Do winglets produce thrust?
Old November 29th 03, 07:32 PM
Eric Greenwell
soarski wrote:
In my country, our gliders move forward because the wing produces
thrust, and our sailboats move over the water because the sail produces
thrust. Whether we should rule the world is causing much controversy.
PLEASE....Readers of the World! This is not in our textbooks! Did
someone in the USA write the above???
Wings produce Lift!! A by product of lift is drag! Winglets do also
produce lift, and therefore drag. Possibly less than the wing? But
you canot call it thrust!.......
"Thrust", for the winglet question and my remarks about gliders and
sailboats, was used to mean "force in the direction of motion".
Apparently, that was an unusual use of the word for some people.
Here's an expanded expanation:
Gravity is pulling straight down, and so can not propel the glider
forward; drag is pulling the glider back, and so can not propel the
glider forward. So, what is left to counteract the drag? Lift, produced
by the wings. This forward force comes from the lift, which is not
vertical, but tipped forward a bit. Look at any diagram showing the
forces on a glider, and you will see how the lift, drag, and gravity
forces accomplish this.
It is not common to call this force moving the glider forward (without
it, drag would bring it to stop) "thrust", but the word is sometimes
used that way.
I still can't answer the original question about the winglets, though.
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old December 1st 03, 03:28 AM
LittleJohn
used that way.
Sheesh! So many words and so little knowledge... Here's how it works,
guys.
For any aircraft in balanced flight, there are four forces acting on it.
All forces except gravity act only along the chord or perpendicular to it.
Gravity not only produces a force in opposition to lift, but a resultant
vector force which can be either thrust or drag, depending on the angle of
the chord in respect to earth (gravity). in other words; Gravity is the
'engine' in a glider that produces thrust.
For those that don't understand vector force components (or flunked trig),
don't worry 'bout it. Simply believe they exist.
As for the winglets, they only reduce drag. At the point where the
airfoil ends, air rolls to the other side of the wing due to the pressure
difference. The rolling air produces a vortex that kinda acts like vacuum
cleaner hoses grabbing the trailing tips of the wings. The winglets
interfere with the creation of the vortex(s) thus reducing drag. Smaller
vortex (smaller vacuum cleaner) means better L/D (slicker ship).
LittleJohn
Madison, AL
Old December 4th 03, 09:43 PM
Fred the Red Shirt
LittleJohn wrote in message ogy.net...
guys.
it can also produce a force in the same direction to, or perpendicular
to lift. 'lift' is the aerodynamic force perpendicular to the direction
of motion. It is the horizontal component of lift that turns a banking
aircraft, and a vertical, downward lift that allows an aircraft to
accelerate in a dive FASTER than the acceleration due to gravity as
when the old Hurricanes inverted to keep the fuel flowing into their
engines when chasing a diving Messerschmidt. If they dove without
inverting first, they'd be chasing that M. in a glider.
Weight is the only one of the four forces that is constant in direction
is an earth-centered frame of reference. The other three forces may
be oriented in any direction though not independently as drag must be
opposite to thrust and lift perpendicular to both. Of course these
defintions are arbitrary, but other equally arbitrary defintions are
less useful.
Gravity is the
More like it is the 'fuel', the engine is the wing.
FF
Old November 30th 03, 01:53 PM
K.P. Termaat
"soarski" schreef in bericht
om...
In my country (Holland) students will be disqualified from their examination
when they make an "interesting" remark like this. Reducing induced drag is
what winglets do and gravity is the engine of our gliders.
Karel Termaat
Old November 30th 03, 05:08 PM
Eric Greenwell
om...
And what produces the "thrust" that moves your sailboats? Gravity?
This may be a simple confusion over the word "thrust", which I used (as
did the original question) in the sense of "force in the direction of
motion". Both the glider and the sailboat are propelled in a forward
direction by lift from the wing or sail.
Eric Greenwell
Washington State
USA
Old December 4th 03, 09:45 PM
Fred the Red Shirt
Eric Greenwell wrote in message ...
om...
Not if you _define_ lift as perpendicular to the direction of motion...
FF
Old December 4th 03, 10:31 PM
Eric Greenwell
e.com...
True, which was not my intention. What I meant was "horizontal motion",
as I said later ("propelled in a forward direction"), thinking as a
pilot might as he tries to get somewhere.
Eric Greenwell
Washington State
USA
Old November 29th 03, 01:13 AM
Denis Flament
Keith W wrote:
That's against the laws of thermodynamics.
No.
Provided the thrust of the winglets is not higher than the drag of the
other part of the glider, that's not (and of course the winglet thrust
is only a few % of the glider drag)
Denis
Private replies: remove "moncourrielest" from my e-mail address
Pour me répondre utiliser l'adresse courriel figurant après
moncourrielest" dans mon adresse courriel...
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 01:19 AM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
