Robert Ehrlich wrote:
Marc Ramsey wrote: ... It did not examine whether airborne collision avoidance systems would continue to provide warnings when confronted by such situations. ... The only such system I have heard about is TCAS. As far as I know this system is not available on gliders, only on big airplanes carrying passengers or military ones. It should emit hints to the I've seen a $20,000 version of TCAS, with a graphic display and altitude displayed, in an acquantence's 182. It seemed a little big for a glider (display the size of a Garmin 430). And my goodness I can only imagine the power consumption! |
TCAS installed on all transport category aircraft can "read" mode "c" or "s"
and determine if a climb or descent is needed to avoid the other aircraft. The glider does not need to have TCAS installed, only a transponder, in order for the other aircafts TCAS system alert for an avoidance manuever. "Robert Ehrlich" wrote in message ... Marc Ramsey wrote: ... It did not examine whether airborne collision avoidance systems would continue to provide warnings when confronted by such situations. ... The only such system I have heard about is TCAS. As far as I know this system is not available on gliders, only on big airplanes carrying passengers or military ones. It should emit hints to the pilot for avoiding the collision based on altitude information, assuming that the other aircraft is going to fly at a constant altitude, or to follow the hint of its own TCAS, and neither is true for a glider. |
Mike Raisler wrote:
TCAS installed on all transport category aircraft can "read" mode "c" or "s" and determine if a climb or descent is needed to avoid the other aircraft. The glider does not need to have TCAS installed, only a transponder, in order for the other aircafts TCAS system alert for an avoidance manuever. Ok, but the advice emitted by the TCAS in the other aircraft is based on the assumption that the glider will keep its flying level and this is not true. |
"Robert Ehrlich" wrote:
Mike Raisler wrote: TCAS installed on all transport category aircraft can "read" mode "c" or "s" and determine if a climb or descent is needed to avoid the other aircraft. The glider does not need to have TCAS installed, only a transponder, in order for the other aircafts TCAS system alert for an avoidance manuever. Ok, but the advice emitted by the TCAS in the other aircraft is based on the assumption that the glider will keep its flying level and this is not true. It is far better than no warning at all. The pilots of the TCAS equipped aircraft will at least get their heads out of the cockpit and take a look out of the windows. Marc |
TCAS installed on all transport category aircraft can "read" mode "c" or "s" and determine if a climb or descent is needed to avoid the other aircraft. The glider does not need to have TCAS installed, only a transponder, in order for the other aircafts TCAS system alert for an avoidance manuever. Ok, but the advice emitted by the TCAS in the other aircraft is based on the assumption that the glider will keep its flying level and this is not true. It's my understanding that the conflict resolution algorithm is based on much more realistic assumptions, so that climbing and turning flight of the potential threats is included. The simple assumption of straight flight might have been used in the very beginning, but no longer. If you have a recent reference that suggests otherwise, I'd like to know about it. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell skrev den Tue, 03 Feb 2004
12:15:57 -0800: It's my understanding that the conflict resolution algorithm is based on much more realistic assumptions, so that climbing and turning flight of the potential threats is included. The simple assumption of straight flight might have been used in the very beginning, but no longer. If you have a recent reference that suggests otherwise, I'd like to know about it. The algorithm is to look at a number of consecutive returns to determine a rate of closure and then divide the distance with this rate to give a 'tau' value, of time to impact should there be a collision. When this value goes below an [altitude dependant] threshold, you have a traffic advisory. Another lower [also altitude dependant] threshold, and the TCAS begins working on a resolution advisory. In other words, more or less straight but not level flight is assumed. Cheers, Fred |
my experience is, that ATCs do not like glider pilots
as soon as they find out, that you cannot keep your flight level. In central Europe I had a transponder in the glider, to get permission to cross some controlled corridors. I mostly got permission to cross the airspace with the condition of keeping flight level! A reply of not being able to keep flight level invertet mostly the permission into refusal. The trick was then to enter the airspace first and then request for sinking to flightlevel (-2FL for the 20km). But the ATC never liked you for doing that!! I think Transponder requirement is only virtually increasing safety. You accept to install transponders and as a thank you, they will steal you some more airspace which has been free for VFR before! Chris "Robert Ehrlich" wrote in message ... Chris Nicholas wrote: An experiment in the french Alps made with a group of tow planes mimicking glider flight, i.e. circling together from time to time has shown that transponders, except in mode S, may not be very useful in gliders. As soon as 2 or more gliders are close together, e.g. circling in the same thermal of working together the same ridge, they are hit simultaneaously by the radar beam and generate simultaneaously their responses, which results in both interfering and nothing useful received at ATC. I had the chance of having one of the engineers involved in the experiment as a passenger last September and he confirmed this. In mode S, as each transponder is specifically adressable, this mess will probably not occur, a new experiment using them is planned. |
Non-radar transponder codes | Michael | Instrument Flight Rules | 16 | February 13th 04 01:15 PM |
Dual Transponders? | Scott Aron Bloom | Instrument Flight Rules | 17 | December 14th 03 05:54 AM |
Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 06:21 AM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
