LINUX flight software
Old February 26th 04, 03:04 PM
André Somers
John Gilbert wrote:
Angular guages perhaps. Sweeps of 180 to 270 degrees are quite
readable, I agree. But what does the study say about altimeters with
dual needles, that rotate multiple times? How many times have you
misread the altitude or had to think hard to get it right? This has to
be the most confusing instrument to read, unless you don't really care
about knowing about that last +/- 1000 feet.
Well... hardly ever, but maybe that's because our meters are, well, in
meters :-) That means a full spin round is 1000m. Not something you'd
easily misjudge I think.
André
Old February 26th 04, 04:28 PM
Bill Daniels
"André Somers" wrote in message
André
I've flown airplanes with metric instruments (And Russian placards too).
The airspeed, rate-of-climb, RPM, manifold pressure were no problem.
Numbers is numbers I guess - fly with the needles in the green arc and
everything works. But that damn metric altimeter was impossible - no way to
read trends on an instrument that insensitive. With an altimeter that reads
1000 feet (304.8 meters) per rev of the big hand, you can thermal by
watching the trend of the needle.
Responding to "YO": Some people like analog gauges and some don't.
Ergonomic studies just produce averages which may be useful to marketeers
but what's important individually is what works best for that particular
user. If the data are displayed on an electronic screen, the user can
select the display method in a setup dialog box. i.e. check box one for
round gauge analog, box two for vertical tape with a digit window etc...
Check another box for metric or imperial units. With altitude in meters,
expanding the scale of a vertical tape gives the same sensitivity as with
imperial units.
I've also flown with both vertical tapes and round gauges. At first the
tapes were confusing but once adapted to the idea of having all the "V"
speeds floating alongside the tape with the trend indicators, going back to
round mechanical gauges seemed like the stone age. I vote for computer
graphic displays of primary flight data.
Graphical displays are inevitable anyway since all those little watchmakers
who built and repaired mechanical instruments are all retired or dead now.
Bill Daniels
Old February 26th 04, 07:26 PM
Martin Gregorie
On Thu, 26 Feb 2004 09:28:30 -0700, "Bill Daniels"
You've just solved a mystery for me: thanks.
The most confusing altimeter I've flown with was a two pointer job but
with 3000 ft per rev of the big hand. I found it difficult to read
rather than insensitive.
I always wondered why anybody would build such a confusing instrument
but now I understand. Looks like they retained the gear train from a
metric instrument while changing the bellows and scale to make it read
in feet, 3000 ft per rev.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old February 26th 04, 09:56 PM
André Somers
to
reads 1000 feet (304.8 meters) per rev of the big hand, you can thermal by
I prefer to thermal on my "butt-feeling" and my audio variometer. I don't
need my altimeter for that. I guess that might be different in regions with
stronger thermals than we have to make due with here. I guess I could get
used to other scales as well (did fly a Sedhberg with Imperial instruments
once, real fun to fly 26 knots or so :-) !)
Personally, I would not trade by old, reliable mechanical primairy
instruments for a computerised system so easily. Not in a glider anyway.
Battery power alone is just not reliable enough for primairy
instrumentation in my opinion. It's fine for navigation, climb optimizing
and other stuff you don't really need to fly safely, but not for altitude
or airspeed.
André
Old February 27th 04, 07:41 PM
Robert Ehrlich
This is why I like to fly the few gliders in my club where both type of
altimeters (meter and feet) are installed. By the way, as a quick way
to make the difference between them we call the second one an "altipied",
which could be transtalted as "altifeet". So I look on the metric instrument
when I have anything to think about glide ratios, as vertical an horizontal
distances are so in the same units (and this instrument is set at QFE) and
on the other one for anything about airspace (set at QNH or flight level)
or when I need self encouragement during climb, as the rotation of the
needle is perceptible at a glance when the climbing speed is good.
Old February 26th 04, 05:48 PM
tango4
I used to fly a grob twin that had an altimeter marker 3000m per rotation.
Now that instrument was *really* a pain!
Ian
André
Old February 26th 04, 02:53 PM
Dave Nadler YO
Thanks Bob. I'd cite Donald Norman's "The Design of Everyday Things".
Amazing what you read on R.A.S. sometimes ;-)
Best Regards, Dave
PS: Not covered in the references: You can pick up motion trends during
a scan off analog meters, but not discrete indicators (LCD). All the above
is why we (ILEC) continue to use mechanical round dials despite their being
the highest cost single component and not as reliable as the alternatives...
(Bob Kuykendall) wrote in message . com...
Earlier, Robert Ehrlich wrote:
The "normal" instruments are very easy to
interpret (it has been shown that round dials are by far the easiest to
comprehend for the human brain: judging angles is easier than judging a
distance or reading and interpretting a figure.)
Not obviuous for me...
The assertion that angular guages are easier to read is backed up by
countless perception and human factors studies. It is also
corroborated by studies of the stimulation network pre-processing that
takes place right in the retina at the back of the eye.
Human factors texts such as McCormick's, and physiology texts on
sensation and perception deal with this topic at great length.
Thanks, and best regards to all
Bob K.
Old February 26th 04, 04:18 PM
Tony Verhulst
Best Regards, Dave
Maybe it's just personal preference. I have both a digital and a
traditional altimeter and find myself using the round dial exclusively.
Like wise, my current watch has hands. I much prefer it because I don't
have to read it - just scan it.
Slightly off topic, I remember reading about a (pre-digital) military
transport where the flight engineer's station was designed so that when
everything was operating normally, all dials pointed in the same
direction. It almost trivialized detecting abnormalities.
Tony V "6N"
Free Flight Planning Software Dean Wilkinson Products 0 September 18th 04 10:44 PM
Flight instructors as Charter Pilots C J Campbell Piloting 6 January 24th 04 07:51 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
