Winch rope 1/4 inch poly
Old January 17th 04, 08:03 PM
Robert Curry
(Doug Taylor) wrote in message . com...
Vectran would not be a very suitable winch rope. It tends to fatigue
relatively rapidly with bending. It is useful as standing rigging on
sailboats but isn't used for running rigging. Technora is about the
same tensile strength and modulus (both have very high modulus)
without the fatigue problem. I don't have any proof of this but was
told this by someone who appeared to know quite a lot about all the
various new fibers being used in rope.
Gary,
Thanks for the information. Now, if the poly could be spliced ~50/50 or so
with something like 1/8" Validator 12
http://www.samsonrope.com/admin/data...dator12_LR.pdf ,
(Vectran) http://www.pelicanrope.com/peli05c.htm both the bungee and sag
effects could be reduced with some cost benefits. This could be a solution
for long runs. When we launched with 1000ft of Spectra on the end of the
wire rope, we didn't pull the Spectra through the rollers. Two synthetics
with a reasonable join might work well as a hybrid solution.
Vectran is stronger than Spectra with a higher critical temperature, but
with somewhat less abrasion resistence.
There are some interesting 1/4" vectran sheathed products
http://www.pelicanrope.com/new04.htm
for improved abrasion resistence.
And Plasma 12
http://www.cortlandcable.com/psrope/...PlasmaRev9.pdf
Spectra in a variety of sizes.
Frank Whiteley
Colorado
OK, I can see that their are many ideas & successes on the polyrope.
Can anyone give me an idea as to the height advantage. For example.
Four thousand foot runway no wind. With wire we usually climbed to
1000 feet and with poly we averaged 1200? Does anyone know of a web
site where this info may have been posted?
Robert Curry
Ohio
More Spectra Winch Rope Bob Johnson Soaring 0 December 24th 03 05:45 PM
Spectra winch rope Bob Johnson Soaring 0 December 24th 03 04:25 PM
Tow Rope Freindly Fences John Spargo Soaring 8 September 2nd 03 04:17 AM
using winch instead of aerotow goneill Soaring 5 August 27th 03 02:46 PM
Using Plasma Rope For Winch Tows Craig Freeman Soaring 56 August 24th 03 10:55 PM
