Thanks for ideas on drilling a centered hole!
Old October 21st 04, 12:57 PM
Rip
Or, you could put a drill bit the diameter of the rod in the drill
press. Drill into a well clamped piece of wood. Remove the bit. Insert
the rod into the hole you just made. Now the rod is concentric to the
chuck. Almost as accurate as a lathe, and no center-finding required.
Scott wrote:
Haven't made the tool yet, but I think I've narrowed it down to 2
possibilities. Either put the rod inside a piece of sqaure tubing and
scribe two lines across from opposite corners in which case the lines
will cross at the center of the square tube and thus the center of the
rod as well...or the method mentioned where the drill bit gets attached
to the drill press table and the rod gets chucked in the drill. The
only thing is that I think this method would make it as though you were
trying to with the drill motor reversed which might not make the
drilling action happen too fast ... have to try it and see...
Scott
Del Rawlins wrote:
On Sun, 17 Oct 2004 15:28:57 +0000, Scott
Man, you guys are the greatest! Now this is how this newsgroup (and
all others) should be!! Helpful, curteous, non-political, etc. I
got a lot of great ideas on how to accomplish the task! Harry K.:
Great saying! I only need to build ONE, so making ONE alike ought to
be a piece of cake LOL!!
So how did you do it?
Del Rawlins--
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Remove _kills_spammers_ to reply
Old October 24th 04, 06:18 PM
lou hinshaw
MUCH ADO ABOUT VERY LITTLE.
I owned a machine shop, many years ago, and all the machinists
used a technique which was faster and easier than layout.
use 2 drill bits. One the size of the rod and the other the size of
the rod to be holed.
Drill thru a piece of half inch thick bar stock, say an inch wide,
using the small bit. Then using this hole as a pilot, drill halfway
thru with the large bit.. Then vise up the rod, set the bar stock
down on it and drill thru the pilot hole. Instant drill bushing.
FWIW
Lou Hinshaw Good inventor, lousy salesman. AADD victim.
Tulsa Oklahoma
On Wed, 20 Oct 2004 10:54:02 +0000, Scott
Scott
Old October 25th 04, 02:52 AM
Morgans
"lou hinshaw" wrote in message
FWIW
Tulsa Oklahoma
Damn, that's a keeper. Easy and quick. The only trick is to have a bit the
size of the rod! ;-))
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004
Fairing question... Tina Marie Home Built 5 July 16th 03 12:18 AM
