Marc Ramsey wrote:
... It did not examine whether airborne collision avoidance systems would continue to provide warnings when confronted by such situations. ... The only such system I have heard about is TCAS. As far as I know this system is not available on gliders, only on big airplanes carrying passengers or military ones. It should emit hints to the pilot for avoiding the collision based on altitude information, assuming that the other aircraft is going to fly at a constant altitude, or to follow the hint of its own TCAS, and neither is true for a glider. |
Robert Ehrlich wrote:
The only such system I have heard about is TCAS. As far as I know this system is not available on gliders, only on big airplanes carrying passengers or military ones. It should emit hints to the pilot for avoiding the collision based on altitude information, assuming that the other aircraft is going to fly at a constant altitude, or to follow the hint of its own TCAS, and neither is true for a glider. TCAS/ACAS detects nearby transponder equipped aircraft. In the US and western Europe, almost all aircraft larger than small twins now have them. They will provide useful warning of the presence of a nearby mode C equipped glider, whether or not the glider is flying straight and level. Marc |
Marc Ramsey wrote: ... It did not examine whether airborne collision avoidance systems would continue to provide warnings when confronted by such situations. ... The only such system I have heard about is TCAS. As far as I know this system is not available on gliders, only on big airplanes carrying passengers or military ones. It should emit hints to the I've seen a $20,000 version of TCAS, with a graphic display and altitude displayed, in an acquantence's 182. It seemed a little big for a glider (display the size of a Garmin 430). And my goodness I can only imagine the power consumption! |
TCAS installed on all transport category aircraft can "read" mode "c" or "s"
and determine if a climb or descent is needed to avoid the other aircraft. The glider does not need to have TCAS installed, only a transponder, in order for the other aircafts TCAS system alert for an avoidance manuever. "Robert Ehrlich" wrote in message ... Marc Ramsey wrote: ... It did not examine whether airborne collision avoidance systems would continue to provide warnings when confronted by such situations. ... The only such system I have heard about is TCAS. As far as I know this system is not available on gliders, only on big airplanes carrying passengers or military ones. It should emit hints to the pilot for avoiding the collision based on altitude information, assuming that the other aircraft is going to fly at a constant altitude, or to follow the hint of its own TCAS, and neither is true for a glider. |
my experience is, that ATCs do not like glider pilots
as soon as they find out, that you cannot keep your flight level. In central Europe I had a transponder in the glider, to get permission to cross some controlled corridors. I mostly got permission to cross the airspace with the condition of keeping flight level! A reply of not being able to keep flight level invertet mostly the permission into refusal. The trick was then to enter the airspace first and then request for sinking to flightlevel (-2FL for the 20km). But the ATC never liked you for doing that!! I think Transponder requirement is only virtually increasing safety. You accept to install transponders and as a thank you, they will steal you some more airspace which has been free for VFR before! Chris "Robert Ehrlich" wrote in message ... Chris Nicholas wrote: An experiment in the french Alps made with a group of tow planes mimicking glider flight, i.e. circling together from time to time has shown that transponders, except in mode S, may not be very useful in gliders. As soon as 2 or more gliders are close together, e.g. circling in the same thermal of working together the same ridge, they are hit simultaneaously by the radar beam and generate simultaneaously their responses, which results in both interfering and nothing useful received at ATC. I had the chance of having one of the engineers involved in the experiment as a passenger last September and he confirmed this. In mode S, as each transponder is specifically adressable, this mess will probably not occur, a new experiment using them is planned. |
Mil80c , another point you need to be aware of; Many gliders, e.g. mine (a Ka6E), have neither panel space for a transponder nor capability of carrying any more weight for the extra batteries - I am already on max AUW, on a CofA which has already been extended as far as it can be - I am 208 pounds with a parachute, and there are plenty of heavier pilots than that. If a new generation of lightweight, low power transponders emerges (the UK CAA has persuaded one manufacturer to build a prototype which tested OK), and if ICAO accept 20 w output instead of 100+, and if the thing is taken to commercial production, and if it can come with an option of a small remote control panel I could strap to my knee, with the larger piece and battery going into the stowage behind the pilot's seat, and if I can lose enought weight to compensate for it, then it might be viable. Transponder + encoder = 1 kg 7 amphour battery = 2.3 kg ant and cable = .4 kg mounting all of it = .5 kg TOTAL = 4.2 kg or 9.3 pounds If this is what is keeping you from installing a transponder that you think you need, I suggest you take another look at your priorities. Put in the transponder by - losing 10 pounds; getting a lighter parachute; removing something from the panel; flying 10 pounds overgross and cut your critical speeds a couple of knots. Or, if you want to spend about $600-700 more, get the Filser Mode S when it's available and shave off a couple pounds using a smaller battery and no external encoder. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric, my point was - and remains - that package and weight are issues
