![]() Pee tubes are popular, followed by various baggies or containers (Gatorade bottles work just fine in a 1-34, but not at all in an LS6 I've been using Gatorade bottles in my LS6 but I want to get away from that. I had a full pee bottle bounce off of the top of the canopy once (yes, from the inside) and I don't want that to happen again. It was pretty violent and I have no idea why the canopy didn't crack. Tony V. http://home.comcast.net/~verhulst/SOARING |
Tony Verhulst wrote:
Pee tubes are popular, followed by various baggies or containers (Gatorade bottles work just fine in a 1-34, but not at all in an LS6 Pee tubes with the cutout thing at the end that looks like half a turkey baster are great. Without the encloser at the end, any mishandling of the stick can result in buying a new map. I know one guy who just wears Depends. He says it's both for relief and when he does something that scares himself (haha). Maybe this would work for the gals, too. Bags are nasty and leaky. Even the ones with that adsorbent gel stuff are gross and messy... |
Mark James Boyd wrote:
Tony Verhulst wrote: Pee tubes are popular, followed by various baggies or containers (Gatorade bottles work just fine in a 1-34, but not at all in an LS6 Pee tubes with the cutout thing at the end that looks like half a turkey baster are great. Without the encloser at the end, any mishandling of the stick can result in buying a new map. I know one guy who just wears Depends. He says it's both for relief and when he does something that scares himself (haha). Maybe this would work for the gals, too. Bags are nasty and leaky. Even the ones with that adsorbent gel stuff are gross and messy... Bombs Away! No mess, fertilize the forest, and the bags are photodegradable. Shawn |
![]() "Ted Wagner" wrote in message ... a.. Flaps or no? (I'll be flying mostly in Arizona, more x-country than local.) b.. Opinions on the Rigging Innovations P-124 emergency parachute system? (Yes, I know it's a ram-air parachute. I have much more experience on that kind of glider.) Mostly looking for feedback on comfort compared to other products. c.. What is the most popular solution to the call-of-nature problem? (A topic conspicuously absent from the x/c portions of my (two) soaring books!) Are relief tubes offered in new(er) gliders? (No, this will not affect my choice of glider.) d.. What is the best L/D of a laden swallow? -ted African or European? Tim Ward |
At 15:42 27 January 2004, Tim Ward wrote:
'Ted Wagner' wrote in message . .. a.. Flaps or no? (I'll be flying mostly in Arizona, more x-country than local.) Flaps or not may not be as significant as it once was. I am a flaps guy, but if I had a choice between a sweet LS4 with a good trailer, and a rough LS3 with a cruddy trailer- I would take the 4 in a heartbeat. A cruddy trailer will make rigging miserable. c.. What is the most popular solution to the call-of-nature problem? If you plan on flying in Arizona in the summer, you better have a system that works! KS had an article on this somewhere. Texas Catheter system can be very much a hands-off system if designed properly. |
Earlier, "Ted Wagner" wrote:
a.. Flaps or no? (I'll be flying mostly in Arizona, more x-country than local.) I like to think of it as "airbrakes or no". But let's not open that can of worms today. ![]() c.. What is the most popular solution to the call-of-nature problem? That Depends... ![]() I believe that the usual choices a Men: external catheters, zip-lock baggies, plastic bottles, diapers Women: diapers, awkward-looking funnels And some folks wonder why there are so few women in our sport. This might be TMI, but before a long flight I tape the zipper of a zip-lock baggie so it's mostly closed, and then tape a PVC pipe elbow fitting into the remaining opening. I prefer the heavy-duty freezer baggies. The baggie is generally more conformal than a bottle, and the elbow fitting helps solve the "uphill start" problem. Some folks have elaborate overboard dump tubes that they extend out of the belly of their glider so that they can pour overboard without getting pee on the glider. This is more than an aesthetic concern, since the pee is corrosive and often gets drawn into the landing gear well where it can corrode the metal undercarriage parts. Bob K. |
to the call-of-nature problem? One tip I learned the hard way- try it on the ground first!! If your solution is not leakproof it is better to find out when you can leap out of the cockpit rather than at 6000ft Once you start it is very difficult to stop and it is very uncomfortable sitting a pudddle for 5 hrs Nigel |
Bob Kuykendall wrote:
Some folks have elaborate overboard dump tubes that they extend out of the belly of their glider so that they can pour overboard without getting pee on the glider. This is more than an aesthetic concern, since the pee is corrosive and often gets drawn into the landing gear well where it can corrode the metal undercarriage parts. Or worse: it corrodes the rudder hinges and cables. The successful systems aren't really elaborate (it's just a tube sliding through a tube), but are long enough to extend away from the glider. Some do it by having the end of the tube at the back, rear, bottom corner of an extended gear door (requires the gear to be partially extended in use); some use a stiff tube that is pushed out the belly, which gets the pee far enough from the glider it doesn't land on it. It's best to look at a successful system for guidance, so you can avoid potential corrosion problems. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Ted,
Regarding c): Forget about 'relief tubes' that end outside the glider unless you attach the trailing end to your gear door. This also requires you to extend the gear before letting go. Even then I'd be concerned that the pee will make its way along the fuselage and end up corroding your rudder hinges and cables. Get a dozen or two 'external male catheters' (the friendly girl at the medical supplies place will help you find the right size. Careful, they laugh when you go for extra large and small sizes. Next you ask for the large pee bag with check valve on the infeed and manual dump valve on the out. It comes with a silicon tube around 2 feet long. The bag and tube can be used repeatedly, I rinse mine, though. I'll spare you the details of putting it all together... Seriously, this is an absolute MUST on most every flight, don't leave the airport area without it. Herb, J7 "Ted Wagner" wrote in message .. . a.. Flaps or no? (I'll be flying mostly in Arizona, more x-country than local.) b.. Opinions on the Rigging Innovations P-124 emergency parachute system? (Yes, I know it's a ram-air parachute. I have much more experience on that kind of glider.) Mostly looking for feedback on comfort compared to other products. c.. What is the most popular solution to the call-of-nature problem? (A topic conspicuously absent from the x/c portions of my (two) soaring books!) Are relief tubes offered in new(er) gliders? (No, this will not affect my choice of glider.) d.. What is the best L/D of a laden swallow? -ted -- |
In our club in hot Aussie conditions, the CFI and his mob will discus
matters with you, if you take off without adequate water, a hat and a relief system. The drop off in pilot performance due to dehydration is dramatic and has been attributed to many accident. We have professional colour charts in the toilets warning of the risks. The volume of water carried for drinking on a long flight in hot conditions is amazing. Food is another seperate issue that hopefully someone might like to start a new thread. The "****a phone" to the outside is great and perhaps a internal comtainer syastem. You must ensure secure fitting as corrosion is an issue. So is the little yellow crysals during negative G manouvers. Yes it has happened to me. Wine cask bladders with a suitable valve are Ok for ergonomically suitable gliders and people. The cut off disposable petrol filters work great with suitable sanding to a smooth surface. Catheters (called in our club Irish Condoms due to the hole in the end ) work well. All of these though are best tried on the ground or at home, so troubles are sorted ot beforehand. Good soaring Robert |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
In the plane market - some questions before purchase | Bill | Piloting | 13 | January 1st 04 01:20 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
