I was trying to use Autocad to plot the airfoil shape for eventually
creating leading edge templates. In doing so I came up with a couple of questions. I started with the coordinates from the UIUC database. http://www.aae.uiuc.edu/m-selig/ads/coord/fx67k150.dat What I wanted to come out with was something like this: http://www.goddard.com/soaring/info/FX67K150.gif My attempts were to use the "spline" command in order to fair the shape through all of the points. The problem came with the leading edge area (doesn't it always!). My first attempt was to simply use the spline command for the top surface and then the bottom surface. But this left me with a hard point at the leading edge (0,0). Clearly, one needs to create some sort of 'fairing' around the leading edge. Intuition told me that I should start the spline at the trailing edge and continue it around the leading edge and along the other surface.\ But that approach came out with a leading edge like this: http://www.goddard.com/soaring/info/spline-full.gif This gave a very nice faired curve but it extends too far forward (into negative X territory) and puts the actual leading edge above the centerline. So then I plotted it with the top surface and bottom surface splines separately forcing each of them to a tangent with a vertical line at (0,0). That produced the following: http://www.goddard.com/soaring/info/spline-normal.gif Now that looks about like what I thought it would... but the questions occurred to me... What is the "official" method of creating accurate plots from the data? How was the coordinate system designed in order to be able to accurately recreate the shapes? How did they calculate this stuff before the advent of computers and CAD programs? I know they had an arsenal of 'french curves' but there seems like there would be a lot of "eyeball judgement" in that approach. Just wondering... Larry Goddard "01" USA |
The Italian "Profili" program can export dxf files that is usefull in
autocad, maybe it have to many coordinates!? but.. Jan Carlsson www.jcpropellerdesign.com "Larry Goddard" skrev i meddelandet ... I was trying to use Autocad to plot the airfoil shape for eventually creating leading edge templates. In doing so I came up with a couple of questions. I started with the coordinates from the UIUC database. http://www.aae.uiuc.edu/m-selig/ads/coord/fx67k150.dat What I wanted to come out with was something like this: http://www.goddard.com/soaring/info/FX67K150.gif My attempts were to use the "spline" command in order to fair the shape through all of the points. The problem came with the leading edge area (doesn't it always!). My first attempt was to simply use the spline command for the top surface and then the bottom surface. But this left me with a hard point at the leading edge (0,0). Clearly, one needs to create some sort of 'fairing' around the leading edge. Intuition told me that I should start the spline at the trailing edge and continue it around the leading edge and along the other surface.\ But that approach came out with a leading edge like this: http://www.goddard.com/soaring/info/spline-full.gif This gave a very nice faired curve but it extends too far forward (into negative X territory) and puts the actual leading edge above the centerline. So then I plotted it with the top surface and bottom surface splines separately forcing each of them to a tangent with a vertical line at (0,0). That produced the following: http://www.goddard.com/soaring/info/spline-normal.gif Now that looks about like what I thought it would... but the questions occurred to me... What is the "official" method of creating accurate plots from the data? How was the coordinate system designed in order to be able to accurately recreate the shapes? How did they calculate this stuff before the advent of computers and CAD programs? I know they had an arsenal of 'french curves' but there seems like there would be a lot of "eyeball judgement" in that approach. Just wondering... Larry Goddard "01" USA |
Gentlemen....
