"Eric Greenwell" wrote in message The most interesting thing to me about Chris's experience is fixing a trailering problem by changing the tires on the tow vehicle, something I don't recall hearing about before. Each of the changes he made... So, sounds like they went for the 'bottom line' on the tires. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) Eric. I think the critical change was the lowering of the hitch point. I have a Chevy Tahoe with Geolanders on it. I play with sports cars a bunch and I can't believe how good these tires were at the limit. When I changed the brakes a bit ago you could clearly see where I was on the bump stops from cornering. I was suprised to see that much body roll indicated when the feedback in the seat was so secure. Besides that, tires usually are reactive to forces, not force generators. In order for an oscillation to be established, the tires must be excited by something. A high hitch raises a trailer CG ans contributes mightily to swaying back and forth. Stiffer tires would be more difficult to excite, but they are masking the force, not curing its existance. Scott Correa |
In article , scorrea-removethis-
@socket.net says... Besides that, tires usually are reactive to forces, not force generators. In order for an oscillation to be established, the tires must be excited by something. A high hitch raises a trailer CG It's hard to see how this can be, since the CG is so close to the trailer wheels. Raising the hitch 6" would raise the trailer CG less than 1". ans contributes mightily to swaying back and forth. The explanation that seems more likely to me is the higher hitch lets the trailer roll the tow vehicle more, which would introduce steering forces. Chris also said: "Other advice that helped included lowering the hitch position and shortening the hitch to reduce the distance from the ball to the rear axle." It sounds like he tested the hitch effect separately from the tire changes. Stiffer tires would be more difficult to excite, but they are masking the force, not curing its existance. -- !Replace DECIMAL.POINT in my e-mail address with just a . to reply directly Eric Greenwell Richland, WA (USA) |
| Thread Tools | |
| Display Modes | |
| Tire Stiffness & trailer swaying | chris | Soaring | 42 | October 22nd 03 04:51 AM |
