JJ,
Again you demonstrate your somewhat tenuous grasp of the facts and geography.. There is nothing legally stopping someone operating and flying gliders outside of the BGA umbrella in the UK or even the bit called england. I'm happy to carry on listening to you talk out of your arse by email, but I suspect we're boring the rest of group.. Mark At 15:12 09 February 2004, Jj Sinclair wrote: Mark wroteI pointed out that the government did not require us to do anything, and the BGA (the SSA equivalent) made those decisions in a fully deregulated manner unlike you guys with the FAA all over you.. Mark, The BGA IS the government, you just don't realize it. You MUST do what the BGA says, if you wish to fly gliders in England. We don't have to do ANYTHING the SSA tells us to do. I believe your government (BGA) is telling you to do 2 turn spins in both directions, on initial check-out and every spring thereafter. Most of our instructors, exercising their freedom of choice, teach spin recognition and spin avoidance. We feel that ANY spin accident that accured after the glider was intentionally put into a spin, can NOT justified. JJ Sinclair |
On 9 Feb 2004 09:17:28 GMT, Mark Stevens
wrote: In my opinion any comparison with the withdrawal of spin training for US PPL's is invalid, power pilots do not routinely fly at high angles of attack, and tend not to use the rudder in most phases of flight. They also tend not to make the number of outlandings glider pilots do and tend not to have the same problems to solve in the pattern.. Do you fly power? I got my power licence after 27 years gliding. Where do you get the idea that power pilots don't use the rudder? Rudder is used as required. In most power planes not much rudder is required because of the design of the ailerons and the short wings but it is still required if you want to keep the ball in the middle. Put a well trained power pilot in a glider and he might take a couple of minutes to figure it out but that is about all. He probably will take a little longer to do good coordinated continuous steep turns but that is only because glider pilots do many more than power pilots do. Hopefully power pilots don't do many outlandings but I was impressed by the amount of time spent during training on forced landings and then you have a far worse problem than in a glider. JJ might fill you in on use of rudder at high AOA in power planes like the F4. Mike Borgelt |
Errr
Mike..in answer to your points... I don't have much power experience, but people I have flown with and coverted to gliders include an ETPS graduate, a lightning pilot and ex RAF low level aerobatics champion and a number of high hour ATPL's - and I've listened intently to what they've said during the conversion process.. Perhaps I should have excluded fighter and aerobatic pilots specifically from my comments, but I did not say spam can pilots never used the rudder nor that they never fly at high AOA.. During my own power training in the UK (again post learning to glide like you) I was not terribly impressed with the forced landing training. As has been said here before glider pilots spend most of the time flying in the lower 40% of the speed range of their airframe and power pilots (F4's, world record attempts, test flying, excursions into outer space and so on excluded) spend most of the time in the upper 40% of their speed range.. I normally respect your opinion on these sort of things, but I do wish you would read what I wrote and not what you thought I wrote.. Mark At 21:36 09 February 2004, Mike Borgelt wrote: On 9 Feb 2004 09:17:28 GMT, Mark Stevens wrote: In my opinion any comparison with the withdrawal of spin training for US PPL's is invalid, power pilots do not routinely fly at high angles of attack, and tend not to use the rudder in most phases of flight. They also tend not to make the number of outlandings glider pilots do and tend not to have the same problems to solve in the pattern.. Do you fly power? I got my power licence after 27 years gliding. Where do you get the idea that power pilots don't use the rudder? Rudder is used as required. In most power planes not much rudder is required because of the design of the ailerons and the short wings but it is still required if you want to keep the ball in the middle. Put a well trained power pilot in a glider and he might take a couple of minutes to figure it out but that is about all. He probably will take a little longer to do good coordinated continuous steep turns but that is only because glider pilots do many more than power pilots do. Hopefully power pilots don't do many outlandings but I was impressed by the amount of time spent during training on forced landings and then you have a far worse problem than in a glider. JJ might fill you in on use of rudder at high AOA in power planes like the F4. Mike Borgelt |
Kirk,
These are my experiences as a trainee... When I learnt to glider, all my spin training was done from straight from 2000' aerotows. My instructor pulled the nose up booted the rudder in and over we went.. Over time he allowed me to do the same. My thoughts at the time were that if for some reason I pulled the nose up hard I would not boot the rudder in and wondered why anyone would.. A few months later I had changed clubs and was flying with an instructor who first demonstrated how nose low spins could happen.. The first time we did this at 1000' ft I had an almost irresitable urge as the world went green/brown to pull back on the stick.. That was one of the most memorable moments of being instructed.. Mark At 14:18 10 February 2004, Kirk Stant wrote: (Mark James Boyd) wrote in message news:... W.J. \(Bill\) Dean \(U.K.