray Lovinggood
Carrboro, North Carolina, USA
At 12:06 10 September 2003, Jose M. Alvarez wrote:
Recently I decided for a Volkslogger. Easy installation,
screwed it in place
of the camera, small, GPS included. IGC files perfect.
Several friends have
EW and have trouble with downloads, plus you need another
GPS to connect.
If I were you I'd go for a Volkslogger. Besides, the
EW is not that cheap!
Jose M.Alvarez
'Eric Greenwell' escribió en el mensaje
says...
Most other loggers include a GPS the EW does not
and has to be used with
a
specified GPS for ICG approved flights.
This aspect makes it more work for you and your official
observer, if
you go for badges or records. It is also limited to
the Diamond badge
and lower.
!Replace DECIMAL.POINT in my e-mail address with just
a . to reply
directly
Eric Greenwell
Richland, WA (USA)
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
