Winching - Reverse Auto Tow
Old November 4th 03, 04:42 PM
Chris Nicholas
Initial acceleration is certainly much slower with autotow (whether
pulley or direct) than with winching. At both North Weald and Aston Down
there was more than one runway, so most launches were broadly into-wind.
Such cross wind as there was could be handled. The initial ground run
was a phase of flight in its own right - the pilot had to learn to
balance on the wheel and taxi straight until flying speed was achieved.
Wingdrop was not normally a problem, but training people to taxi was a
feature. The same considerations apply when landing, in any case, so
they got two lots of taxi training in one flight.
On tarmac or concrete the F250 trucks had adequate power and grip. F100'
s were not bad, but we didn't have such heavy gliders in those days.
Aston Down tried a variety of tow vehicles over the years, including
some home-built diesel dragsters, but I believe they ended up with
factory-built trucks, as we did, and as Lasham (using straight autotow
at one time) also did. I worked for Ford then, and helped to get some
advantageous prices for imported US-built vehicles for two if not all
three clubs IIRC - Ford used gliders at North Weald as background for
some advertisements, and did us a favour in return.
My club used LPG rather than petrol/gasoline, which made it a comparable
fuel cost to diesel winching, per launch/cable-retrieve. Total
depreciation/financing cost was probably about comparable, but needed
less cash flow up front. Trucks were cheaper capital cost than new
winches, though not as durable - ours lasted for about 50,000 launches
each and were not fully worn out - we recycled one old powertrain into a
winch when we had to adopt that method for our Ridgewell site.
The key features for us at North Weald were that on hard runways we had
to use piano wire (single strand steel cable), not stranded, to avoid
too much wear and cable cost, and pulley/autotow lends itself to that
better, with pulley giving also the benefit of fast launch rate when
well organised. We did about 9,000 launches a year, and added
considerably to our cash flow, when we had optimised the system.
Chris N.
Old November 4th 03, 05:35 PM
W.J. \(Bill\) Dean \(U.K.\).
The initial acceleration for a car or reverse pulley launch is no worse than
for an aerotow; it is flown in the same way. There is of course no tug
slipstream to contend with.
A car launch starts like an aerotow, and turns into a winch launch when you
are airborne.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Chris Nicholas" wrote in
message ...
On tarmac or concrete the F250 trucks had adequate power and grip. F100's
Chris N.
Old November 8th 03, 12:50 PM
Frank Dobbs
"W.J. \(Bill\) Dean \(U.K.\)." wrote in message ...
are airborne.
message ...
Chris N.
It was the Dublin Gliding Club which used reverse pulley launching in
Ireland up to the early 1970s.
I flew there, from Baldonnel airfield. The pulley was about 3feet in
diameter and very simple with hardly any fairing. It was mounted on
the back of a large Chrysler car which had a tow-beam coming out of
the front with a heavy metal spike at right angles that was embedded
in the ground to anchor it. The mount for the pulley allowed it to
rotate to any angle to follow the line of the cable. The cable was
single strand piano wire. The concrete runways would have worn out
stranded cable too quickly.
The tow car, a large American automatic transmission car, had a
standard cable release mechanism welded to a lever which compressed a
small plastic football filled with water connected to a clear plastic
tube leading in to the top of the dashboard. The water rose in the
tube as the tension in the cable increased. Marks indicated the right
pressure for single seaters and two seaters (we flew K7, K13, K8, K6
mainly). The launch driver technique was very simple. Accelerate
rapidly to the correct tension once the glider was established in
climb. Slow down or speed up to keep the tension on the mark. I don't
remember ever having to signal too slow or too fast from the glider.
When the wind was strong, it was possible to reverse down the runway,
paying out the cable, as the glider kited upwards. My highest launch
was 4500 feet using this approach.
Cable breaks took rather a long time to disentangle as the cable
sprang back and tied itself in knots. Good heavy gloves were useful.
Splices were carried out by two people standing opposite each other
and winding the free ends back over the wire by hand.
The end came when the Army Air Corps installed VASI instrument landing
lights at the ends of the runways. The runway lights had been
expensive to replace if hit by flying rings, but the VASI lights were
£20,000 each and would have meant bankruptcy.
The Dublin Gliding Club still launches by (straight) car tow from
beaches in County Kerry each year on their wave safaris, using parafil
cable.