\). wrote: 'As this training progresses, it is necessary to introduce brief spins where the ground is noticeably close. This reminds me of the old FAA requirement to practice twin engine-out procedures (Vmc demonstration) at low altitudes during multiengine training, the reasoning being the low performance of the existing twin-engined trainers required a low altitude in order to have any single-engine climb available to show. Apparently, this killed a LOT of pilots due to stall spins at low altitude in light twins - not fun with an engine caged! - until the FAA decided that the cure was a lot worse than the disease. Sure, with a really experienced instructor, and a really trusted glider, a low altitude spin could be 'safely' demonstrated. But I'm not totally convinced that it is necessary for the lesson to sink in. OTOH, in the context of spin training, it is absolutely vital to beat into the students head the nasty impact (pun intended) of a surprise low altitude departure. You guys (the Brits) can possibly get away with it, due to much more standardization (a good thing). I would hate to see it adopted in the US, where standardization is a one of dem big woids we aint learnd in skool. How about our French, German, Dutch, etc. colleagues - How low do you teach (or demonstrate; not necessarily the same thing) low altitude spin entries? BTW, don't forget 1812 (we still need to burn 10 Downling Street) and Suez (Now there was a virtuous war!). Just joking, we love you man! Kirk |
Mark,
Along the lines of - 'why is divorce so expensive? because it's worth it' ..:-) Mark. At 18:12 08 February 2004, Mark James Boyd wrote: Mark Stevens wrote: A couple of years ago a friend and I were sitting in a bar on the 4th of July in Houston and got chatting to some of the locals.. They gleefully reminded us what they were celebrating... We commented we had come over for that very purpose.. LOL. Even the wife thought that one was witty... (she usually only laughs when I trip over something). |
On 2/8/04 5:18 AM, in article ,
"Mark Stevens" wrote: And of course here in the UK we look with some amusement at...the preventative affect on crime of a prison incarceration rate about eight times the european average. If we just had a distant land, peopled only by a few aboriginals, to which we could send those misfits, I am sure it would be much more economical than sheltering and feeding them here at our expense. Our surrounding moat is also a bit narrow, in some places non-existent, and I'm sure that reflects badly somehow on our judgment and character. Perhaps you Brits would be willing to take on a few of tens of thousands of these excessively incarcerated individuals. Surely, you can make peaceful productive citizens of them simply by offering free medical care and an environment in which their potential victims have almost no means of defending themselves. If there were any imperfections or glaring anachronisms in UK culture, I'm sure I would be not only unqualified to criticize them but also totally uninterested, since I neither live, vote, nor pay taxes there. Your expertise on matters social has been noted however, and I trust you won't mind our calling on you to help us find our footing in the swamp of inadequacy and despair in which we find ourselves. When you have taken a goodly number of those unfortunates (whom we have so obviously failed) and made them welcome as members of your glider syndicate, perhaps you would be so kind as to report on your progress in teaching them to spin Puchaz, and thereby draw this thread back on topic. ----- Jack ----- |
At 16:00 08 February 2004, Jj Sinclair wrote:
Mark, I guess it comes down to a matter of government control, doesn't it? You Brits require fully developed spins and us Yanks allow our instructors to demonstrate and instruct as they see fit. You Brits collect all the guns and us Yanks allow our citizens to protect themselves. You Brits force everyone into a state health care system and us Yanks allow our citizens to choose. It all comes down to a matter of freedom to choose, didn't we fight a war with you chaps over this? I'm sorry, but I can't resist this even though it's a bit off-topic: (deliberate misinterpretation) the only war we fought with you (the one about independence) we lost. The other one involved the UK in conflict that was more about securing middle eastern resources and oil for the west and protecting a bunch of magpies living on the coast of the mediteranean sea than it was about protecting us from WMD's. The arguments being presented now about how wonderful it is that a despotic regime has been removed ignore the fact that the same regime was heartily supported through the 80's by the US and the UK, amonst others. Bring it on... Rgds, Derrick. |
Derrick,
I just activated my time machine and its now 1938. Now, do we DO something about Hitler or just let him involve us in another world war? Our recent war had more to do with removing a Hitler type threat, than anything to do with oil. JJ Sinclair |
Mark Stevens wrote in message ...
Chris, Some gentle reminders about reality here in the UK.. Mark, no need to be gentle. I can stand a good pummeling, so long as its delivered with skill and panache. Mine was an honest reaction to yet another account of a pilot being asked to intentionally spin a glider at low altitude by a flight instructor certified by the BGA. I would expect this of maverick instructors in the US, but I had been given the impression that the BGA did a much more successful job of homogonizing training practices. Spin training is good. Stall recognition and recovery is better. The two together, with emphasis on the latter and careful instruction in the former is best. I think we're on the same page here. |
Inside A U.S. Election Vote Counting Program | Peter Twydell | Military Aviation | 0 | July 10th 03 08:28 AM |
