#51
At 09:18 07 January 2004, Marc Ramsey wrote:
Chris Rollings wrote: In launching on a C og G hook you are risking the tow-pilots life more than your own, and this I will not defend. Marc Ramsey wrote I personally prefer to fly aerotow with nose hooks, and both of the gliders I now fly have them. But, I'm not convinced that anyone has provided actual evidence of an observed safety issue with CG hooks. Some numbers like these for, say, the past 20 years in the UK: How many aerotow operations were there per year? What percentage of aerotow operations used CG hooks? How many aerotow upset accidents were there during that period? What percentage of the aerotow upset accidents involved CG hooks? If these figures aren't available, is the use of CG hooks being discouraged based simply on the assumed lack of positive longitudinal stability during aerotow? Marc I hate to agree with Chris Rollings but he sums it up quite well. The questions posed by Marc Ramsey, difficult to obtain that no one will even try, so they will not get answered. Whatever we write here, I cannot see the owners of C of G only aircraft rushing out to retrofit a nose hook. Having towed on both, the worst being an Olympia 2B with only a C of G hook and a powerful tug, I prefer the nose hook every time. Some years ago, mid 1908’s I believe, the Australian Gliding Association, following a number of tug upsets produced a very graphic illustration showing the various stages of a tug being upset by a glider on tow, wherever the hook. It clearly and simply illustrated the difficulties this caused the pilots at each end of the combination. C of G hooks merely increase the likely hood of this happening with an inattentive pilot. The short answer is educating the pilots on the particular hook to be used and hammering home the consequences of inattention to all. The Australian poster should be displayed at all gliding sites. To try to answer the question that started this thread, the B4 pilots problems could be solved by asking the tug to accelerate a little faster from the start, having due regard to the problems this may cause. IE Things may go wrong even quicker! Dave |
#52
Flying a Pik-20D some years ago I had to be very cautious in airtows because
the glider: - had a large tendency of dropping the left wing at low speed (angle of attack problem because of the large wheel and short fuselage) - had a large tendency of dropping the right wing because of prop wash - was quite unstable in pitch during the tow because of the quite backward position of the CG hook, while no nose hooh available. Nevertheless the towpilot and I survived very many tows without a serious problem. However I would not go through this once more; just to risky that something goes wrong. After the Pik-20D I flew a DG800S 18m for about 10 years. Only a CG hook and never a problem. Would do it again this way without hesitation. Just recently we (my son and I) bought a Ventus-2cxT. Nice glider. My first flight with it was on airtow. Used nosehook which we paid for seperately. No tendency of dropping a wing. However very nervous on pitch during the tow. Not a pleasure and was happy to release. I guess a novice would certainly have had problems with it. So one may say that each glider has its own way of being pulled into the air. Being towed is certainly a safety issue. So I wonder why not everybody concludes that for airtows nosehooks should be mandatory and CG hooks should not be allowed. We are talking about money I guess. We spent many thousands of euros on the glider itself and try to save some euros in not having a nose hook installed and still like to take off in an airtow. To my humble idea our lives and especially those of towpilots are to valuable to run an additional risk of not using a nose hook in air tows. Karel, NL "W.J. (Bill) Dean (U.K.)