Puchaz spin - now wearing 'chutes
Old February 11th 04, 07:23 PM
Dave Houlton
Bill Daniels wrote:
"Jim Harper" wrote in message
om...
Mike Borgelt wrote in message
some snippage
The whole ship chute concept is a bit of a worry. There you are in a
large heavy object with absolutely no control. With a personal chute
you do have steering on most rigs nowadays.
With a whole ship chute would it just ruin your day to have save and
then hit the high voltage lines, fall out of a tree, fall over a cliff
etc?
some MORE snippage
Mike Borgelt
Actually, Mike, on that we disagree.
Unless you are using a square canopy for your personal chute, you have
very little choice on where you are gonna land...and hitting the tree,
high voltage lines or over the cliff are gonna suck less if you have
some aluminum or fiberglass around you. Well, that was my decision for
sure.
Oh, and keep in mind that as I disagree with you, I do it with all due
deference to someone as distinguished in our sport as yourself (no
sarcasm, I meant that!)
OK, crank these numbers. Consider my Nimbus 2C (Experimental, so I could
install a BRS) at 650 Kilos with water (which takes 5 minutes to dump). The
gear strut will give 30mm on impact and the tire will give 50mm more. The
cockpit shell is just fiberglass with no crush structure.
I pop a BRS at 300 meters AGL with the surface wind at 15 knots. What are
my chances? Give BRS weights, 'chute diameters and descent rates.
Bill Daniels
Hi, Bill.
Too many variables there to calculate for me, but I did visit the BRS
site to gather some data. Their 680 kg. capacity system is 13.5m in
diameter, weighs 16kg, and claims 7.6 m/sec descent rate @ 5000' density
altitude. So in your proposed situation you're going to land with about
a 15kt vertical component and a 15kt horizontal component. Translating
that into G-forces and survivability I'll leave up to someone more
knowledgeable...
OTOH, I'm glad you picked this particular scenario, because I think its
exactly where a BRS system would be invaluable. You're at 300m AGL in
an unlandable ship - you pull the BRS handle and 2-3 seconds later you
are under canopy. In the same situation what are your chances of
popping the canopy, unbuckling, bailing, and deploying your chute in
time? Now what if you're spinning, tumbling, or pointed straight down
without an elevator?
At a sufficient altitude where egress time isn't a big factor, I think
the personal vs. BRS calculation could go either way. The closer you
are to the terrain at the time of the 'incident', the more a BRS system
looks like the only game in town.
All IMHO,
Dave Houlton
Old February 11th 04, 08:11 PM
Bill Daniels
"Dave Houlton" wrote in message
could
The
The
are
Bill Daniels
Hi, Bill.
knowledgeable...
Dave Houlton
OK, Dave, good numbers.
This asks me to add 16 Kilo's (35 pounds) to the non-flying parts of the
glider for which I get a 15 knot descent rate when deployed (Maybe less
since I will be dumping ballast like crazy.) With a 15 knot wind I would
probably whack an obstacle at 20 knots. (Probably survivable - with
injuries.)
BTW, if I'm getting dragged by an open 'chute in that 15 knot wind, how do I
dump the 'chute?
I seem to recall that the price of this system is about $3500 - presumably
not installed. What would be the installed price?
Bill Daniels
Old February 11th 04, 08:35 PM
Eric Greenwell
could
My understanding is the "whole glider" German rescue systems will lower
the glider nose down at about 40 degrees or so. If it is more level, it
is likely to oscillate wildly so much the descent and impact can't be
controlled. So, the landing gear is irrelevant, but the cockpit
structure is extremely important. The nose must absorb the "landing".
A Nimbus 2 might be a poor candidate for installing a system that won't
be tested, except when you really need it. Your safety might be better
served by selling the Nimbus and buying newer glider with a more crash
tolerant cockpit. At least in the US, crashing while landing (meaning
the last 100' of altitude) still claims more pilots than unsuccessful
bailouts.
change "netto" to "net" to email me directly
Eric Greenwell
Washington State
USA
Old February 11th 04, 09:37 PM
Bill Daniels
"Eric Greenwell" wrote in message
could
The
The
are
bailouts.
Eric Greenwell
Washington State
USA
OK, good info Eric - now we are getting down to it.
To summarize the thread so far:
The BRS requires a reinforced cockpit to absorb the non-trivial landing
impact forces. Most accidents involve premature termination of tow or
landing errors where a BRS 'chute wouldn't help anyway. Or perhaps,
mid-air collisions at an altitude where a personal 'chute is the equal for a
BRS for survivability.
