#111
K.P. Termaat wrote:
Started this thread (Avoiding Vne) some weeks ago with a kind invitation to respond to the idea of pulling the airbrakes while still in the rotating mode of a spin. The idea behind it is when rotation has been stopped with the glider at a pitch angle of say 60° or more this will be at a lower speed then when the airbrakes stay closed all the time. Possibly a build up of speed to over Vne can then be avoided after that. Of course airbrakes should be closed again in the following pull up manouvre. Any comments? well... after 114 answers, I think you have good specimens of the very diverse opinions that have been expressed so far ;-) in short, mine is : apply full airbrakes just after applying the initial spin recovery control inputs, and keep them out during dive (gentle) pull out... -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
#112
Hi Denis,
If I understand you well you will wait with pulling the airbrakes until the glider has stopped its rotation and then carefully put some back pressure on the stick. I was considering the idea of pulling the brakes with the glider still in its rotation mode in order to keep forward speed as low as possible at any time. However this may frustrate the spin recovery action; I just don't know. What's your idea about this. Of course handbooks do not say anything about this. B.t.w. my provisional handbook for the Ventus-2cxT forbids spin exercises. My idea is to avoid spins with this glider any time anyway; however I will try to get some feeling about the glider's behaviour close to entering this "acrobatic" flying mode. Karel, NL "Denis" schreef in bericht ... K.P. Termaat wrote: Started this thread (Avoiding Vne) some weeks ago with a kind invitation to respond to the idea of pulling the airbrakes while still in the rotating mode of a spin. The idea behind it is when rotation has been stopped with the glider at a pitch angle of say 60° or more this will be at a lower speed then when the airbrakes stay closed all the time. Possibly a build up of speed to over Vne can then be avoided after that. Of course airbrakes should be closed again in the following pull up manouvre. Any comments? well... after 114 answers, I think you have good specimens of the very diverse opinions that have been expressed so far ;-) in short, mine is : apply full airbrakes just after applying the initial spin recovery control inputs, and keep them out during dive (gentle) pull out... -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
#113
At the risk of flogging this subject to death it should
be remembered that this thread was started with the question on how to avoid reaching excessive speeds. While extending airbrakes and/or dropping the wheel may help the only really effective way is to use gravity to slow down the glider as opposed to accelerating it. The priority is to prevent reaching excessive speeds, not necessarily what to do if they are reached, when options may be very limited. Those who have said that pulling excessive G beyond the design limits can cause failure are right. Those who have said that exceeding VNE and getting into the flutter envelope can cause failure are right. The title of this thread is 'Avoiding VNE' and what I have said has always been directed at this. It is clear that at very high speeds in excess of VNE you are in danger of flutter and catostrophic overstress and the Nimbus accident shows that. The accident report only gives a probable cause, did the wing fail because of the excess G or did flutter cause the break up, I suspect no one really knows. What we do know is that the higher the airspeed the more G can be applied. Bearing in mind that we are trying to avoid VNE, because of flutter and the danger of excessive G forces the sooner the speed can be reduced the better. The lower the airspeed when full control is applied the less the load which can be applied. (The report of the Nimbus accident seems to indicate that the airspeed was very high indeed) I advocated using the elevator to prevent further acceleration even if this applied a G load in excess of the placarded limit to reduce airspeed or at least prevent further acceleration. What we do know is that flutter can and has caused the breakup of aircraft (and as I have said before, bridges). Flutter is the result of high speed. We also know that the higher the airspeed the greater the load that can be applied and I accept that at speeds in excess of VNE these loads can exceed the ultimate design load. Conversely at lower airspeeds it may not be possible to apply a loading above the placarded limit. Ergo, pulling hard before the speed gets excessive is better than allowing the speed to build and then trying to do something about it, especially when the situation could be complicated by the onset of flutter with total loss of control (see comments made earlier by manufacturer). It may be possible to exceed the design G limit of the airframe at VNE but it will be almost impossible at 60kts. I re-stress my suggestion was directed at avoiding high speeds, given the choice of having to apply excessive load or exceeding VNE I would choose the former. The risks involved in allowing the airspeed to increase are far greater than the risks involved in controlling the airspeed by a smaller excessive loading at the lower speed. It really is a case of the lesser of two evils, best to avoid the situation in the first place. At 07:12 06 April 2004, Denis wrote: Don Johnstone wrote: OK taking your point about the Nimbus 4. Exactly why did the wing break, because of pilot induced overstress or because of overstress caused by flutter? What did the crew say in evidence? I have no information except the link that have been provided by Bill earlier in this thread : http://www.ntsb.gov/NTSB/brief.asp?e...12X19310&key=1 The likliest cause of the outer wings failure seems to be pulling out of the dive beyond extreme load, since the observed wing bending (45°) correspond to that expected by the manufacturer for ultimate load limit NTSB Identification: LAX99MA251. The docket is stored on NTSB microfiche number DMS. 14 CFR Part 91: General Aviation Accident occurred Tuesday, July 13, 1999 in MINDEN, NV Probable Cause Approval Date: 9/30/02 