On Wed, 28 Jan 2004 01:44:10 GMT, "Arnold Pieper"
wrote: You shouldn't spin more than 3 turns unless you're practicing for aerobatic flight. If your purpose is International Aerobatic Club competition, you don't need to do it for that either. According to the FAI catalog of aerobatic figures, there is no spin allowed to be done with greater than 2 turns. For unknown flights at the unlimited level, the max is 1.5 turns. So I would modify what you say above to say, "you shouldn't spin more than 2 turns unless you are practicing to be a test pilot." Be safe, Klein |
The Puchacz WAS certified to JAR 22. When it was first
imported into the UK I repeated the tests, prior to the BGA granting it certification. The testing included five turns spins with the C of G at the manufacturers aft limit; recovery was normal in well under one turn. Having said that: 1. I once had a similar experience to the one described, when flight testing the Grob Twin II for BGA certification. Earlier spins at mid-range C of G had been typically Grob - self recovery after less than a turn. I expected that it would be just possible to hold it in at aft C of G. In fact the spin started to flatten after about two turns. I initiated recovery immediately, it took three turns to recover (I was considering abandoning the aircraft at that point). After lots of phone calls to the manufacturer (who said it had never happened in their testing), we resumed testing (Cautiously) and approached the aft C of G in small increments. Eventually we got to the C of G position at which I had had the problem - the spin was perfectly normal! So far I was aware, I had used exactly the same spin entry technique in both cases. Clearly there must have been some small difference (ailerons not quite central, or some such) that made an important difference. Whatever the cause, I couldn't get it to repeat, all subsequent spins were unremarkable. Rogue spins can happen, IN ANY TYPE. 2. The Puchacz described may have had some repair, or equipment change, that moved the C of G further aft, and this failed to get into the aircraft's records (appalling, I know, but it has happened). 3. The elevator deflections may have become mis-set, allowing greater upward deflection, and less downward. This can happen unintentionally, I don't know how, but it would very likely produce the result described. At 01:36 28 January 2004, Geir Raudsandmoen wrote: If you were within the permitted CoG range, and used the standard recovery method, the spin behaviour you described is definitely non-compliant with JAR 22 certification rules. JAR22.221 states that a sailplane certificated for intentional spinning must be able to recover from a fully developed spin (5 turns) within 1 turn after recovery action is done. This has to be demonstrated in several loading and control conditions. Additionally, this paragraph states that it must be impossible to obtain uncontrollable spins with any use of the controls. The Puchacz may not have been certificated to JAR 22, but possibly to the older OSTIV rules. However, I very much doubt that this type of behaviour would have been acceptable under older certification rules, although the verification/testing requirements might have been less strict in earlier days. Geir At 01:00 28 January 2004, Tim Shea wrote: I love to spin. It's exciting. I took aerobatic training with Wayne Handley and was taught spin recoveries by him. I have direct experience spinning the Puchacz at Minden. This is what I remember from my experience. Your mileage may vary. With friends (usually lighter than me) in the front, I spun it while sitting in the back seat more than a dozen times. The CG was within the published range and I didn't have any trouble with simple recovery- stick centered and forward and rudder away from the direction of rotation. Worked great. I should mention that I used to be 50 lbs heavier than I am now, but still in the published range for the plane. During the training towards my instructors rating, I spun the Puch twice with my instructor. The first 2 or so rotation spin I was able to recover normally, no sweat. The second manuver was quite different. I was asked to let the spin develop a little deeper for the second. After 4 or so rotations, the nose seemed to float up and the rotation *seemed* to slow considerably. I remember thinking that this is cool! Kind of like floating. When it was time for the recovery I applied the control inputs I'd been taught (as specified above) and much to my surprise, nothing different happened.....for a long time. I estimate that we completed another 5+ rotations nose high before it broke, rolled over and recovered. I had the stick centered and against the front stop with the rudder also pegged away from the rotation. We recovered with several (4 or 5) thousand feet under us (we'd been playing at cloudbase at about 15K). Once on the ground, we discussed this incident in the grumpy bar for at least an hour. I (and he) decided to never spin the Puch again. I didn't. I doubt he did either. I had heard of this happening before. I assumed that it was from operation outside of the design envelope. Apparently I was wrong. John Shelton probably said it best: 'On my own as a test pilot, I will certainly get killed'. I felt like a dumb-ass for quite a while (more than usual) after that. |