which should not be overlooked. Most of your suggestions are not acceptable - my panel is full of things I want, I have about as light a parachute as I know of, and flying outside the max AUW is a no-no for insurance, CofA, and club rules purposes. Those might not feature in your priority list, but they do for a lot of other people. Saying I could lose weight is not very relevant - probably most of us could - but at the margin there must be some people for whom another 9 pounds is a diet too far. Of course, I could go and spend 20k, 40k, or 60k on a bigger glider as well as the several thousand k on a Mode S transponder etc.. If it were the only way to fly, I would have to look at that. Until it is mandatory, for many people (not just me, the original enquirer wanted to know the general issues AIUI) that would not be an option. And in priority lists, avoiding being killed has several other dangers more prevalent than collision with airliners, judging by the accident statistics. I am not one of those determined never to use transponders. As it happens, I can see the day coming when I will want one for my sort of flying in the place I do it, and I will have to solve the cost/package/weight issues then - but we are not yet there. I hope the technology then available will make it easier - but I am not holding my breath, as I said. Regards - Chris N. |
Eric, my point was - and remains - that package and weight are issues which should not be overlooked. True, especially if it involves a battery, the majority of the weight in the installation. It must be properly installed and accounted for in the W&B. The rest of the items aren't a problem. snip And in priority lists, avoiding being killed has several other dangers more prevalent than collision with airliners, judging by the accident statistics. Part of the reason is a lot of pilots in high risk areas use transponders. We'll never know how many collisions are avoided because of this, of course. Your situation sounds like it isn't in a high risk area. I am not one of those determined never to use transponders. As it happens, I can see the day coming when I will want one for my sort of flying in the place I do it, and I will have to solve the cost/package/weight issues then - but we are not yet there. I hope the technology then available will make it easier - but I am not holding my breath, as I said. The glacial pace of change is disappointing. It took a _long_ time for the small Microair and Becker transponders to actually hit the shelves, and the Filser has been a mirage for even longer. It looks like it will actually be available this year! So, something so very different, like a low power portable unit you can stick to the canopy with a suction cup, is likely years away. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
There are lots of excellent reasons for not requiring
gliders to carry transponders but this study seems flimsy. In NZ we often have groups of gliders flying together whilst using transponders - no problem. The main reasons for not requiring gliders to carry transponders a - if airspace is managed well they are not required in most areas. The real problem is that the groups that draw the lines on the maps give the commercial airlines more airspace than is required. For example, Auckland (NZ) airport has more airspace around it than Heathrow. - as a glider pilot I don’t want to spend my day listening to commercial pilots talking to ATC all day. I prefer to have the radio tuned to a gliding frequency or off. - most (but not all) controllers don’t understand how gliders operate. The glider pilot is often required to provide training to controllers whilst trying to fly their glider. I don’t like having to do this… “no, I am a glider which means I have no engine and thus I cannot maintain 3000ft”. - most glider pilots (including me) are not commercial pilots and are not practiced at talking to ATC. Controllers are used to speaking to commercial pilots and often become frustrated with amateur glider pilots. The also become frustrated with the unpredictable flight path of gliders. Once you agree to put transponders in gliders you are obliged to use them and they are a pain in the ass. If you only give commercial operators the airspace they need there should be plenty left over for gliders. At 18:36 22 January 2004, Marc Ramsey wrote: Robert Ehrlich wrote: An experiment in the french Alps made with a group of tow planes mimicking glider flight, i.e. circling together from time to time has shown that transponders, except in mode S, may not be very useful in gliders. As soon as 2 or more gliders are close together, e.g. circling in the same thermal of working together the same ridge, they are hit simultaneaously by the radar beam and generate simultaneaously their responses, which results in both interfering and nothing useful received at ATC. I had the chance of having one of the engineers involved in the experiment as a passenger last September and he confirmed this. In mode S, as each transponder is specifically adressable, this mess will probably not occur, a new experiment using them is planned. This study is sometimes cited as an excuse to put off installation of transponders until inexpensive mode S transponders are available. My take on it is that it addressed a fairly narrow concern, the possible inability of ATC to properly discern a group of thermalling mode C equipped gliders. It did not examine whether airborne collision avoidance systems would continue to provide warnings when confronted by such situations. The times when I've been surprised by the close approach of larger aircraft have been while cruising between thermals, when I'm generally alone or at a fair distance from other gliders. While thermalling, I have a view of pretty much the entire sky, and I have a much better chance of seeing approaching traffic in plenty of time to avoid it. Marc |
Ben Flewett wrote in message ...
