As a low time glider pilot who is getting back into soaring (just
bought a 1-35), I can't believe this thread. The FAA absolutely CAN regulate people against their own stupidity. They do it with that thing called the FAR's. The tone of many on this issue here seems to be that the FAR's are for the rest of aviation to follow, not contest glider pilots. Did it ever occur to you guys that one day the FAA might get fed up with us glider pilots and start enforcement actions against our tiny population? Rules are rules and you are supposed to follow them. Soaring has a terrible safety record and most of it seems due to a bad attitude at everything related to safety. Hans Langer's tragic accident occurred just a few weeks ago and the NTSB site says that his spoilers weren't hooked up. How many deaths have been caused in the last 10 years because the glider pilot didn't assemble his aircraft correctly? Oneday when someone makes a low pass and hurts or kills someone on the ground or causes a midair, then you can be sure that the FAA will step in to do something about this stupid practice. Owain Walters wrote in message ... JJ, I am sorry for starting this fight with you but I will proceed with what we have started. I dont mind how experinced you are in Fast Jets I dont see why you want to regulate against things that might happen. You will not stop someone hell-bent on killing themselves by enforcing a 500' min finish height. Lets be reminded that the guy who started this says that the racing finish is still allowed. You can not regulate against peoples stupidity. If this rule goes through people will get their kicks somewhere else and almost certainly in a more dangerous, less regulated situation. |
Let's assume, for the sake of argument, that the interpretation
of the FAR's is correct - that busting 500' is, without exception, a violation in any circumstance other than final approach to landing. It is not clear to me that this is necessarily the case, or enforced that way by the FAA, but put that aside for now. If we are going to abide by the letter of the law on FARs, then busting 500' agl ANYWHERE on course should be grounds for penalty. This could be DQ for the day, scoring as if you landed at the spot where the infraction occurred, or whatever is consistent with other FAR violations under contest rules. I believe this would include low saves as well as ridgeline crossings and ridge soaring, etc. In other words, we would need to enforce a 500' agl hard deck in the scoring programs, which would need to include an accurate terrain elevation database. I suspect this is technically not that hard to do since programs like SeeYou already have it. Before going down that path, however, I would want to see a definitive statement from official FAA sources that this is in fact the correct interpretation of the FARs AND that the FAA intends to enforce these FARs to the letter of the law, rather than only in those instances that show some form of recklessness beyond the technicalities alone. It would be a pity in my view if this happened as I really like mountain flying and ridge soaring. 9B At 19:00 03 October 2003, George William Peter Reinhart wrote: JJ, You have a very good point. Why not handle violations of the FAR's same way as busting 18K? No score for the day (or maybe DSQ for the contest). Rules violations used to be handled that way at the sailboat races in times before political correctness was so much the vogue. Cheers!, Pete JJ Sinclair wrote in article ... I flew the 111 at Mountain Home ('72-'74) We have established that the 50 foot gate VIOLATES the FAR's, So what are we going to do about that? We have established that some pull-ups VIOLATE the FAR's, So what are we going to do about that? We have established that finishing over people, VIOLATES the FAR's, So what are we going to do about that? JJ Sinclair |
Here is what the local FAA Saftey inspector from the FSDO told me less
than a month ago. "Just about everyone likes to do a low pass once in a while. I have even done one in a my Aeronca champ, but no one noticed. The FAR's say 500 feet from any man made object, except for takeoff and landing. Precedince is a fence post is a man made object. However an occasional low pass safely done over a runway will usually not get the FAA's attention. However repeated low passes will result in a visit from you local FAA inspector and possible certificate action" That is right from the FAA and perhaps not word for word but you get the idea. It may be interpreted differently at different FSDO's. But it seems to mee that our FSDO has a very common sense approach to this subject. Brian Case CFIIG/ASEL Andy Blackburn wrote in message ... Let's assume, for the sake of argument, that the interpretation of the FAR's is correct - that busting 500' is, without exception, a violation in any circumstance other than final approach to landing. It is not clear to me that this is necessarily the case, or enforced that way by the FAA, but put that aside for now. If we are going to abide by the letter of the law on FARs, then busting 500' agl ANYWHERE on course should be grounds for penalty. This could be DQ for the day, scoring as if you landed at the spot where the infraction occurred, or whatever is consistent with other FAR violations under contest rules. I believe this would include low saves as well as ridgeline crossings and ridge soaring, etc. In other words, we would need to enforce a 500' agl hard deck in the scoring programs, which would need to include an accurate terrain elevation database. I suspect this is technically not that hard to do since programs like SeeYou already have it. Before going down that path, however, I would want to see a definitive statement from official FAA sources that this is in fact the correct interpretation of the FARs AND that the FAA intends to enforce these FARs to the letter of the law, rather than only in those instances that show some form of recklessness beyond the technicalities alone. It would be a pity in my view if this happened as I really like mountain flying and ridge soaring. 9B At 19:00 03 October 2003, George William Peter Reinhart wrote: JJ, You have a very good point. Why not handle violations of the FAR's same way as busting 18K? No score for the day (or maybe DSQ for the contest). Rules violations used to be handled that way at the sailboat races in times before political correctness was so much the vogue. Cheers!, Pete JJ Sinclair wrote in article ... I flew the 111 at Mountain Home ('72-'74) We have established that the 50 foot gate VIOLATES the FAR's, So what are we going to do about that? We have established that some pull-ups VIOLATE the FAR's, So what are we going to do about that? We have established that finishing over people, VIOLATES the FAR's, So what are we going to do about that? JJ Sinclair |