Frank Dobbs
Ulster Gliding Club, Northern Ireland
Old November 5th 03, 12:02 AM
F.L. Whiteley
Ridgewell, that's the place old Fred had the steam winch. Of course, he was
shunned by most BGA types.
There's still a story out there somewhere. Maybe someone will ask around
this winter.
Frank Whiteley
Old November 5th 03, 12:46 AM
Chris Nicholas
Frank Whiteley wrote: "Ridgewell, that's the place old Fred had the
this winter."
It was diesel, not steam, but made from a converted combine harvester.
The saga of Freddie's club is fairly complicated, but he was far more
tolerated by the BGA and quite a lot of BGA types until he made it
impossible to be allowed to carry on in BGA membership.
His achievements in starting a club from scratch, converting a rough
field at Ridgewell into a useable gliding site, backing it with his own
money, and carrying on until illness intervened, were prodigious. We
all recognized those things, and perhaps let him get away with other
foibles for too long. My club has since benefited from his pioneering
efforts, having bought the site in 1991 when it looked like we would
lose the use of North Weald.
Before starting his own club, Freddie acquired a PPL and a Silver C
elsewhere. He went on an instructors course, and failed to qualify.
When his own club had mustered the enough equipment to start, he
appointed himself Chief Flying Instructor (CFI).
In establishing the club, he sought help from, and was given it by, the
BGA, free gratis. He did not join straight away, but did after a while.
The BGA tolerated his lack of qualifications and tried to get him up to
standard, but he was unable to reach the level needed. The BGA tried to
get him to accept a qualified instructor from elsewhere as CFI, but he
refused. He then claimed to be operating in two ways. When there was
no BGA-qualified instructor on the site, he said he had a soaring group
and he was carrying passengers and letting them try the controls. When
his passengers had reached solo standard as he thought, he then called
in a visiting instructor from elsewhere, called it a gliding club that
day, and got the visitor to check out his students so they could have a
BGA A and B certificate. The BGA let this go on for some years, all the
time trying to get him either up to scratch himself or persuade him to
accept outside help. I was on the BGA Executive Committee at the time,
and took an active part in trying to help - to no avail.
During this time, there were various events which brought interest from
outside authorities. One was a tug accident, Fred towing and IIRC
hitting his own mechanical shovel. After one of these, he was again
assessed by the BGA, and a second opinion sought when he refused to
accept the first. Both thought he was not up to instructing. There
were also concerns about the airworthiness of his fleet.
Eventually the BGA delivered an ultimatum. He was in breach of a prime
regulation - not having a CFI with qualifications, and himself
instructing while unqualified. I went personally to try to persuade him
to accept another CFI, and at one time I thought I had succeeded. But
he then dug in and refused to accept it. The BGA put it to a General
meeting and it was resolved, with only his vote against, to discontinue
his club's BGA membership. What would any responsible regulatory body
do?
Sadly, he fell ill and died not long after. His club went moribund.
After his death, several of my friends and colleagues helped to set up
his club again. My club's deputy CFI went to help, and promptly
declared all their gliders unserviceable through neglect. Eight of us
bought them a K7 2-seater to start again. (I have just sold it for
virtually nothing, so lost 1000 sterling on it.) One of my friends
became their CFI and technical officer. I persuaded the BGA to let them
back in without paying a subscription for a year.
Then they lost the use of their site, and went into hibernation again
until we bought it a few years later. Several of their members joined
us - several more were members of both clubs anyway, having helped in
their regeneration.
I think Freddie's family held me personally responsible for the rift,
when in fact I had done all I could, and more than most, to try to help.
I could say more, but that covers the essential part of a strange story.
Somebody else can write up the saga of the combine harvester winches (I
think there were two in succession).
Chris N.
Old November 5th 03, 05:10 PM
F.L. Whiteley
Chris,
Thank you very much. That fills in a lot of details.
For sure, our club CFI and Chairman told us to steer well clear.
Frank Whiteley
"Chris Nicholas" wrote in message
this winter."
do?
their regeneration.
Chris N.
Old November 5th 03, 04:50 PM
Alistair Wright
"Chris Nicholas"
|Hi Chris,
Remember me? I was an instructor at North Weald from 1972 till
1978 when I went to the LGC (a bad move) and gave up gliding
when they refused to ratify my instructor's ticket (I only had
1000 launches instructing and about 20 solo pilots to my
credit).