A BRS is likely to require non-trivial pilot training and discipline in its
operation and maintenance. Injuries should be expected with the used of
either personal or BRS 'chutes.
On the other hand, taking the 'chute off the back of the pilot and putting
it on the glider adds significantly to ergonomics and comfort. The BRS can
be deployed at low altitudes where a pilot with a personal 'chute is
unlikely to make a successful egress. This altitude band favoring a BRS
probably expands where the pilot is old or infirm.
Maybe it's something to think about on a new glider but retrofitting an
older glider is problematical. A BRS is perhaps a useful option but not a
panacea. I remain skeptical but open to ideas.
Bill Daniels
Old February 12th 04, 12:00 AM
Eric Greenwell
bailouts.
I think that's a good summary. For me, it's not possible because I have
a motor glider. That also excludes about half the German production.
I don't think the on-ground safety aspects are difficult - remember,
these units have been used successfully (BRS lists 159 saves so far) in
ultralight aircraft for many years and they have systems for the Cessna
150, 172, 180, and Cirrus, so it's not like the basic system is new.
Eric Greenwell
Washington State
USA
Old February 12th 04, 01:24 AM
Jim Harper
"Bill Daniels" wrote in message ...
Bill Daniels
Hi, Bill. Please don't take what follows in any sort of argumentitive
way. I've played out the scenario you describe in making my decision
to buy the BRS. As I reread it, it sounds harsh, but it certainly
isn't meant harshly...just heart-felt. Thanks for taking it in the
spirit it is intended...Dave answered the primary question you had...a
15 knot collision with the earth is gonna hurt for sure. However let's
put you in your Nimbus, busted...at around 980 feet, plummeting
earthward at...oh, let's just say...80 mph. You need to pull your
ripcord at a minimum of, what, 350 feet? That would be
borderline...I'd rather try it at 500 feet. Ok, you have (117 fps
down) 3-4 seconds to open (jettison) your canopy, unfasten your belts
and get out of and away from your glider and pull the ripcord. Pretty
much half the amount of time it took to read that last sentence out
loud. Do you really think you can? Add the g-forces associated with
any significant damage and just making the decision...If you can, you
are a better man than I.
Put me in the same position in my BRS equipped glider...I need to
reach over my right shoulder and pull...much the same move as your
first move to jettison the canopy...but in a different direction, of
course :-). I am now under canopy. I am hanging nose down (I figure
around 45 degrees or so) I've got (around 22 fps down) 20 seconds
(assuming I wind up under canopy at 500 feet) to get my landing gear
down, tighten my straps, brace and take the impact. The glider hits
nose first (with an impact which is a significant fraction of the
total force...let's call it 75% of the force...so about what I would
get by running into a brick wall at 12 mph), and the rest of the force
is dissipated by the glider rotating down to the landing gear...one
would expect that it would take the rest with minimum loading on my
body.
I'm hurting but alive, most likely. You're dead, most likely. God
forbid either one of us explore this scenario...but I prefer my
chances over the non-BRS equipped glider.
Old February 12th 04, 03:22 AM
Here is a link that shows Jim's HP-16 BRS installation.
http://www.soaridaho.com/Schreder/HP...S_in_HP-16.htm
The HP-16's stub box spar across the fuselage is ideal for a BRS
application.
om...
could
The
The
are
Bill Daniels
body.
Old February 11th 04, 08:29 PM
Mike Borgelt
On 11 Feb 2004 08:50:00 -0800, (Jim Harper) wrote:
Mike Borgelt wrote in message . ..
some snippage
etc?
some MORE snippage
Mike Borgelt
sure.
I figure that the choice with a personal chute is small but with a
whole ship chute it is zero.
The guy who taught me to pack a chute gave me escape instructions from
the glider and then said "enjoy the ride" as you were likely to be
confused and shocked anyway. He wouldn't have been as his real job not
long before had been giving the Viet Cong a hard time as a member of
the Australian SAS.
The other problem with whole ship chutes is that there is no room for
them - the engine occupies that space!
I once saw a movie of the BRS drop test on a C150 simulating its
arrival under a deployed BRS chute. I doubt that the Cessna was
useable again even though it was a symmetrical level attitude when it
hit with no drift. I'd hate to hit at a similar descent rate in a
glider. In Oz we've had a few people do hard landings in the last
couple of years. Some are considered lucky to be walking but the
gliders are repairable. Air bags may be essential.