Why don't you guys do it the easy way and just plot from compufoil?? You can downloat the airfoil coordinates from the Mike Selig site, import them into compufoil and plot them at any chord length you desire. http://www.compufoil.com/compufoil.html http://www.aae.uiuc.edu/m-selig/ Scott Correa |
Establish a few more coordinates between zero and the first set of
coordinates by iteration till you are happy with the results regarding that final curve near the leading edge.( the last few to 10 thousands of an inch). I have done this a number of years ago on my acad and found that this precision is only of value if the machine is able to reproduce it, regardless of method. I prefer a template with a slight "point", when sanding, all will be taken care off. Some one maybe of help with the finer points on how to work the acad to get the spline right, with just the coordinates you have. Udo ... I was trying to use Autocad to plot the airfoil shape for eventually creating leading edge templates. In doing so I came up with a couple of questions. I started with the coordinates from the UIUC database. http://www.aae.uiuc.edu/m-selig/ads/coord/fx67k150.dat What I wanted to come out with was something like this: http://www.goddard.com/soaring/info/FX67K150.gif My attempts were to use the "spline" command in order to fair the shape through all of the points. The problem came with the leading edge area (doesn't it always!). My first attempt was to simply use the spline command for the top surface and then the bottom surface. But this left me with a hard point at the leading edge (0,0). Clearly, one needs to create some sort of 'fairing' around the leading edge. Intuition told me that I should start the spline at the trailing edge and continue it around the leading edge and along the other surface.\ But that approach came out with a leading edge like this: http://www.goddard.com/soaring/info/spline-full.gif This gave a very nice faired curve but it extends too far forward (into negative X territory) and puts the actual leading edge above the centerline. So then I plotted it with the top surface and bottom surface splines separately forcing each of them to a tangent with a vertical line at (0,0). That produced the following: http://www.goddard.com/soaring/info/spline-normal.gif Now that looks about like what I thought it would... but the questions occurred to me... What is the "official" method of creating accurate plots from the data? How was the coordinate system designed in order to be able to accurately recreate the shapes? How did they calculate this stuff before the advent of computers and CAD programs? I know they had an arsenal of 'french curves' but there seems like there would be a lot of "eyeball judgement" in that approach. Just wondering... Larry Goddard "01" USA |
occurred to me... What is the "official" method of creating accurate plots from the data? How was the coordinate system designed in order to be able to accurately recreate the shapes? How did they calculate this stuff before the advent of computers and CAD programs? I know they had an arsenal of 'french curves' but there seems like there would be a lot of "eyeball judgement" in that approach. There are several de facto file format standards for transferring airfoil co-ordinates between programs and many of them use 100 points along the chord with the co-ordinates starting at the TE for the opt surface, continuing round the LE and back to the TE. A list like this, sucked into autocad and then joined using a cubic spline starting and ending at the TE should give a reasonable result if you use, say, 10 line segments per point. The critical points a - use enough co-ordinate points - use at least 10 line segments per point - make sure you're using a CUBIC spline, not a circular spline You didn't say what format you're using to download the co-ordinates. If it doesn't suit this method and/or hasn't enough points to give a really accurate wing section you can use Martin Hepperle's ConCord program to convert the co-ordinates into a more suitable form. His web site is: http://www.mh-aerotools.de/airfoils/index.htm. Click 'Software' on the index and scroll down to ConCord for a free download. HTH Martin -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
In article , Martin Gregorie writes:
sucked into autocad and then joined using a cubic spline starting and ending at the TE should give a reasonable result if you use, say, 10 line segments per point. The critical points a - use enough co-ordinate points - use at least 10 line segments per point - make sure you're using a CUBIC spline, not a circular spline None of this will solve the problem. The real problem is that like with most early Wortmann sections, the original FX67K150 coordinates are grossly too coarse at the leading edge. A cubic spline will produce bad glitches just above and just below the 0,0 leading edge point. There are many different types of cubic spline parameterizations possible, but they all produce shape glitches with various degree of severity. What I usually do in such situations is to add points near the LE point, and then smooth the local LE shape by smoothing the local Cp(s) distribution in Xfoil at high and low angles of attack, like +15 and -10 degrees. Whether or not this produces the "correct" shape is a moot point, because the correct shape cannot be determined from the official coordinates. At least it produces a shape with a well-behaved Cp spike, which is really what matters. |
Mark is right.
