News Flash: You don't need elevator control !
Old November 3rd 03, 06:43 AM
F.L. Whiteley
"JJ Sinclair" wrote in message
I know of a Kestrel 19 that's done the same, twice. The wing attach
design
is very much the same. The pin is not load bearing, but only locks the
wings together. As long a 0 to negative G is avoided, they won't come
off.
Come on guys, this story is getting out of hand. Your asking us to believe
that
a Kestrel driver used his neat little wing assembly tool to force his
wings
together and then FORGOT to put the main pin in? And you say he did it
twice?
That pin is not load bearing, but any turbulance (like what we do to make
wing come out, on didassembly) will allow the wings to slide out and then
our
fictitious Kestrel driver would find himself wingless.
JJ Sinclair
Nevertheless, the owner admitted to doing this twice.
Frank
Old November 3rd 03, 06:48 AM
F.L. Whiteley
"F.L. Whiteley" wrote in message
design
off.
believe
that
wings
twice?
make
then
our
JJ Sinclair
Frank
Maybe the tape and control linkages are _just_ enough........
One of our club members also landed his Std Jantar 2 following a winch
launch. A young lady that walked out to look at the glider picked up the
horizontal tail attach pin and handed it to him, as it had fallen out on
landing. He painted it in such a way that if it wasn't properly seated, a
color would show. He then booked a flight to Majorca to 'enjoy life' and
the fact that he was still living it.
Frank
Old October 30th 03, 04:55 PM
Chris Nicholas
Depends on the glider type. In a Ka6E you will certainly crash. If on
tow, you will kill the tug pilot and then crash yourself. Which part of
the phugoid you are in when you hit the ground will play a large part in
determining whether your crash is fatal or just very serious.
Chris N.
Old October 30th 03, 07:36 PM
John Galloway
At 10:00 30 October 2003, Andrew Warbrick wrote:
Mind the flaps are the major pitch control in the ASW20,
the elevator is there more for fine adjustment.
I'd like to see a 20 completing a loop with flaps alone
before I accept that oft stated view:-) A spin recovery
would be interesting too.
John Galloway
Old October 31st 03, 12:20 AM
Dave Nadler \YO\
And, in related news:
http://www.news.com.au/common/printp...628206,00.html
See ya, Dave
"nowhere" wrote in message
m...
Yes, according to Peter Garrison's "Aftermath" column in the November
issue of "Flying" you don't need to connect your elevator control! I
quote: "the NTSB report does not comment on the fact that a
disconnected elevator does not make an ASW-20, or for that matter any
other airplane, unflyable. The situation is aerodynamically no
different from what occurs when the pilot removes his hand from the
stick."
I think I'll start leaving the elevators off my ASW-15 now. Imagine
how the reduction in drag will improve the performance! Not having to
worry about pitch control will certainly cut down on the cockpit
workload as well. The benefits are endless!
Old November 1st 03, 12:38 AM
Doug Haluza
(nowhere) wrote in message om...
stick."
Well, it may be flyable, but not landable! The stick free phugoid can
get pretty dramatic, even with the mass and friction of the stick
attached to provide some damping . If you have not tried this, you
should. Keep hands completely off and keep the wings level with
rudder. Let the phugoid fully develop--it's a real roller coaster
ride. Close to the ground, it's a crap shoot whether you would land or
crash.
There was an accident a few years back in a DG-800 that had a loose
nut on the elevator control. The pilot hit on the down part of the
phugoid and crashed wings level. He lived, but never flew again.
The same thing happened to United Flight 232, the DC-10-10, that
crashed while attempting an emergency landing at the Sioux City
Gateway Airport, Iowa, in 1989. After losing all hydraulics, they had
no movable flight controls. They were able to fly the aircraft with
differential thrust on the two wing engines, but they could not
control pitch on final approach.
I have not seen the article, but I'm surprised that a knowledgable
person would suggest that elevator control is optional.
Old November 1st 03, 04:25 AM
Andy Blackburn
Doug overstates the case a bit. Even without elevator
control it is possible to damp out the phugoid mode.
I tried this on a BFR recently and I encourage the
rest of you to give it a try as well. Since the phugoid
is a function of airspeed/pitching moment coupling,
you can damp it out by applying speedbrakes at the
bottom of the cycle. This take a bit of thinking ahead,
but it can be managed with practice.
The United 232 crew was able to control pitch through
pitch/thrust coupling. They applied collective thrust
to adjust pitch and differential thrust for directional
control. It was crude put effective enough to get to
the runway threshold. Unfortunately, the dug s wing
in on landing. It was not directly a result of the
phugoid mode, though I suspect all the different modes
conspired a bit.
news:...
Yes, according to Peter Garrison's 'Aftermath' column
in the November
issue of 'Flying' you don't need to connect your elevator
control! I
quote: 'the NTSB report does not comment on the fact
that a
for that matter any
no
his hand from the
stick.'
now. Imagine
Not having to
on the cockpit
free phugoid can
of the stick
tried this, you
level with
roller coaster
you would land or
crash.
that had a loose
part of the
flew again.
that
Sioux City
they had
aircraft with
could not
a knowledgable
Old November 1st 03, 03:23 PM
Andreas Maurer
On 1 Nov 2003 04:25:38 GMT, Andy Blackburn
conspired a bit.
One might mention that NASA tried to recreate this 232'2 landing
using a simulator (as well as an F-15).
No aircrew *ever* was able to touch down their aircraft soft enough to
make the crash survivable.
Bye
Andreas
Old November 5th 03, 01:56 PM
Andy Durbin
Andreas Maurer wrote in message . ..
Bye
Andreas
NASA followed up with a test using a modified MD-11. The FADEC
control laws were changed to allow much greater authority in engine
trim and the Flight Control Computer (FCC) software was modified to
control pitch and roll with FADEC thrust commands. (On an MD-11 a
single autothrottle servo drives all engines in parallel but the FCC
to FADEC interface provides independent thrust trim to each engine)
The program demonstrated that it was possible to control the aircraft
in pitch and roll with thrust only using normal inputs from the
autopilot mode control panel. Several approaches were made I think at
least one sucessful landing was demonstrated. (I was only involved
with the lab test and never saw the flight test reports).
Andy
22 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 24th 04 06:46 AM
16 Aug 2004 - Today’s Military, Veteran, War and National Security News Otis Willie Military Aviation 0 August 17th 04 12:37 AM
AVSIM News Update Eric Lunston Simulators 16 August 15th 04 04:49 AM
CBS NEWS - An Idea Harry Gordon Piloting 15 January 17th 04 01:22 PM
