Do military aircraft utilize transponder signal based
collision avoidance systems? At 15:18 02 February 2004, Kirk Stant wrote: (Terry Claussen) wrote in message news:... A lousy end to what was a beautiful day of soaring, thanks to the USMC and my own lack of vigilance. Some thoughts on this incident (and comments in subsequent posts): If I hear a powerplane (any kind!) while cruising and don't see him - My response is to IMMEDIATELY throw up a wing and pull a hard S-turn. This does two things: It lets you check behind, where your greatest threat is, and throws a much bigger visual target for the approaching plane to see. And he is close enough to hear, he will probably see you. This works very well for military jets, not so well for airliners and bugsmashers, from personal experience. At the altitudes we usually fly, fighters will usually be transiting at relatively low speed (about 300 knots, perhaps 350). Down low (or high), they will be going a lot faster (450 - 600 knots) but if you are that low you are about to landout! But even at 350 knots, you have time to hear and react to the sound of the approaching fighters (this from personal experience). Note I say 'fighters' - there will almost always be at least two of them, maybe more, so do not stop searching after finding one figher - it's the wingman, not the flight lead, that is most likely to hit you (because his attention is divided between maintaining formation and clearing his flightpath). In the US most fighters will be either in relatively close formation (easy to see both) or spread out 1 to 2 miles line abreast (hard to see both). And it probably isn't the one that is closest to hitting you that you are going to pick up first, since he will be closest to nose-on. The good news is that if either figher sees you, he will warn the other to avoid you. Fighter pilots look out the window a lot, it is actually something they train at all the time. Don't count on that from airline or lightplane pilots, though! Airliners descending to land are a problem, since you absolutely cannot hear them - you have to pick them up (since they will probably not maneuver unless they get really exited!). Of course, they are big and brightly painted, so are a bit easier to see. When cruising, obviously it is most dangerous at the VFR hemispheric altitudes, but at least you should have an idea where the threat is coming from. Finally, in the US our transition altitude is 18000ft, and since most of us use the field elevation to set the altimeter (instead of calling FSS), there is going to be some altimeter discrepancies - so you really can't count on using altitude for close deconfliction. Kirk |
Gary Evans skrev den 2 Feb 2004
15:32:41 GMT: Do military aircraft utilize transponder signal based collision avoidance systems? Yes, and this does not amuse controllers as they have a fast jet blasting upwards at umpteen thousand fpm, setting off all the TCAS bells in the traffic above the sector. ![]() Cheers, Fred |
Fredrik Thörnell wrote in message ...
Gary Evans skrev den 2 Feb 2004 15:32:41 GMT: Do military aircraft utilize transponder signal based collision avoidance systems? Yes, and this does not amuse controllers as they have a fast jet blasting upwards at umpteen thousand fpm, setting off all the TCAS bells in the traffic above the sector. ![]() Cheers, Fred It depends. The newer, large transport (and tanker?) military aircraft probably have TCAS, since they are usually equipped to airliner standards. But they also will almost always be on an IFR flight plan. Fighters are a whole different bag of fish: Most have air-to-air radar that may or may not see a glider (I have seen F-16 radar detect and lock on to a glider). Some Harriers have a radar, but not all. Some fighters also have the capability to interrogate a transponder, much like ATC does; this includes F-15s and some F-16s, not sure about the radar equipped Harrier 2. In this case, a transponder in the glider will help a lot. As far as I know, no fighter-type aircraft have TCAS or similar. All military aircraft have transponders and are squawking mode 3 and mode C - but if there are two fighters in formation usually only the flight lead will be squawking - the wingman will be in STBY as long as he is part of the formation. So a TCAD or similar device in a glider may not detect all the threats. Kirk |
Kirk Stant skrev den 2 Feb 2004 11:15:10 -0800:
All military aircraft have transponders and are squawking mode 3 and mode C - but if there are two fighters in formation usually only the flight lead will be squawking - the wingman will be in STBY as long as he is part of the formation. So a TCAD or similar device in a glider may not detect all the threats. My mistake. I was reading 'transponder equipped'. And I agree, I have yet to see TCAS in fighters. No space, no way of effectively fitting it into the already complicated peacetime cognitive system without reducing the wartime capability of same. Thanks for correcting me! Cheers, Fred |
![]() If radar getting you is a problem, for boats they make fairly compact aluminum "radar reflectors" that are pretty lightweight. Dunno if they'd fit in a tail section though, kinda "ship-in-a-bottle" maybe? |
In the Washington, Idaho, Oregon area, we were told (last year, by a
military ATC person briefing us at our contest) about 20% of the big transports have TCAS or equivalent; all new ones get it; old ones are slowly being retrofitted. None of the fighters have it. A couple of years ago, a fighter pilot told me fighters can usually pick up small aircraft on their radar. He didn't comment specifically about when they are flying close to the ground, like the time Chip Garner was hit, or the crop duster fatality we had here several years ago when he was hit a few hundred feet off the ground by a fighter. If you have a transponder, and the transports are flying high enough to show on the radar (here they are often quite low during training), the military ATC will warn them of your presence. Not as good as TCAS on the transport; better than nothing! Twice, I've had two A-10s climb by me at 30 degree angles (not in MOAs, either). I believe they saw me and came up to take a look; I sure hope so, because I don't think there is any way I can see something coming that fast from below me, and so quickly. Gary Evans wrote: Do military aircraft utilize transponder signal based collision avoidance systems? -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Eric Greenwell skrev den Mon, 02 Feb 2004
09:09:04 -0800: Twice, I've had two A-10s climb by me at 30 degree angles (not in MOAs, either). I believe they saw me and came up to take a look; I sure hope so, because I don't think there is any way I can see something coming that fast from below me, and so quickly. They insist on painting the buggers green, grey and all kinds of strange colours that can't be seen too! We share our field with a helo batallion and the eggbeaters are really hard to pick out against the backdrop of forest! Strange, those military types. Why don't they paint them neon? ![]() Cheers, Fred |
Indiana National Guard pilot killed in midair collision | Otis Willie | Military Aviation | 0 | June 17th 04 08:08 PM |
Aviation Consumer and Collision Avoidance | BHelman | Products | 52 | April 23rd 04 05:35 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"China blamed in '01 air collision" | Mike Yared | Naval Aviation | 8 | September 15th 03 05:07 PM |
"China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 06:08 PM |