Aircraft: Schempp-Hirth NIMBUS 4DM, registration: N807BB Injuries: 2 Fatal. The glider broke up in flight during the recovery phase after a departure from controlled flight while maneuvering in thermal lift conditions. Airborne witnesses in other gliders who saw the beginning of the sequence said the glider was in a tight turn, as if climbing in a thermal, when it entered a spiral or a spin. With a 45-degree nose down attitude, the speed quickly built up as the glider completed two full rotations. The rotation then stopped, the flight stabilized on a northeasterly heading, and the nose pitched further down to a near vertical attitude (this is consistent with the spin recovery technique specified in the Flight Manual). The glider was observed to be pulling out of the dive, with the wings bending upward and the wing tips coning higher, when the outboard wing tip panels departed from the glider, the wings disintegrated, and the fuselage dove into the ground. Several witnesses estimated the wing deflection reached 45-degrees or more before the wings f ailed. Examination of the wreckage disclosed that the left and right outboard wing sections failed symmetrically at 2 locations. The glider is a high performance sailplane with an 87-foot wingspan and is constructed from fiber reinforced plastic (FRP) composites. The manufacturing process uses a hand lay-up of carbon and glass materials with applied epoxy resins. The glider is certificated in the normal category in Germany under the provisions of the European Joint Airworthiness Regulations. Pilots with experience in the Nimbus 4 series gliders stated that the glider was particularly sensitive to over input of the rudder control during turns due to the 87-foot wingspan, with a resulting tendency for unwanted rolling moments. The manufacturer reported that to avoid undesired rolling moments once the bank is established the ailerons must be deflected against the bank. Maneuvering speed (Va) is 180 km/h (97 kts) and the AFM notes that full control surface deflections may only be applied at this speed and below. Never exceed speed (Vne) is 285 km/h (154 kts) and control deflections are limited to one third of the full range at this speed and a bold print cautionary note reads, 'Avoid especially sudden elevator control movements.' The manufacturer reported that design dive speed (Vd) is 324 km/h (175 kts). The manufacturer also said that, assuming a 45-degree nose down attitude with airbrakes closed, the glider would accelerate from stall speed to Vne in 8.6 seconds, with an additional 1.8 seconds to accelerate from Vne to Vd. While no specific information on stick force per 'g' was available, certification flight test data showed that the elevator control stick forces were relatively light, with only 11.9 pounds of force (nose down) required to hold a fixed attitude at Vne versus the neutral stick force trim speed of 135 km/h (72.89 kts). Detailed examination of witness marks and other evidence in the wreckage established that the pilot extended the airbrakes at some point in an attempt to slow the glider during the descent prior to the break-up. Concerning limitations on use of the airbrakes, the AFM notes that while airbrakes may be extended up to Vne they should only be used at such high speeds in emergency or if the maximum permitted speeds are being exceeded inadvertently. The manufacturer noted that the airbrakes function like spoilers and have the effect of shifting the aerodynamic loads outboard on the wings. The control linkages for the airbrakes and flaps are interconnected so that when full airbrake deployment is achieved, the flaps are extended to their full down limit. The maximum maneuvering load factor limits (in units of gravity or g's) change with variations in glider speed and flap/airbrake configuration. From a 'flaps up' configuration at Va to the condition of airbrakes and flaps extended at Vne, the maximum maneuvering load factor limits decrease from positive 5.3 to a positive 3.5. The pertinent certification regulations require a minimum safety margin of 1.5 above the design limit load, which is defined as ultimate load. Review of the manufacturers data on safety margins in the wing spar disclosed that in the area of the primary wing failures, the structural design safety margin ranged between 1.55 and 1.75. The manufacturer supplied data of the wing deflections under various load and aerodynamic conditions. At the design load limit (3.5g's) with airbrakes extended and at Vd, the wings were deflected to a 31-degree angle. At the ultimate load limit, the deflection was 46.5-degrees, similar to the witness observations of the wing deflection just prior to the break up. An extensive series of scientific investigations were undertaken to establish: 1) if the structure as built conformed with the approved production drawings; 2) that the wing design met pertinent certification standards for strength safety margins; and 3) whether or not the failures occurred in overload beyond the ultimate load limits of the structure. While production control type discrepancies were found in the structure that differed from drawing specifications, none contributed to the failures. The testing established that the structure as built exceeded the minimum safety margin requirements. All the wing failures were overload in character and occurred at loadings well above the ultimate design load limits. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: The pilot's excessive use of the elevator control during recovery from an inadvertently entered spin and/or spiral dive during which the glider exceeded the maximum permissible speed, which resulted in the overload failure of the wings at loadings beyond the structure's ultimate design loads. Full narrative available Index for Jul1999 | Index of months -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
#114
K.P. Termaat wrote:
