There is no legal requirement to comply with the AD.
The insurance company may say that the owner/operator did not practice due diligence by not complying with the manufacturers recomendation but. I recall a PIK-20 that was destroyed by failure to connect the elevator a number of years back. It was totaled and they replaced it. Any insurance guys out there have an opinion on this? |
Gee,
Since my(our) premiums pay for these claims, when does the insurance company not have to pay? |
Stewart Kissel wrote:
Gee, Since my(our) premiums pay for these claims, when does the insurance company not have to pay? Most of us buy insurance to protect us from accidents, including ones we contribute to, and the policies I've bought (generally from the SSA insurer) do this. The insurance company lays out the things they will not pay for in the policy; generally, this would include things like fraud, a non-covered pilot flying the glider, non-payment of the premium, deliberate damage by the policy holder, and probably things like acts of war and perhaps radioactive contamination, but it's been a while since I studied my policy. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
Stewart Kissel wrote in message ...
Gee, Since my(our) premiums pay for these claims, when does the insurance company not have to pay? When you haven't done what you are supposed to: current BFR and annual inspection. IMPORTANT: The A/P who signs off on the annual MUST be registered and current. Most of us assume that the guy in the shop has done all of the necessary paperwork, but when was the last time you actually checked the guy's credentials? Probably never. Well, if he is faking it your insurance company can (and probably will) deny the claim. You can check his credentials with the FAA. The same thing goes for the CFIG who signs off on your BFR. If you think that you can claim ignorance or "acting in good faith", well you can forget it. This falls into you either comply or you don't. Period. Of course, you can always gamble that your insurance company won't catch it. In this case: GOOD LUCK! You can always sue the offending A/P or instructor, but the odds on this tactic are poor at best. Tom Seim Richland, WA |
At 21:06 04 April 2004, Martin Gregorie wrote:
On Sun, 04 Apr 2004 11:40:06 +1200, Bruce Hoult wrote: In article , Stewart Kissel wrote: http://www.ntsb.gov/NTSB/brief2.asp?...00417&ntsbno=C H I04CA090&akey=1 That looks more like: 'if the manufacturer issues an AD [1], you'd probably better do it, whether you legally have to or not'. -- Bruce [1] in this case, installing a locking device onto L'Hotellier connectors. This is the subject of a BGA AD in 1993 for the ASW-20, so I don't see where you get the 'manufacturer AD' bit from, even though it does appear in ASW-20 TN-17 on extending the service life beyond 3000 hours. As the AD in question refers to the requirement for a locking pin in the Hotellier, I'm a bit gobsmacked that these couplings could ever have been used without a locking pin or shroud: there's no way you could inspect the check hole after assembly (other than poking something through it) on wing control circuits in the ASW-20 and other gliders. Admittedly you can see the check hole for the elevator, but that's the only one that is easy to check by inspection on a '20. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : Martin, You can see some of the check holes through the hatch relatively easily (the airbrake ones as I recall). I was always under the impression that the requirement for the pin was because the spring loaded wedge could get gunged up with old greasy crud to the point where the spring would not push the wedge (or the spring could break through fatigue and the wedge could work loose). I always felt safest if, having fitted the pin, I pushed the wedge up against the pin and gently tried to pull the L'Hotelier off the ball (as a check against the cup/wedge being worn enough to detach). |
On 5 Apr 2004 08:35:48 GMT, Andrew Warbrick
wrote: You can see some of the check holes through the hatch relatively easily (the airbrake ones as I recall). Those are the only ones that offer a side view: the flaps and aileron connections show their topsides to the hatch - hence my comment, as you'd really need a light and mirror to do the visual check. I was always under the impression that the requirement for the pin was because the spring loaded wedge could get gunged up with old greasy crud to the point where the spring would not push the wedge (or the spring could break through fatigue and the wedge could work loose). I always felt safest if, having fitted the pin, I pushed the wedge up against the pin and gently tried to pull the L'Hotelier off the ball (as a check against the cup/wedge being worn enough to detach). My '20 has spring locking shrouds (I never can remember their correct name) on all Hotelliers except the elevator, which has a pin. Like you, I do a rattle test on the Hotelliers after assembly and before doing positives: checking for wear is a good point, but I use the test mainly as a check that all the springs are holding things in place. -- martin@ : Martin Gregorie gregorie : Harlow, UK demon : co : Zappa fan & glider pilot uk : |
At 08:42 06 April 2004, Andy Henderson wrote:
Well! He's lucky to get away with that! Yes, a talk is required. Not a bollocking, but a sensible talk as to the the cause and solution of the problem. Let's not forget the tug pilot and others on the ground could have been killed. Therefore the matter can not just be left to the 'competition' pilot. I wonder what solution he came up with in the few minutes between launches. The only acceptable one would have been to fit safety pin's to all L'Hotellier fitting's. Positive checks would not always have found the problem which causesd this accident. 'The safety pin or wire prevents the locking plate from backing out and thus allowing the socket to inadvertently disengage from its corresponding ball'. Do some of you still fly without safety pins? If you do don't you are risking your own and other's lives. Lets hope we all have a safe season. Happy flying! Regards Andy The spring prevents the locking plate backing out and thus allowing the socket to inadvertently disengage from its corresponding ball. The pin prevents three things. 1. If the mechanism is bunged up with crud the spring may not be strong enough to move the locking plate so the socket may be only over the ball, not locked (should be possible to verify this by trying to pull the socket off the ball). 2. The spring may be broken through fatigue allowing the locking plate to back out (you should be able to feel this by verifying that the spring pushes the locking plate to the end of its travel when released). 3. If the socket is not properly engaged the locking plate will not be fully home and the hole will not be visible, fitting a pin cures this problem but so does a visual inspection of the holes. As I understand it, the AD was issued in response to an incident where the spring was either broken or insufficiently strong to move the locking plate in a gunged up connector. I never flew my 20 without pins, but then I fly in a country where the airworthiness organisation issued an AD requiring pins to be fitted. If I were in a country where this was not mandatory then I would consider flying without pins as long as I had verified that the locking plate was moving freely, the spring returned it to the end of its travel and felt strong enough, that the hole in the locking plate was clearly visible with the L'Hotelier fitted and that the socket would not pull off the ball and the pin on the end of the ball was proud of the slot in the socket (on the flap, airbrake and elevator connections of the 20). However, in the case under discussion, the fitting of the pins was not a factor, the complete failure to connect the elevator was the problem, having a pin on a bit of string won't save you in this case. It's also worth noting that a loose pin can be almost as dangerous as a disconnected elevator. The pilot I bought my share in the 20 from contemplated bailing out on one occasion when the elevator safety pin worked its way far enough out of the hole in the L'Hotelier to foul on the structure of the fin and prevent full elevator travel, fortunately with the application of a bit of brute force the pin bent and he regained control. You should make sure that the pin cannot work its way out in this fashion. Regards, Andrew |
| ELT Checks | Kevin Chandler | Owning | 28 | September 16th 10 03:47 PM |
| Formation flying | Bingo | Home Built | 21 | August 23rd 04 01:51 AM |
| ~ 8 MORE DEAD US SOLDIERS - 93 IN APRIL SO FAR - BUSH CHECKS TURKEY | MORRIS434 | Military Aviation | 0 | April 22nd 04 10:44 AM |
| A couple Questions-Ramp Checks and Experimental Operations | Badwater Bill | Home Built | 48 | October 8th 03 10:11 PM |
| Flight Checks | Mark Jackson | Instrument Flight Rules | 5 | September 24th 03 07:39 PM |