There are lots of excellent reasons for not requiring gliders to carry transponders but this study seems flimsy. In NZ we often have groups of gliders flying together whilst using transponders - no problem. As I see it (and this is for the Western US, and may not apply in NZ or the UK, etc) there are really only two reasons for not carrying a transponder: No place to put it in the glider (I've been trying to figure out where to install one in my LS6 (small panel), it will take a complete redo of the panel to squeeze it in; and cost - as soon as I win the lottery (or get REALLY scared by an airliner) I will probably get one. The main reasons for not requiring gliders to carry transponders a - if airspace is managed well they are not required in most areas. The real problem is that the groups that draw the lines on the maps give the commercial airlines more airspace than is required. For example, Auckland (NZ) airport has more airspace around it than Heathrow. If you fly away from airliners, or airways, then the midair risk is obviously low. I fly right next to the Phoenix Class B and share airspace with a lot of traffic. I'm still in Class E, so a transponder isn't required and I'm not talking to ATC, but still it would be nice to be "seen" by any TCAS-equipped planes in the vicinity, especially when cruising (i.e. invisible) at high altitude (cloudbase above 18000' is not uncommon out here). - as a glider pilot I don?t want to spend my day listening to commercial pilots talking to ATC all day. I prefer to have the radio tuned to a gliding frequency or off. Same here, and since I'm VFR in Class E airspace, the only time I talk to ATC is when I think it may help - like during the week near a busy military base. Then I let them know where I am, and the controllers have always been very receptive - vectoring the fighters around me if necessary. Having a transponder would make it easier for ATC to track me, and many fighters could see me as well with their systems. It doesn't mean I would have to talk to them more. Is it different in NZ? (aside from no fighters - a shame about your A-4s and MB-339s!) - most (but not all) controllers don?t understand how gliders operate. The glider pilot is often required to provide training to controllers whilst trying to fly their glider. I don?t like having to do this? ?no, I am a glider which means I have no engine and thus I cannot maintain 3000ft?. Again, just having a transponder doesn't mean you have to talk to ATC if VFR, it means ATC will see you and know you are VFR (squawking 1200) and let other traffic know you are there. If you do decide to talk to ATC, it's that much easier for them to locate you. And the ATC controller is not controlling you, so it isn't your concern if he doesn't understand gliders - it's his, since his responsibility it to protect the airplanes that he is "controlling"; those on IFR flightplans in his airspace. Trust me, he will appreciate any "training" you can give him! (thinks - invite local ATC for a glider ride - many of them are pilots anyway and would jump at the chance!). - most glider pilots (including me) are not commercial pilots and are not practiced at talking to ATC. Controllers are used to speaking to commercial pilots and often become frustrated with amateur glider pilots. The also become frustrated with the unpredictable flight path of gliders. C'mon, if stinkpot student Cezzna pilots can do it, even glider guiders can learn to speak ATC! Try it, if you step on your johnson you can always give your buddy's identification and turn off the radio! And at the speeds we go, to ATC we aren't unpredictable, we are parked! Once you agree to put transponders in gliders you are obliged to use them and they are a pain in the ass. If you only give commercial operators the airspace they need there should be plenty left over for gliders. How are they a pain in the ass? Put in the extra battery, turn it on when you takeoff, turn it off when you land, take out and charge the extra battery. Again, this may only apply to the US, but having a transponder doesn't mean you have to talk to ATC. It means that when you do want ATC to know where you are, they will see you, and that some airplanes (those equipped with TCAS or similar systems) will have a much better chance of seeing and avoiding you. If you fly (location or altitude) where there is little commercial, business, or military traffic, a transponder will probably not help much, since most small planes don't have a TCAS-like capability. Just like most safety issues, the is a cost and risk tradeoff. Some day (unfortunately, probably due to a bad glider-airliner midair), transponders will probably be mandated, probably within certain altitudes (say, above 10,000ft within 50 miles of Class B and C, for example, with no exceptions). When that happens, we will have to solve the problem. Cheers, Kirk |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
Dual Transponders? | Scott Aron Bloom | Instrument Flight Rules | 17 | December 14th 03 05:54 AM |
Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 06:21 AM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