Are your gliding club members smart enough to avoid inadvertent
deployment of a ballistic chute in the hangar? At one club I used to
belong to the new ASW20B got wheeled up twice in a month or so - in
the hangar as people said "what does this lever do?". In the chute
case you would hope nobody else was standing behind the wing looking
into the cockpit.
About 12 years ago we did a precision altimeter project for an RAAF
test project. The chief aero engineer of the research and development
unit was building an ultralight of his own design. I asked if he was
fitting a BRS chute. He said he was designing the aircraft basically
to high enough standards that like a FAR 23 power plane it was
reliable enough in its structure and control systems that flying
without a chute was a good risk. His opinion was that the whole ship
chutes at the time couldn't meet their claimed descent rates with the
chute sizes used. His first job had been with a parachute manufacturer
so I had to take some notice of his opinion.
Mike Borgelt
Old February 12th 04, 02:02 PM
Jim Harper
snip
Of course I would expect that the glider wouldn't be reusable after
using the BRS...I would only pull the thing is a situation that would
lead to me leaving the airplane, should I have had a parachute. In
that case, the airplane is a write-off. As I have previously
recounted, I have the thing set up to lower the airplane nose down
somewhat...one hopes that the forces will be somewhat dissipated by
the landing attitude. Of course the risk of injury exists for a
successful bail-out as well. It's interesting that in this dialogue
folks worry about hitting under canopy IN the glider, and don't
discuss the myriad of risks associated with hitting under canopy OUT
of the glider.
I parachuted in the military and in sport. I have seen more than a few
broken bones, broken backs, internal injuries and others. And those
were with trained parachutists jumping under controlled situations and
the best possible conditions, with prepared...or at least
planned...drop-zones. I don't think that to be the case for the
typical emergency bail-out from a broken glider.
We've had this debate on this board more than once and in each case,
it seems to me that we set a double standard...somehow we assume that
the guy who leaves the glider and deploys a round canopy for his first
parachute jump ever will arrive on the ground unscathed...and the guy
who pulls the BRS lever is subjecting himself to an extraordinary
amount of risk, because he _might_ hit the ground in a manner that
_might_ lead to injury.
The reality is that when the decision to deploy either your personal
canopy OR the BRS is made, your only other option is very likely
death. If I can fly the airplane, I am going to fly the airplane. If
my airplane is damaged beyond the point that I can fly it, I am going
to deploy. If when I land I am injured, I still firmly believe that I
am going to be far better off than if I had ridden the glider to the
ground without a parachute. And no question...if I had room in the
cockpit/no weight constraints, I would ALSO wear a square emergency
parachute for those cases where I AM high enough to choose that
egress. I think that I would STILL have the BRS, though, for the
collision in the pattern or the like. And I have far more experience
under a parachute canopy than 99% of glider pilots.
into the cockpit.
The BRS system has a remove before flight safety pin. With the pin in
place, the BRS cannot be deployed. If some yahoo starts playing with
my glider and REMOVES the safety tag/pin and then pulls the handle? I
would, under those circumstances, hope he DOES have his face in front
of it. He will certainly have exceeded any reasonable "what does THIS
lever do" level of curiosity in my book.
Mike Borgelt
One hopes one's glider isn't going to go poof in flight. However,
certificated gliders HAVE gone poof in flight. Further, our sport has
a much higher (at least theoretical) risk of collision in the air than
the usual spam-can. My glider is better built than most of them out
there, and I don't carry the BRS in expectation of a wing
spontaneously folding up. Nor do I plan on running into someone in a
gaggle. But if it happens, I am comforted in knowing that it's there.
BRS parachutes DO meet their claimed descent rates. Look at their
data. They have tested these things extensively. I would suggest that
an aero engineer who had worked for a parachute manufacturer may have
had a bias just like any other fellow...and that WAS 12 years ago. I
guess that if you are making a decision based on one person's opinion
during the last millenium, no matter how experienced, well, more power
to you. I prefer doing a bit more research than that. Once again, with
all due respect, and no offense intended.
Old February 12th 04, 04:28 PM
Eric Greenwell
into the cockpit.
THe BRS web site says it is a 35-40 pound pull, a rather stout effort,
and well beyond what you need to collapse the gear on an ASW20B. A key
lock could be used to prevent removal of the safety tag and pin, if one
is really concerned.
Eric Greenwell
Washington State
USA
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
Puchaz spin count 23 and counting henell Soaring 116 February 20th 04 12:35 AM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
