Glider Pilot Network wrote:
------------------------------------------------------------ Newsgroup: rec.aviation.soaring Subject: 12 Volt DC input Battery Charger Author: Paul Repacholi Date/Time: 08:30 14 March 2004 ------------------------------------------------------------ (d b) writes: Check the model airplane folks. They have some very fancy chargers that can be used to field charge from a 12V source. Not cheap. They are for fast charging NiCd or NiMH cells. Put one on a lead acid gell cell, and you will kill it! They range in price, and capability. Some are indeed only for Nicad or NiMH, but some also have settings for lead acid cells. I have a Graupner UltraDuo II, and it more than satisfies the needs of all these cell types. Of course the problem with gell cells is that the maximum charge rate is limited by the cell construction, so "fast charge" may not actually be what you expect. Out of interest, the charger mentioned is not limited by the 12v input source - it is capable of charging up to 30 cells (42v) as a pack, with maximum charging current of 5A (I'm quoting from memory - none of my packs are that large, so check the actual specs before commiting yourself to anything!). Rgds., Paul |
| Thread Tools | |
| Display Modes | |
| RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 02:19 AM |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| 12 Volt DC input Battery Charger | Michael I Green | Soaring | 2 | March 15th 04 03:52 AM |
| Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 07:32 PM |
| Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio | A. Kay | Aviation Marketplace | 0 | August 23rd 03 09:01 AM |