![]() Clearly there must have been some small difference (ailerons not quite central, or some such) that made an important difference. Whatever the cause, I couldn't get it to repeat, all subsequent spins were unremarkable. Rogue spins can happen, IN ANY TYPE. Could it be that a spinning glider is governed by laws that are not well described by more traditional linear equations of aerodynamics (or JAR-22)? I am reminded of some articles related to the loss of ships at sea to "Rogue Waves" or "Freak Waves". http://members.shaw.ca/diesel-duck/l...ogue_waves.htm Ships designed to the standard engineering models of expected maximum wave heights for the worst predicted conditions were being lost and those describing witnessing these waves at sea were dismissed as crackpots until only very recently. Now, application of a non-linear model i.e. chaos theory, seems to be describing these freak ocean waves more accurately, where there very existance was doubted until jut a few years ago. Your description of a very small variation in the initial conditions, resulting in a very much different situation describes an outcome that might be predicted by chaos theory better than some of these other explanations. The non-linear SchrÖdinger equation was originally developed in the field of quantum mechanics but is now being applied to modeling freack ocean waves. Could we be dealing with a "quantum" phenomenon when dealing with a spinning glider where it behaves nicely according to our traditional model most of the time, but every once in a while it produces a "Freak Spin" do to the complex interaction of all the forces involved? |
Bob wrote:
Clearly there must have been some small difference (ailerons not quite central, or some such) that made an important difference. Whatever the cause, I couldn't get it to repeat, all subsequent spins were unremarkable. Rogue spins can happen, IN ANY TYPE. Could it be that a spinning glider is governed by laws that are not well described by more traditional linear equations of aerodynamics (or JAR-22)? I am reminded of some articles related to the loss of ships at sea to "Rogue Waves" or "Freak Waves". http://members.shaw.ca/diesel-duck/l...ogue_waves.htm Ships designed to the standard engineering models of expected maximum wave heights for the worst predicted conditions were being lost and those describing witnessing these waves at sea were dismissed as crackpots until only very recently. Now, application of a non-linear model i.e. chaos theory, seems to be describing these freak ocean waves more accurately, where there very existance was doubted until jut a few years ago. Your description of a very small variation in the initial conditions, resulting in a very much different situation describes an outcome that might be predicted by chaos theory better than some of these other explanations. The non-linear SchrÖdinger equation was originally developed in the field of quantum mechanics but is now being applied to modeling freack ocean waves. Could we be dealing with a "quantum" phenomenon when dealing with a spinning glider where it behaves nicely according to our traditional model most of the time, but every once in a while it produces a "Freak Spin" do to the complex interaction of all the forces involved? Maybe you don't need to invoke such complex things like chaos. Things which are not taken in account by JAR-22 and usual procedure for weight and balance, as somebody pointed it, are the moments of inertia around the 3 axis of the glider. Of special importance is the moment of inertia around the pitch axis, a higher inertia around this axis favors flattening the spin. And 2 gliders may have exactly the same weight and same CG postion with different such moments. |
Robert Ehrlich wrote:
... Maybe you don't need to invoke such complex things like chaos. Things which are not taken in account by JAR-22 and usual procedure for weight and balance, as somebody pointed it, are the moments of inertia around the 3 axis of the glider. Of special importance is the moment of inertia around the pitch axis, a higher inertia around this axis favors flattening the spin. And 2 gliders may have exactly the same weight and same CG postion with different such moments. Correcting myself: what favors flattening the spin is rather the difference of the moments of inertia around the 2 other axis (roll and yaw). Practically what has influence on both (moment around pitch axis or difference between moments around the 2 other axis) is the same thing, i.e. weights in the fuselage far from CG, e.g. tail repair balanced by nose ballast. |
Reading of these brave souls who have been testing the Puchaz spinning
characteristics with multi-turn spins at high altitudes reminds me of an anecdotal rumour which reached me about at least one other glider type, and I think also some power aircraft, which similarly misbehaved until many turns/it got lower. It made me wonder a few things: At the heights people here have been writing about - 10 to 17 thousand feet - what is the true airspeed at which it enters the spin on command and how does that differ from the lower altitude airspeed used for certification tests? Bear in mind also one poster's comments that a glider does not instantly cease forward motion and go instead into vertical motion with a rotational component - in the absence of infinite forces, the first is subject to some deceleration taking time and space, and the second some vertical acceleration taking time and height. Similarly, what is the true vertical velocity at onset and when stable in the spin? What is the ratio of those two velocities compared with the ratio at test air densities? Does the rotation rate remain identical, whether at height (lower air densities) or at lower altitude (higher density)? Does all that have an effect on true angle of attack? Could such things account for high altitude spins when fully developed requiring more turns to recover? I wonder if the people who conduct these high altitude tests were in a regime not tested by the maker or the certification test pilots such as Chris Rollings? Chris N. |