However the winch story is interesting. When I was at the
Staffordshire Club in the late 60s I designed(!!) and built a
diesel winch which consisted of two old artic tractors , one
mounted on the top of the other (looked like a particularly
nasty copulation). The lower lorry was for transport and the
upper had its wheels replaced by large drums with brakes. You
braked one drum and the other ran at twice prop shaft speed
using the diff as a gear (didn't half heat up the oil). Worked
a treat and was very economical. I never saw anyone else try
this method. The SGC called it the 'Winchosaurus' as it
certainly looked primeval!
Alistair Wright
long retired glider pilot
Old November 6th 03, 12:10 AM
Chris Nicholas
Alistair, Hi! I certainly remember you. Didn't know where you went
after North Weald.
I have seen a recent posting which suggested that using the diff as the
drive for a winch drum on the axle and doubling the speed is not a
recipe for long life. As others have pointed out, a better long term
solution seems to be a proper rightangle drive (the crown wheel and
pinion seem fine for that) and dog clutches for the drum, one at a time
and at crown wheel speed.
I did not see your winchosaurus, but I believe that there have been an
amazing variety of winches over the years. The most eccentric I know of
were Freddie Wiseman's 1977 converted combine harvester at one end of
the scale, and a totally portable, demountable, device to bolt onto the
hub of a Rover car at the other extreme. The latter was a commercial
offering, again in the 1970's.
When we lost the use of wire launching at North Weald but had bought
Ridgewell and needed to acquire one or more winches, we tried a
converted bus. That had two axles, one above the other, rather than the
whole second chassis. It had one drive shaft which had to be
disconnected from the lower axle after driving the bus to the winch
point, and reconnecting it to the higher, drum, axle. IIRC it had dog
clutches. We didn't buy it because it was unreasonable expensive and
looked as though it was not a sufficiently long term solution for us.
I had seen a similar arrangement in 1970 when Essex's original winch was
an old truck with that idea. I had my first instructional launch from
it, one cold March morning when there was too much ice to autotow. Got
300 feet and a free second go, which was not much better.
Now, we have ended up with 4 ex-ATC winches bought at auction, getting
two reasonable ones from them plus a lot of spares, and replacing their
powertrains. One had a total cab transplant too, professionally built;
the other is in the course of having a lower cost replacement cab, made
by some of our members.
Regards - Chris.
Old November 6th 03, 09:43 PM
Alistair Wright
after North Weald.
Quite true as we found out. We had a source of free lorry back axles at the
time and we went through a fair number till we altered the lubricating
system to thinner oil with a pump and cooler. I left SGC about that time so
have no data on the subsequent fate of that winch. Considering it replaced
our original S/H ex Derby and Lancs one (Ford V8) which was on its last legs
when we bought it , it did pretty well.
My next club was the Coventry GC at Husbands Bosworth where very little
winching took place -- I only had about 4 in as many years - it was all
aero-towing at HB.
You were lucky then! It wasn't a pretty sight I can tell you. I have a
model of it somewhere.
converted bus.
I used to think NW's auto towing was magic. On a good day you could get
twenty launches an hour. Didn't half use up Ford Zephyrs though!!
Good idea. The ATC jobs were very well built and designed to launch T21s.
A winch that could hoist one of those to 1000ft would launch anything.
Best wishes
Alistair
All the best to any others in the EGC who remember me.
Old November 7th 03, 12:38 AM
F.L. Whiteley
"Alistair Wright" wrote in message
after North Weald.
so
replaced
legs
aero-towing at HB.
converted bus.
When we re-engined an ATC winch at Enstone from 150hp Bedford diesel to the
275hp XJ-6 Jag we got some pretty solid launches. After a time we developed
a vibration and thought one of the pillow blocks on the drum had given up,
but this wasn't the case. The vibration got worse, so we pulled all of the
wire from the drum and found it to be collapsing inward under the strain of
launching the Twin Astir and L-13 under more power than the winch had been
designed for.
Frank Whiteley
vortex ring state at any point during an auto?? Greg Johnson Rotorcraft 18 August 30th 04 09:12 PM
Auto Fuel Residue Stu Gotts Restoration 4 May 12th 04 08:52 PM
Auto conversions & gear boxes Dave Covert Home Built 56 April 1st 04 06:19 PM
Arrow auto gear extension oddness Roy Smith Owning 10 March 8th 04 02:27 AM
VOR & Reverse Sensing mrwallace Piloting 1 August 21st 03 03:08 AM