Andy,
Thank you for your reasonable response that deals with the issues. You mentioned Minden and thought that a 50 foot, finish line could be safely employed there. I was asked to be the CD at the first Sports Class Nationals, held at Minden, some 20 yeasr ago. We employed a finish line on the Eastern edge of the main N-S runway and it extended on out East for 3300 feet along the edge of the closed runway. That closed runway is now glider tie-downs on both sides of the N-S runway. If we extended the finish line, another 3300 feet on out to the East, any low and slow finishers would be a minimum of half a mile away from any runway. Clearly not a safe situation. I don't know anywhere that a f 50 foot high, 3300 foot long finish line could be safely used at Minden today. That is why we used the 500 foot, 1 mile finish cylinder at this years Regionals and will use it again if we get the 18 meter nationals in 2004. A couple of years ago, I was again asked to be the CD at the 18 meter and Sports Nationals held at Montague. In the Regionals that immediately preceded the nationals, we used a finish line with 50 foot minimum altitude. The airport lay-out is similar to Minden with a main N-S runway and glider tie-downs on both sides of an intersecting closed runway. When it was pointed out to me, that finishers were coming in very low, right over people in the tie-down area, I decided to employ the 500 foot, 1 mile finish cylinder in the Nationals. The same situation as Minden exists at Montague. If we moved the finish line another 3300 feet on East, a low and slow finisher would be a minimum of half a mile from any runway. We could move the finish line to the North end of the main runway, but finishers would find themselves over a mile away from the glider tie-down area. This would result in some low finishers, rolling to a stop, thousands of feet short of the southern tie-down area and consequently, blocking the runway. I don't know anywhere the finish line could be safely used at Montague. The 500 foot, 1 mile finish cylinder eliminates all conflicts with FAR violations and allows for a safe and efficient way to deal with finishers that may be facing head-on situations as they come in from all directions, at the end of a MAT task. Any head-on traffic has a full 2 mile separation. The contestants, pull-up and slow-up at 1 mile and then enter the pattern in a relaxed and orderly manner. I believe the 50 foot, finish line will disappear from US competition, whether or not it is removed from our rules, simply because no prudent Contest Manager would employ it due to the conflicts it presents with violation of several FAR's, JJ Sinclair |
![]() "Jonathan Gere" wrote... JJ - Do you ever make your landing touchdown within 500' of a person, trailer or runway light, even if it is not necessary? 91.119 Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes... |
"Marc Ramsey" wrote in message m...
"Jonathan Gere" wrote... JJ - Do you ever make your landing touchdown within 500' of a person, trailer or runway light, even if it is not necessary? 91.119 Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes... I meant not "necessary for takeoff or landing". The things I mentioned are not necessary for landing. Lots of people do them as a normal part of their landing, but they could land at the far corner of the airport (or off-field) to better follow the FAR's, if JJ's legal opinions were correct, not ridiculous. Lots of other people make low passes as a normal part of their landings, right under the noses of FAA officials, the ones who get a weekday off with pay visiting glider contests. I guess JJ is right that low passes are illegal! The seventh level of hell: eternity with JJ, John Cochrane, and the guy who determined that rigging a glider required a logbook entry as preventative maintenance, until the FAR wording was changed. Jonathan Gere |
JJ,
The finish cylinder has its place in competition. But not to the exclusion of the finish line. Many of us still contend that it is better to race to a visible marker rather than to a virtual point in space requiring refernce to instruments. Heads up rather than heads down. As for the FARs, aircraft regularly take off and land withn 500 feet of people, structures, and other aircraft at commercial airports. This is by necessity. An airport manager must balance proactive safety initiatives with perceived risk versus safety history. And finally, trailers and tie downs are mobile. Are we there to race or to recreate? If the latter, call it a camp and dispense with the racing altogether. Camps are fun too, but let's not confuse them with contests. OC |
"Chris OCallaghan" wrote...
The finish cylinder has its place in competition. But not to the exclusion of the finish line. Many of us still contend that it is better to race to a visible marker rather than to a virtual point in space requiring refernce to instruments. Heads up rather than heads down. Flying head down is never necessary. The center of the finish cylinder is almost always close to some visible marker on the airport. If it isn't, I ask the CD to move it so it is. My software beeps when I cross the boundary of the cylinder, does yours? Finally, I only glance at the computer once in a while to see if I'm falling below glide slope, which I'd also be doing with a 50 foot gate. But then again, I'm not anal about finishing at precisely 500 feet... As for the FARs, aircraft regularly take off and land withn 500 feet of people, structures, and other aircraft at commercial airports. This is by necessity. 91.119 Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes... |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Jet fighter top speed at military power | David L. Pulver | Military Aviation | 18 | December 1st 03 07:13 PM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
New Film: The Need For Speed - Going to war on drugs | Phil Carpenter | Military Aviation | 0 | July 23rd 03 07:43 AM |
