Your description of the accident was very articulate and sobering.
I would like to hear more about the bailout. In particular: 1. What was your approx. altitude (AGL) at collision. 2. How difficult was it for you to exit the glider and how much altitude did you lose in the process. 3. What was your attitude when you pulled the rip cord. 4. Did you have any problems separating from the glider. 5. What brand of chute did you have. 6. Did you have any injuries landing in the trees. 7. What problems did you have getting down to the ground after landing in the trees. 8. Did either glider have an ELT. thx, Tom Seim Richland, WA |
Paul
Thank you for your very honest posting. A major revelation is that you believe that GPS/cockpit instrumentation was *not* the cause of the incident. Ian |
Paul and Will's family have my sincere sympathy. What a horrible
tragedy to have to live through, and live with. But if any good is to come out of such a horrible event, it is for the rest of us to try and learn how we might reduce the chance of another such tragedy. For that, Paul and the other posters have my gratitude. A few thoughts on that topic: 1. While greater use of the radio probably would have prevented this accident, no one has mentioned the pressure we all feel to minimize such use so as to not interfere with other pilots who also need the frequency. There just aren't enough air-to-air frequencies for all of us to be in constant contact with nearby gliders on a busy day. Anyone who uses 123.3 or 123.5 as much as they need to always know where their flying buddy is will get chewed out for overuse of the frequency. But there is a solution. Get the people you fly with to get their ham licenses and radios, or more simply and cheaply (but less range - but hey, we're talking about midairs) the unlicensed FRS radios. I just bought two of the latter for well under $100 at Costco since my most frequent flying buddy has them. I'm also waiting for him to get his ham license. 2. While, as noted, GPS can be a distraction if misused, it is also invaluable for collision avoidance. If both gliders have the same destination dialed in, they can give bearing and distance to quickly determine when they are in close proximity to one another. Visual references are much less precise. 3. The European PPT post at first left me thinking, "not much use", but as I'll explain below, more thought led me to think it may have a lot of merit. I, as many others, have thought that a low cost device like that described was a much better approach than the expensive ones being pursued by the powers that be. If it was portable, there would be no need for a 337 or other paperwork. The big problem, and the one that made me have an initial negative reaction to the utility of the idea, is the "chicken and egg problem." The device is of no use until a significant fraction of the fleet has one, and who wants one before it is useful? So what made me change my mind? The realization that gliders, or other planes, that fly in close proximity to one another could benefit immensely from the device even if no one else had it but those two aircraft. If it were available for a few hundred dollars (and in large quantity production there's no reason they should cost even that much -- except for the possible liability and patent issues mentioned in the PPT slides), I suspect I could convince my frequent flying buddies to get them too. And, maybe that's the way to get over the chicken and egg problemfor them to be useful for general midair collision avoidance. If we ever reached the point that a significant fraction of the whole fleet bought them to avoid hitting their flying buddies, then they'd become even more useful. 4. The last point has to do with complacency. When put that way, it sounds too mundane. We all know the danger of compacency. Or do we? On reflecting on this thread, I realized I needed to be less complacent in ways that hadn't hit me before. I have had a similar situation to Paul and Will's, where I was flying in close proximity to a friend, one of us moved away, neither of us had the other in sight, I was concerned, but felt that one more radio call just to confirm that all was OK would sound compulsive or amateurish. After all, I've been in that situation many times, with no ill consequences. And none of the other guys flying close to one another are constantly checking. Just listen to the frequency. So I didn't call on the radio for fear of becoming a nuisance either to my friend or the others on the frequency. But after being a part of this thread, I am committing to being extra wary of doing that again. One of the problems with complacency is that it wears many disguises, in this case that of the competent pilot. In this disguise, we believe that only a rank beginner or scaredy-cat would be constantly giving in to his fears of "where did he go" and hitting the PTT each time. Hoping these thoughts are of some help. Martin |
I'm sure almost every RAS reader has read every word of Paul's account