If you have a CAD program that will allow you to impose tangency constraints as well as point location (like CATIA or UniGraphics), you can force the curve to be vertical at the leading edge. Now if you spline the upper and lower surfaces separately (preferably a with a B-spline of some form) along with the vertical constraint, the curve should be closer to the desired shape. It will, however, likely still produce a suction spike at the leading edge due to a jump in curvature (2nd derivative for the mathematician) at the leading edge. But if you distribute points on this new curve more densely near the leading edge, you have a better starting point than the coarse tabular data. You could then do as Mark suggests to home in on an acceptable solution. If you have a program like CATIA though, you could try one more smoothing by using the first 5 or 10% of the upper and lower surfaces as a smooth curve. If you examine the curvature (2nd derivative with respect to the arclength of the curve), you can slightly move the points near the leading edge to make a smooth transition in curvature between the upper and lower surfaces. This should remove the any spike from the pressure distribution at the leading edge. You should, however, use a code like Mark's Xfoil to check for problems with any of your airfoils. Good Luck! ...... Neal Mark Drela wrote: None of this will solve the problem. The real problem is that like with most early Wortmann sections, the original FX67K150 coordinates are grossly too coarse at the leading edge. A cubic spline will produce bad glitches just above and just below the 0,0 leading edge point. There are many different types of cubic spline parameterizations possible, but they all produce shape glitches with various degree of severity. What I usually do in such situations is to add points near the LE point, and then smooth the local LE shape by smoothing the local Cp(s) distribution in Xfoil at high and low angles of attack, like +15 and -10 degrees. Whether or not this produces the "correct" shape is a moot point, because the correct shape cannot be determined from the official coordinates. At least it produces a shape with a well-behaved Cp spike, which is really what matters. |
constraints as well as point location (like CATIA or UniGraphics), you can force the curve to be vertical at the leading edge. In Xfoil you can effectively do this by placing a point just above the 0,0 LE point, and placing another point just below. For example, change the three points at the LE... 0.001070 0.004620 0.000000 0.000000 0.001070 -0.001450 to... 0.001070 0.004620 0.0 0.00001 0.000000 0.000000 0.0 -0.00001 0.001070 -0.001450 Xfoil's arc-length spline parameterization doesn't care about the resulting very non-uniform point spacing, so these new coordinates spline OK without any difficulty. But in the case of the original FX67-150 coordinates, this still produces overshoots, with a concavity below the LE point (top looks better, but still wavy). The real problem is that the necessary geometric information is simply not present in the coarse coordinates. An adequately-smooth interpolated shape has to be literally "made up" in one way or another. |
i had no problems splining airfoils,
starting at the trailing edge, round the leading edge and stop at the trailing edge again. Easy with a Sinumerik numerical control. Just user the original coordonates as X and Y, add some parameters for speed and spline, add the radius (0.12mm) compensation for the laser and cut it out of stainless steel in any size using the scaling factor - easy. Chris BLS Bristow Laser Cutting Systems Melbourne, Australia "Larry Goddard" wrote in message ... I was trying to use Autocad to plot the airfoil shape for eventually creating leading edge templates. In doing so I came up with a couple of questions. I started with the coordinates from the UIUC database. http://www.aae.uiuc.edu/m-selig/ads/coord/fx67k150.dat What I wanted to come out with was something like this: http://www.goddard.com/soaring/info/FX67K150.gif My attempts were to use the "spline" command in order to fair the shape through all of the points. The problem came with the leading edge area (doesn't it always!). My first attempt was to simply use the spline command for the top surface and then the bottom surface. But this left me with a hard point at the leading edge (0,0). Clearly, one needs to create some sort of 'fairing' around the leading edge. Intuition told me that I should start the spline at the trailing edge and continue it around the leading edge and along the other surface.\ But that approach came out with a leading edge like this: http://www.goddard.com/soaring/info/spline-full.gif This gave a very nice faired curve but it extends too far forward (into negative X territory) and puts the actual leading edge above the centerline. So then I plotted it with the top surface and bottom surface splines separately forcing each of them to a tangent with a vertical line at (0,0). That produced the following: http://www.goddard.com/soaring/info/spline-normal.gif Now that looks about like what I thought it would... but the questions occurred to me... What is the "official" method of creating accurate plots from the data? How was the coordinate system designed in order to be able to accurately recreate the shapes? How did they calculate this stuff before the advent of computers and CAD programs? I know they had an arsenal of 'french curves' but there seems like there would be a lot of "eyeball judgement" in that approach. Just wondering... Larry Goddard "01" USA |
Mandrel for 306/-2 (1/8 in) and 471-2 fitting? | Boelkowj | Home Built | 2 | February 6th 05 02:00 PM |
S-18 airfoil | JDKAHN | Home Built | 0 | October 30th 04 04:35 AM |
can't quite grasp the "power available" curve | xerj | Piloting | 6 | September 12th 04 12:33 PM |
Straight restrictor fitting? | nauga | Home Built | 5 | April 15th 04 01:06 PM |
18m polar curve | Alan Irving | Soaring | 1 | December 15th 03 11:45 PM |