Hi Denis, If I understand you well you will wait with pulling the airbrakes until the glider has stopped its rotation and then carefully put some back pressure on the stick. I was considering the idea of pulling the brakes with the glider still in its rotation mode in order to keep forward speed as low as possible at any time. However this may frustrate the spin recovery action; I just don't know. What's your idea about this. Of course handbooks do not say anything about this. the ASH 26 handbook does say "spinning is not noticeably affected by extending the airbrakes paddles, but it will increase the height loss when pulling out, and is therefore less advisable" I suppose the last sentence refers to loss of total energy (i.e. after recovery you will re-gain more height if you made it without airbrakes than with). It is not true of height loss down to lowest point (you will loose less height with airbrakes because the diving speed is diminished and the curving radius is reduced by the square of the speed -- even with 3.5 G allowed w/ airbrakes instead of 4 G w/o the height loss should be lesser with airbrakes out -- -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
#115
Yes, but we still don't know, whether there was any speed margin left. It seems very much that the
major factor in destroying the craft was fear of exceeding Vne and consequently pulling up too hard. But nobody knows now. One interesting thing is written there about airbrakes: "Detailed examination of witness marks and other evidence in the wreckage established that the pilot extended the airbrakes at some point in an attempt to slow the glider during the descent prior to the break-up. Concerning limitations on use of the airbrakes, the AFM notes that while airbrakes may be extended up to Vne they should only be used at such high speeds in emergency or if the maximum permitted speeds are being exceeded inadvertently. The manufacturer noted that the airbrakes function like spoilers and have the effect of shifting the aerodynamic loads outboard on the wings. The control linkages for the airbrakes and flaps are interconnected so that when full airbrake deployment is achieved, the flaps are extended to their full down limit." Outboard is where the wing broke "Denis" wrote in message ... Don Johnstone wrote: OK taking your point about the Nimbus 4. Exactly why did the wing break, because of pilot induced overstress or because of overstress caused by flutter? What did the crew say in evidence? I have no information except the link that have been provided by Bill earlier in this thread : http://www.ntsb.gov/NTSB/brief.asp?e...12X19310&key=1 The likliest cause of the outer wings failure seems to be pulling out of the dive beyond extreme load, since the observed wing bending (45°) correspond to that expected by the manufacturer for ultimate load limit |
#116
At the risk of reviving a flogged horse, does anyone find this part of the
analysis strange: "The control linkages for the airbrakes and flaps are interconnected so that when full airbrake deployment is achieved, the flaps are extended to their full down limit." What do you think the extension of full flaps at hight speed does to the load distribution and the strength of the wing structure? Allan |
#117
I believe that with the airbrakes open your safe positive
G-limit reduces to +2.5G. This is because you are forcing most of the lift to be produced near the tip and thereby increasing the wing bending moment at the root, and there is also a hell of a shear force produced. God knows what happens if you open them suddenly above Va while pulling 3.5g but i suspect it would not be pretty. (I also suspect that it may be this that caused several big gliders to have wings come off in spin recovery) I once saw a discus, 'A' I beleive, due a high speed low pass and half way through his pull up, which seemed to be agressive, deploy his airbreak/spoiler (?). I thought for sure his wings from the airbreaks out were going to snap off as they had a significant greater angle of 'bend' than the rest of the wing. I don't know why, but I know what I saw. Don |
#118
ADP wrote:
At the risk of reviving a flogged horse, does anyone find this part of the analysis strange: "The control linkages for the airbrakes and flaps are interconnected so that when full airbrake deployment is achieved, the flaps are extended to their full down limit." What do you think the extension of full flaps at hight speed does to the load distribution and the strength of the wing structure? If the ailerons follow the flaps, this would cause the G loading to increase (higher lift configuration), while shifting the load towards the tips (not instantaneously, but very soon thereafter) because the spoiler effect. If the ailerons don't follow the flaps, the G loading would increase but not as much, and the load may or may not be shifted to the tips, because the inner section would have the higher lift configuration. I don't think the strength of the structure would be changed by the flap deflection. -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#119
Todd Pattist wrote:
I don't think you can, but I admit I haven't gotten out my Matlab and done the equations. Anyone else want to do it? Depends on what you bet ;-) -- Denis R. Parce que ça rompt le cours normal de la conversation !!! Q. Pourquoi ne faut-il pas répondre au-dessus de la question ? |
#120
"Andy Blackburn" wrote in message ... snip I've heard of several cases of control surface flutter in sailplanes (often older ones with looser control circuits - and Grobs with poor mass balancing). I've not heard of sailplanes fluttered apart in flight (though this isn't to say it has never happened). Maybe it's because everyone who has been forced to make a choice pulls the wings off first. Something to think about... IIRC, Yugo built Open Cirrus at Inkpen UK. Pilot bailed successfully low while ascending (believe it was Irvin EB80 parachute) following a beatup as the glider fluttered to pieces (horizontal stab?). Think this was the incident that resulted in AD for the lowering the Vne on all the Yugo built Open Cirruses to something like 95 knots. Don't recall it ever being modified. There was also an AD to fit the original Open Cirruses with a rudder damper to prevent flutter. Wings were once tested to 11g's I've heard. Frank Whiteley |
| Thread Tools | |
| Display Modes | |
| Avoiding Shock Cooling in Quick Descent | O. Sami Saydjari | Owning | 32 | January 21st 04 05:32 AM |
| Avoiding gliders | Stefan | Piloting | 16 | August 6th 03 06:44 AM |