because we all have been in the same situation numerous times and could see the same thing happen to us at any moment. I have a lot of soaring books but it is interesting that little is written or formally taught about this aspect of soaring. Outside of the basic rule of gaggle flying in the same direction as others, I think we need a stamdard protocol for any proximity or formation flying which we all rouinely do. Outside of stall/spin in the pattern, mid-airs during proximit/formation flying (including gaggles) is likely the next most dangerous situation we activily place ourselves in. 1. What is the safest way to enter a gaggle, and what are the most unsafe ways? 2. If you lose sight of another glider that you are gaggling with, should you keep thermalling or head away? (assume no radio available) 3. What is the safest way to exit a gaggle, and what are the most unsafe ways? 4. Pair flying - best practices and worst practices ....? Let's express our best ideas here and perhaps this too will save lives. I do know that these recent events have caused members of our local club to immediately begin studying our local methods and habits, which I think this activity will result in some pretty healthy positive changes. |
I'll tell ya, I use the radio and stomp the ground
controller at towered fields sometimes for collision avoidance. I've had several near misses, and seen one guy flip his plane in front of me because I was too timid to get on freq and warn him we were about to collide. I was in disbelief that he wasn't seeing me and avoiding me. I'd say get on the radio and use it per your judgement, and ignore the critics. You're a pilot, not an actor in a bad play. I'd also say LOUDLY that if it helps me to use some other freq. than 123.3 or CTAF or whatever for my formation flight, I do it. I also have a personal limitation that I won't fly glider formation without an audio vario, and I casually slink away when someone joins my thermal... It doesn't mean I don't like the other guy, I'm just not that great at multitasking... In article , Martin Hellman wrote: Paul and Will's family have my sincere sympathy. What a horrible tragedy to have to live through, and live with. But if any good is to come out of such a horrible event, it is for the rest of us to try and learn how we might reduce the chance of another such tragedy. For that, Paul and the other posters have my gratitude. A few thoughts on that topic: 1. While greater use of the radio probably would have prevented this accident, no one has mentioned the pressure we all feel to minimize such use so as to not interfere with other pilots who also need the frequency. There just aren't enough air-to-air frequencies for all of us to be in constant contact with nearby gliders on a busy day. Anyone who uses 123.3 or 123.5 as much as they need to always know where their flying buddy is will get chewed out for overuse of the frequency. But there is a solution. Get the people you fly with to get their ham licenses and radios, or more simply and cheaply (but less range - but hey, we're talking about midairs) the unlicensed FRS radios. I just bought two of the latter for well under $100 at Costco since my most frequent flying buddy has them. I'm also waiting for him to get his ham license. 2. While, as noted, GPS can be a distraction if misused, it is also invaluable for collision avoidance. If both gliders have the same destination dialed in, they can give bearing and distance to quickly determine when they are in close proximity to one another. Visual references are much less precise. 3. The European PPT post at first left me thinking, "not much use", but as I'll explain below, more thought led me to think it may have a lot of merit. I, as many others, have thought that a low cost device like that described was a much better approach than the expensive ones being pursued by the powers that be. If it was portable, there would be no need for a 337 or other paperwork. The big problem, and the one that made me have an initial negative reaction to the utility of the idea, is the "chicken and egg problem." The device is of no use until a significant fraction of the fleet has one, and who wants one before it is useful? So what made me change my mind? The realization that gliders, or other planes, that fly in close proximity to one another could benefit immensely from the device even if no one else had it but those two aircraft. If it were available for a few hundred dollars (and in large quantity production there's no reason they should cost even that much -- except for the possible liability and patent issues mentioned in the PPT slides), I suspect I could convince my frequent flying buddies to get them too. And, maybe that's the way to get over the chicken and egg problemfor them to be useful for general midair collision avoidance. If we ever reached the point that a significant fraction of the whole fleet bought them to avoid hitting their flying buddies, then they'd become even more useful. 4. The last point has to do with complacency. When put that way, it sounds too mundane. We all know the danger of compacency. Or do we? On reflecting on this thread, I realized I needed to be less complacent in ways that hadn't hit me before. I have had a similar situation to Paul and Will's, where I was flying in close proximity to a friend, one of us moved away, neither of us had the other in sight, I was concerned, but felt that one more radio call just to confirm that all was OK would sound compulsive or amateurish. After all, I've been in that situation many times, with no ill consequences. And none of the other guys flying close to one another are constantly checking. Just listen to the frequency. So I didn't call on the radio for fear of becoming a nuisance either to my friend or the others on the frequency. But after being a part of this thread, I am committing to being extra wary of doing that again. One of the problems with complacency is that it wears many disguises, in this case that of the competent pilot. In this disguise, we believe that only a rank beginner or scaredy-cat would be constantly giving in to his fears of "where did he go" and hitting the PTT each time. Hoping these thoughts are of some help. Martin -- ------------+ Mark Boyd Avenal, California, USA |