I have been told two things:
1. That the Reynolds number applicable to a glider changes with altitude, 2. That the Reynolds number affects the stall/spin behaviour and recovery. I can remember an anecdote (I am vague as to who or when) about a K21 at Aboyne. The glider was at about 20,000 ft., and the crew wanted to get down for the next pupil. They put it into a spin (which it entered without difficulty), and then held the spin without moving the controls. It span down to about 7,000 ft. and then self-recovered without any change in control position. Heights are QNH. I don't understand Reynolds numbers, but I know it matters; and it would seem not only to designers. It might well be that some gliders more easily spin and are harder to recover at height. I would expect this to apply at altitudes above about 7,000 ft. QNH, above which height they are almost certainly not test flown. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Chris Nicholas" wrote in message ... Reading of these brave souls who have been testing the Puchacz spinning characteristics with multi-turn spins at high altitudes reminds me of an anecdotal rumour which reached me about at least one other glider type, and I think also some power aircraft, which similarly misbehaved until many turns/it got lower. It made me wonder a few things: At the heights people here have been writing about - 10 to 17 thousand feet - what is the true airspeed at which it enters the spin on command and how does that differ from the lower altitude airspeed used for certification tests? Bear in mind also one poster's comments that a glider does not instantly cease forward motion and go instead into vertical motion with a rotational component - in the absence of infinite forces, the first is subject to some deceleration taking time and space, and the second some vertical acceleration taking time and height. Similarly, what is the true vertical velocity at onset and when stable in the spin? What is the ratio of those two velocities compared with the ratio at test air densities? Does the rotation rate remain identical, whether at height (lower air densities) or at lower altitude (higher density)? Does all that have an effect on true angle of attack? Could such things account for high altitude spins when fully developed requiring more turns to recover? I wonder if the people who conduct these high altitude tests were in a regime not tested by the maker or the certification test pilots such as Chris Rollings? Chris N. |
W.J. (Bill) Dean (U.K.). wrote:
I have been told two things: 1. That the Reynolds number applicable to a glider changes with altitude, 2. That the Reynolds number affects the stall/spin behaviour and recovery. I can remember an anecdote (I am vague as to who or when) about a K21 at Aboyne. The glider was at about 20,000 ft., and the crew wanted to get down for the next pupil. They put it into a spin (which it entered without difficulty), and then held the spin without moving the controls. It span down to about 7,000 ft. and then self-recovered without any change in control position. Heights are QNH. I don't understand Reynolds numbers, but I know it matters; and it would seem not only to designers. It might well be that some gliders more easily spin and are harder to recover at height. I would expect this to apply at altitudes above about 7,000 ft. QNH, above which height they are almost certainly not test flown. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. So I'm a test pilot every time I fly from my home field at 7,500 ft MSL? |
On Wed, 28 Jan 2004 14:12:44 UTC, "W.J. \(Bill\) Dean \(U.K.\)."
wrote: : I don't understand Reynolds numbers They are simply a way of comparing flow patterns round gliders in different situations. If two gliders have the same Reynolds number then the flow round them will look the same - the stream lines are the same shape - regardless of the velocity. It's given by density * velocity * characteristic length / viscosity. So if you go to a high altitude (- low density) you need a higher speed for the same flow pattern [1]. Or if you make a 50% scale model (- smaller length) you also need a higher speed. But beware - Reynolds numbers can be used to compare smaller parts of aerodyamics as well. For example, separation of a boundary layer typically occurs at a particular Reynolds number based on distance from the leading edge of the wing, frontal drag from the fuselage will depend on the Reynolds number based on the mean diameter of the fuselage and so on. This is one of the main reasons people find Reynolds numbers confusing ... Ian, with his Fluid Dynamics Lecturer's hat on. [1] Yes, I know viscosity must change with pressure and density, but I can't offhand remember how! -- |
Heh, in Poland, there is a short story of two bored pilots who wanted to =
have some fun in Puchacz when returnig from a wave flight. They spun the = Puchacz from the 7000m, and kept it spinning till 2000m. When they = started the recovery, there was.... nothing, the Puchacz still spinned! Finally, they stopped after the 6'th or 7'th turn since the recovery = procedure has begun. ![]() Remember about inertia guys!!! --=20 Janusz Kesik visit www.leszno.pl - home of the www.css-leszno.it.pl |
Puchaz Spinning thread that might be of interest in light of the recent accident. | Al | Soaring | 134 | February 9th 04 03:44 PM |
Spinning (mis)concepts | Arnold Pieper | Soaring | 106 | February 7th 04 01:02 PM |
Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 01:35 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