." schreef in bericht ... There have been several fatal "aerotow upset" accidents in the U.K. where it seems certain that towing on a hook intended for winch launching was a factor. These include: Lasham new year 1963/4 Auster towing a Ka 6cr or Skylark 2 (I forget which), Tug at Aboyne towing a Ka 6e, Tugs (Super Cubs) towing K 18s at Portmoak and Dunstable (within a few months of each other), this led to the tests by Chris Rollings, Verdun Luck and Brian Spreckley at Booker see http://www.glidingmagazine.com/ListF...Dtl.asp?id=327 . Will that do, or how many others do you need? Any glider which launches well on a cable using the aft launching hook, will do the same behind a tug maybe killing the tug pilot in the process. If you really think that the glider pilot can control or stop this process once it starts, READ THE ARTICLE LINKED ABOVE; I suggest that the pilots who conducted those tests were more experienced, more current and just plain better than you. To my certain knowledge it is possible to fit a forward hook for aerotow to the ASW 15, 17, ASK 18, ASW 19, 20, and 22 and the Pegase; the ASK 21 and 23 and I think later types were fitted with it as standard. I don't know of any examples of these in club (as distinct from private owner) use which have not been modified. I think you would be very wise to have your ASW 19 fitted with the approved forward hook modification before your wife flies it on aerotow. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Andy Durbin" wrote in message om... Ian Strachan wrote in message ... In article , Andy Durbin writes snip LBA certification prohibits the use of CG hook for aerotow Does not that tell you something, then? 1. With over 1500 hours in the ASW 19 I am very familiar with aero tow with CG hooks. So I have no doubt also thought the glider pilots who got out of position and killed the tug pilot. If you have data on those accidents I would be interested in seeing it. I used to be a tug pilot (2 USA clubs and 1 UK club). The only tug pilot fatalities I am familiar with that resulted from glider being too high did not involve a cg hook. Just do not come to my club and expect to tow on your aft hook, or anywhere where I am towing. I would have thought where life-and-death was concerned you could be a tad more humble about your undoubted handling abilities. But perhaps unlike the rest of us, you never have an off-day ...... One of the reasons I included the forward hook in my order was the slim chance that I would return to UK. What should I do with my ASW 19? I had planned to transition my low time wife to it but perhaps the risks are just too great. Is there an approved forward hook modification? Andy (GY) |
#53
Chris Rollings wrote in message ... SNIP Let's look at the numbers. I will use the UK as an example, since I have a fairly accurate knowledge of the statistics there, but the pricipals are the same for any of the World's gliding nations. SNIP Chris I learnt to fly at an all aerotow operation back in 1967 at the old Leicestershire club at Rearsby. Training was on a Slingsby Capstan and pupils were then sent solo in an Olympia 2b, (in my case after twenty seven flights). These of course like virtually all gliders of that time had only CoG hooks. What do the accident statistics say when comparing that period with the present day ? Don Brown |
#54
Karel,
I think you may have paid the extra for the belly hook not the nose hook. I am on the Schempp-Hirth waiting list at present and when I enquired about the cost of adding a nose hook I was told that all gliders had the nose hook as standard and that the additional cost option was for a belly hook. They would build a glider with the belly hook only for no extra cost on special request but it would be placarded as not certified for aerotowing. John Galloway At 10:30 07 January 2004, K.P. Termaat wrote: Just recently we (my son and I) bought a Ventus-2cxT. Nice glider. My first flight with it was on airtow. Used nosehook which we paid for seperately. No tendency of dropping a wing. However very nervous on pitch during the tow. Not a pleasure and was happy to release. I guess a novice would certainly have had problems with it. So one may say that each glider has its own way of being pulled into the air. Being towed is certainly a safety issue. So I wonder why not everybody concludes that for airtows nosehooks should be mandatory and CG hooks should not be allowed. We are talking about money I guess. We spent many thousands of euros on the glider itself and try to save some euros in not having a nose hook installed and still like to take off in an airtow. To my humble idea our lives and especially those of towpilots are to valuable to run an additional risk of not using a nose hook in air tows. Karel, NL |
#55
Yes John, you are right.