![]() "Tom Seim" wrote in message om... Your description of the accident was very articulate and sobering. I would like to hear more about the bailout. In particular: 1. What was your approx. altitude (AGL) at collision. Roughly 1000-1300' It's hard to say because I'm not sure if we collided over this little shoulder that juts out from the ridge or out over the steet terrain below, that drops 3000 feet very quickly. 2. How difficult was it for you to exit the glider and how much altitude did you lose in the process. Unknown, I blacked out momentarily, probably due to my head striking the canopy, so I have no idea how much time elapsed between the collision and when I began to egress the glider. It could have only been a second or two because, my glider hit the ridge about 200 or 300 yards from Will's crash site. See #4 for more detail. I would point out, due to my close proxmity to the ground, if my canopy had not shattered due to my head and the force of the collision, I may not have had time to unlatch it AND perform the rest of the egress. 3. What was your attitude when you pulled the rip cord. Approximately 500ft, I was under canopy 2 seconds or so before I landed in the tree. I remember pulling the ripcord and seeing it come out of the chute in my hand... As I wondered whether something was broken or not I remember seeing cord and fabric flying out of the corner of my left eye. I felt the tug of it open, I looked up to see it opening, I looked down and saw trees everywhere, and then I was in one. 4. Did you have any problems separating from the glider. It was probably in a spin of some sort due to the wing damage and I remember really struggling to push myself out. At the time I thought it was the horrendous wind blowing me back inside, but now I think it probably had more to do with centripidal force from the glider's flight path. What I ended up doing is reaching my left arm and elbow out over the back of the left wing (This was a Libelle 201B) and I leveraged my body out of the cockpit with that arm and my feet. I don't remember exactly how it happened that my body rolled over the wing but, I imagine the nose down attitude combined with the increasing airspeed helped flip me over the wing once my feet and legs were free of the cockpit. I imagine I was just lucky that I didn't hit the tail. 5. What brand of chute did you have. The tag from the chute says Silver Parachute Sales & Service. I bought it with the glider and took it to a local repacker who checked it out, said it was in good shape, and repacked it for me. The Canopy was a Steerable National Phanton 28' which I guess has the longer shrouds for a lower descent rate and may have saved me a much harder landing. It may not have mattered though, because I landed in a Hemlock which have very soft tops and give quite easily. One of the amusing things I look back on now is this strange, surreal sense of disappointment I had after landing in the tree that I didn't have time to try steering the chute. The Harness was the Original Softie Back 0247-S and was maufactured by Para-Phernalia. I did talk to Allen Silver who runs or owns that above company and he pointed me to a website and was helpful in providing some information that I didn't know prior to using this rig. I should mention that I had NOT had any training in egress or bail out procedures. What I did do is sit in the glider and pretend I was going down and go through the motions a few times, I just "thought" about getting out, so when the time came I didn't have to. It paid off, my hands went right to the appropriate places and preformed just the right functions. It was especially fortunate I did all this as it was only my third flight in the Libelle 201B with that rig and belts. 6. Did you have any injuries landing in the trees. Not that I could tell, I did discover my face injury from the canopy once I was in the tree. I also discovered my legs were very bruised and sore, probably from kicking the bottom of the instrument panel while I tried to bail out. 7. What problems did you have getting down to the ground after landing in the trees. I was lucky as the trees were newer growth and smaller diameter, I was able to use the harness as a swing and get over to another, smaller diameter tree that I slide down like a pole. There were small twiggy branches that helped slow my fall, but it wasn't bad. If I had been in much larger trees with no lower branches and large trunks, I would have probably been stuck. 8. Did either glider have an ELT. No, and though I may not shell out the bucks for a full size ELT in the future, I most certainly will purchase the pocket models that can be carried on one's person. It's easy for me to imagine a scenario where the glider travels quite a distance from the bail out point and I'd rather have the ELT on my person than in the glider. Also, I had a portable radio, but it was hooked to a BNC cable for the ships antennae. If one doesn't have a protable ELT, I couldn't recommend more just keeping the portable on your person and buying a fixed ship radio. thx, Tom Seim Richland, WA |
