Our club Discus has a spot for a battery just aft of the rudder pedals
but the straps are MIA. Is it safe to make new straps or use Velcro for attaching the battery hold down? Brian 17 |
as long as you're not flying it that way!
seriously.....even smaller 7 amp batteries weigh 7 pounds or more....any crash could result in several G's, even at 7-8 G's that's equal to a force of 50 or more pounds suddenly coming from this battery alone.and most crashes would be more severe...I've seen batteries held in with Ty-wraps, Velcro, even packing and double sided tape...Velcro may be easy, but do you really need to risk this? tim "Brian Iten" wrote in message ... Our club Discus has a spot for a battery just aft of the rudder pedals but the straps are MIA. Is it safe to make new straps or use Velcro for attaching the battery hold down? Brian 17 |
The Ventus and Nimbus arrangement for this battery box is a pair of
glasfibre plates with turned over tops that are spread to fit the battery and spring back to hold it in place. Schempp or their agents may have a replacement pair for you. Ian "Brian Iten" wrote in message ... Our club Discus has a spot for a battery just aft of the rudder pedals but the straps are MIA. Is it safe to make new straps or use Velcro for attaching the battery hold down? Brian 17 |
Remember weight and balance if you fit something weighing
3 kilos that far forward. John |
There hasn't been a battery used in that position for
some time as the battery location is behind the seat. I was thinking about carrying a small back up battery in that position if I could find the OEM hold down straps and I would definatly re-weigh the glider for a new weight and balance. Thanks for the comments and suggestions, Brian 17 |
I would not think a complete re-weigh would be required, but at least a
mathematical correction to the current weight and balance should be logged, with information for CG with and without the battery in place. BT "Brian Iten" wrote in message ... There hasn't been a battery used in that position for some time as the battery location is behind the seat. I was thinking about carrying a small back up battery in that position if I could find the OEM hold down straps and I would definatly re-weigh the glider for a new weight and balance. Thanks for the comments and suggestions, Brian 17 |
| Thread Tools | |
| Display Modes | |
| Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 05:30 PM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
| Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 07:32 PM |
| All Czech built Discus grounded | Paul | Soaring | 0 | September 14th 03 03:22 AM |
| Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 10:12 PM |