I looked through the papers and found that the belly hook is the option indeed. So SH does it it in the right way and tries to convince pilots to use the nose hook when on an airtow. Probably the LBA has forced them to do so. Karel, NL "John Galloway" . uk schreef in bericht ... Karel, I think you may have paid the extra for the belly hook not the nose hook. I am on the Schempp-Hirth waiting list at present and when I enquired about the cost of adding a nose hook I was told that all gliders had the nose hook as standard and that the additional cost option was for a belly hook. They would build a glider with the belly hook only for no extra cost on special request but it would be placarded as not certified for aerotowing. John Galloway At 10:30 07 January 2004, K.P. Termaat wrote: Just recently we (my son and I) bought a Ventus-2cxT. Nice glider. My first flight with it was on airtow. Used nosehook which we paid for seperately. No tendency of dropping a wing. However very nervous on pitch during the tow. Not a pleasure and was happy to release. I guess a novice would certainly have had problems with it. So one may say that each glider has its own way of being pulled into the air. Being towed is certainly a safety issue. So I wonder why not everybody concludes that for airtows nosehooks should be mandatory and CG hooks should not be allowed. We are talking about money I guess. We spent many thousands of euros on the glider itself and try to save some euros in not having a nose hook installed and still like to take off in an airtow. To my humble idea our lives and especially those of towpilots are to valuable to run an additional risk of not using a nose hook in air tows. Karel, NL |
#56
Chris,
It's very hard to argue with your point of view. There is absolutely no doubt that a nose hook should always be preferred to a cg hook during aerotow for safety reasons. As you note, resistance to regulatory change on this issue is based on cost. Retrofitting a glider designed with only a cg hook will be high. And as is often the case, a balance must be found between cost and improved safety. Which gets to my point. You've offered an overview of why individual, anecdotal experience should not be trusted, but you've given us nothing quantitative to work with. Can you show that PIO related (as opposed to control failure) aerotow take-off accidents involved a disproportionate number of gliders with cg hooks? What is the current ratio of such use among launched glider (not the whole fleet, but those flying actively)? What is the cost of retrofitting an LS-4 or Discus or other appropiate model? I'll reemphasize that we're in agreement regarding the preference for a nose hook, but if you are going to discount our collective experiece, give us some real numbers. |
#57
Andreas Maurer wrote in message . ..
On Mon, 5 Jan 2004 21:58:53 +0000, Ian Strachan wrote: In article , Andy Durbin writes snip LBA certification prohibits the use of CG hook for aerotow Does not that tell you something, then? Unfortunately the above is wrong. LBA certification prohibits the use of the CG hook in these cases: - no use of CG hook for aerotows of student pilots - no use of the CG hook if a nose hook is available - retro-fitting of nose hook NOT required. - according to the Gliding Operation Handbook (SBO) of the German Aero Club (DAeC) a pilot is required of doing at least three aerotows on a nose hook before he can do aerotows on a glider equipped only with CG hook. ... Bye Andreas Hi Andreas, The initial statement is correct because it was with reference to *my* ASW 28 which I chose to have fitted with both books. (clause 2 of your reply). Andy (GY) |
#58
In article , Andreas Maurer
writes On 6 Jan 2004 08:21:29 GMT, Ray Payne wrote: ASW 27B is only certificated for aerotow operation when the forward tow release is used! This is correct. And an ASW-27 where no nose hook is installed is certified for aerotow operation on the CG hook. ![]() A point I made in an earlier contribution to this thread seems to be being missed but I think is important. That is, where a glider has two hooks, the rear hook can be placed close to the true C of G position. With only one hook, the position will normally be somewhat forward of the C of G position and will be a compromise rather than a true C of G hook. In other postings people talk generally about "CG hooks" without making the above distinction, which could be critical to handling on the launch. "Belly hook" might be a better term, and many will not be true C of G positions unless a nose-hook is also fitted. -------------------- In more detail: Gliders with only one tow hook: The hook will be under the belly rather than in the nose, so that it can be used for both winch/auto tow AND air tow. Test and certification. The hook will be tested for both wire