Thanks for the in-depth response. This could very well be helpful to
the rest of us who hope to never be in a similar situation. BTW: it is customary to buy that repacker a bottle/case of his favorite drink. Tom |
Already in the works... He likes single malt Scotch which runs about $60 a
bottle here, small price to pay, though. Paul "Tom Seim" wrote in message om... Thanks for the in-depth response. This could very well be helpful to the rest of us who hope to never be in a similar situation. BTW: it is customary to buy that repacker a bottle/case of his favorite drink. Tom |
A few more thoughts that a private email question spurred me to sha
We were almost exactly at 90 degrees to each others nose at the time of collision. I could probably have looked 45 degrees to the left and not seen him in peripheral vision because there was no relative change in his position to mine. Despite our relative locations though, we had enough closure for a serious collision. The other oddity; though he was banking away from me, he was just at his point in the circle where my flight path was tangent to the outside of his turn. Thus he probably had to look OVER the high side of his cockpit to see me or perhaps I was even hidden under his nose as he came around. Judging by his position when I heard his call over the radio, he saw me in the former situation, probably because he at first was looking for me in a turn behind him and not out in front. I realize now that scanning from 100 to 80 degrees on either side of the cockpit was something I almost never did outside of turns. When I would make small course adjustments or was flying straight ahead, I think it was rare for me to look farther than 60 degrees to the side. Also, when IN turns I think I tend to look around the corner of my turn more often than straight ahead, perhaps Will did the same thing. With an audio vario my guess is a pilot might stop looking down to the instrument panel after establishing a turn and centering the yaw string. If somebody was on a tangent that would intercept a turn, they might appear right in front or perhaps under the nose of the glider and stationary. His DG-400 surely had a few knots over my Libelle, so it may very well have been one of those situations mentioned in a previous post about lower performance glider boxing in higher performance glider. Paul |
Bravo Paul, I am glad that someone who has experienced that
you just have, has the cojones to lay out the events for the rest of us so that we can all put a little pride aside and learn a little something. Hopefully your comments will help the rest of us avoid a similar experience. I am sure, in this newsgroup, your comments will draw plenty of conjecture from the enlightened, but from those of us who don't know it all. Thanks!jeff At 02:12 16 April 2004, Paul Adriance wrote:A few more thoughts that a private email question spurred me to shaWe were almost exactly at 90 degrees to each others nose at the time ofcollision. I could probably have looked 45 degrees to the left and not seenhim in peripheral vision because there was no relative change in hisposition to mine. Despite our relative locations though, we had enoughclosure for a serious collision. The other oddity; though he was bankingaway from me, he was just at his point in the circle where my flight pathwas tangent to the outside of his turn. Thus he probably had to look OVERthe high side of his cockpit to see me or perhaps I was even hidden underhis nose as he came around. Judging by his position when I heard his callover the radio, he saw me in the former situation, probably because he atfirst was looking for me in a turn behind him and not out in front.I realize now that scanning from 100 to 80 degrees on either side of thecockpit was something I almost never did outside of turns. When I wouldmake small course adjustments or was flying straight ahead, I think it wasrare for me to look farther than 60 degrees to the side. Also, when INturns I think I tend to look around the corner of my turn more often thanstraight ahead, perhaps Will did the same thing. With an audio vario myguess is a pilot might stop looking down to the instrument panel afterestablishing a turn and centering the yaw string. If somebody was on atangent that would intercept a turn, they might appear right in front orperhaps under the nose of the glider and stationary. His DG-400 surely hada few knots over my Libelle, so it may very well have been one of thosesituations mentioned in a previous post about lower performance gliderboxing in higher performance glider.Paul |
Distance Task Opinions? | Kilo Charlie | Soaring | 14 | September 6th 03 04:23 AM |