and air tow launches before the initial C of A is granted for the design. Testing will be at a number of glider C of G positions, the most critical being the aft CG case because it is the least longitudinally stable. The hook is unlikely to be aft enough to be strictly a "C of G" position, so that natural longitudinal stability while on air tow is maintained. This is rightly a certification requirement. During a winch or auto tow launch, a positive pull force will be needed to keep the right climb angle. With some gliders this pull force can be quite high, but at least is safe in the sense that if the cable breaks, the nose falls quickly as soon as back-pressure on the stick is relaxed. Gliders with two tow hooks: Front hook, for air tows. Straightforward. Better longitudinal stability while on tow, more directional stability before takeoff. Less tendency for a "tug upset". Better all round for air tow. Winching on a nose-hook. One of my early clubs (RAF Swinderby, near Lincoln, UK) had an old Cadet Mark 1 glider which only had a nose hook. It also had no instruments! We used to winch launch it and were lucky to get 600 feet. The back-pressure on the stick to get even this low height, was considerable. How did we know that it was 600 ft? The CFI borrowed an altimeter from the RAF Instrument Section and we carried it in a pocket, consulting it when off the wire. Those were the days ! Rear hook. Because there is a front hook, the rear hook can be placed close to the true C of G position. That is, where the vector of the pull of the wire during the main part of a winch or auto-tow passes close to the glider C of G. This minimises the hard pull force otherwise necessary to climb on a wire launch, and maximises the launch height. Flight Manual and Testing. Such a hook may not be included in the flight manual conditions for air tow and may not have been tested on air tow during initial certification testing. Back pressure during launch. During a winch launch there should be a pull force, but not a large one. At aft CG, little if any pull force may be needed on the winch and such a condition can even be neutrally stable longitudinally (relax stick pressure during the launch and the pitch angle hardly changes). Under these conditions it is easy to climb too steeply and break the wire, particularly with a heavy glider. Answer, look sideways at the angle that a wing is cutting the horizon to judge pitch angle. At aft CG it is easy to enter a spin, so careful handling is needed on cable break recovery. -- Ian Strachan Lasham, UK |
#59
Under JAR 22 (Glider Certification Rules), a glider is required to have postive (or at least neutral) longitudinal stability. Put simply, if you move the nose up (or down) a bit and then leave it alone, it should tend to move back towards where it started from, or at least stay where it is, not continue to pitch further up (or down). It is quite possible (easy in most cases) to learn to handle a glider that does not have this stability, but it requires CONSTANT vigilance on the part of the pilot. A failure in concentration of only one or two seconds can result in a massive divergence of the flight path with catastrophic consequences. Both my ASW 19 and my ASW 28 exhibit positive pitch stability for small disturbances when aero towed on the cg hook. Both gliders will fly hands off on aerotow for several seconds and will return to the trimmed pitch attitude following small upsets. You tests on kiting used very large pitch upsets and they were determined to be unrecoverable. Was any testing done to determine the largest recoverable pitch upset? Now that most gliders in UK have both aerotow and CG hooks, is there any intention to repeat the test series to compare the characteristics of the same glider with each hook? Andy |
#60
Todd Pattist wrote:
Of course, despite those comments, we also experience too many towing accidents. The CG hook can be implicated in more than the kiting accidents, and I know several pilots who have purchased or retrofitted the nose hook after a loss of directional control during the initial roll on a CG hook aerotow launch. That is exactly what prompted me to have a nose hook installed; I mean, as long as it was in the shop anyway, getting the damage from the loss of directional control fixed... -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
| Thread Tools | |
| Display Modes | |
| Tow Hook on Cessna 180 - Update | Stuart Grant | Soaring | 13 | April 10th 20 11:48 AM |
| Aero Advantage closing shop. | Eric Ulner | Owning | 51 | May 17th 04 04:56 AM |
| Tow Hook on Cessna 180? | Stuart Grant | Soaring | 3 | October 2nd 03 01:50 AM |
| Cambridge Aero Instruments Inc. Changeover | Joe McCormack | Soaring | 3 | July 30th 03 09:45 PM |
| CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 07:20 AM |
