Larry Dighera wrote:
On Thu, 17 Feb 2005 07:55:51 GMT, Mike Williamson wrote in . net:: Additionally, good training, particularly for fighter/attack types, require a pretty good proportion of clear weather, which makes New Mexico, Arizona, etc., prime training grounds. What is your feeling about the likely success or failure of the use of see-and-avoid to separate 5,000' AGL supersonic military aircraft from VFR civil aircraft within joint-use MOA airspace? As I see it, VFR traffic is never *required* to fly through the MOA, and I'd certainly recommend against it. If you don't feel that those that would fly through it aren't capable of exercising the required caution, then by all means campaign to have all the MOAs turned into restricted areas... |
On Thu, 17 Feb 2005 14:06:19 GMT, Mike Williamson
wrote in et:: Larry Dighera wrote: On Thu, 17 Feb 2005 07:55:51 GMT, Mike Williamson wrote in . net:: What is your feeling about the likely success or failure of the use of see-and-avoid to separate 5,000' AGL supersonic military aircraft from VFR civil aircraft within joint-use MOA airspace? As I see it, VFR traffic is never *required* to fly through the MOA, and I'd certainly recommend against it. Then you are more safety conscious than those who drafted the EIS for the USAF who specifically mention VFR transition of the proposed MOA expansion for supersonic operations. If you don't feel that those that would fly through it aren't capable of exercising the required caution, In the case of VFR transition through a MOA with ongoing supersonic operations, it's not so much a matter of being capable; it's more about the physical limitations of spotting the frontal profile of a gray fighter aircraft against a gray sky in time to identify it as a threat, making the desired control inputs, and having your aircraft respond quickly enough to avoid the supersonic threat. then by all means campaign to have all the MOAs turned into restricted areas... Well, of course, that's not necessary. There is not supersonic training occurring in _all_ the MOAs. What I've found to be particularly useful is contacting the military ATC, and making them aware of my position and intended route, so they can shield me from the military operations occurring in the MOA (by alerting nearby participating military aircraft) and providing radar traffic advisories. Doesn't civilian communication with military controllers just make good sense for VFR civil aircraft transiting a hot MOA? |
On Thu, 17 Feb 2005 17:03:37 GMT, Larry Dighera
wrote: What I've found to be particularly useful is contacting the military ATC, and making them aware of my position and intended route, so they can shield me from the military operations occurring in the MOA (by alerting nearby participating military aircraft) and providing radar traffic advisories. Doesn't civilian communication with military controllers just make good sense for VFR civil aircraft transiting a hot MOA? It makes imminent good sense, but there are some flaws in your rationale. 1.) the "military ATC" (an oxymoron at this point regarding MOAs) operates on UHF, while you in your GA aircraft use VHF. While the military RAPCON and tower may have VHF capability, they often don't monitor beyond their primary frequency or you may not have access to the one Victor freq. they do monitor. 2.) they aren't responsible for the MOA. The FAA is. 3.) they seldom have radar coverage of the MOA, since it isn't their responsibility. 4.) Even if they did have radar, they did have Victor, and they wouldn't be stepping on ATC's toes, they aren't going to deconflict you if you are VFR. 5.) Once cleared to operate in the MOA by ATC, the military aircraft are on a discrete UHF frequency. They don't maintain a vector long enough for ATC to provide any sort of prediction of flight path and they may be contactable by ATC only on Guard. The ATC controller has the MOA discrete, but won't be listening to the in flight chatter which may be secure anyway. 6.) It is a poorly understood concept of IFR that somehow someone "can shield me"--you are only guaranteed separation from other traffic if you a a.) on an IFR flight plan b.) in controlled airspace c.) in IMC If you fail to meeet any one of those three conditions, the responsibility for safe separation returns to the basic principle of VFR, "see-and-avoid". Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
![]() Ed Rasimus wrote: 2.) they aren't responsible for the MOA. The FAA is. 3.) they seldom have radar coverage of the MOA, since it isn't their responsibility. Exactly. Flying out here in the West it's not uncommon to transit several MOAs in the course of a long XC. I just contact Center on the local frequency and get advisories. They will steer you away from any military activity if the MOA is hot. There are some locations that have a dedicated advisory frequency for operations in high traffic MOAs. I'm not sure whether its a military or civilian agency that is providing the advisory service, but I really don't care. As I recall, one such area is north of Nellis/Las Vegas. John Galban=====N4BQ (PA28-180) |
On Thu, 17 Feb 2005 10:30:44 -0700, Ed Rasimus
wrote in :: On Thu, 17 Feb 2005 17:03:37 GMT, Larry Dighera wrote: What I've found to be particularly useful is contacting the military ATC, and making them aware of my position and intended route, so they can shield me from the military operations occurring in the MOA (by alerting nearby participating military aircraft) and providing radar traffic advisories. Doesn't civilian communication with military controllers just make good sense for VFR civil aircraft transiting a hot MOA? It makes imminent good sense, but there are some flaws in your rationale. 1.) the "military ATC" (an oxymoron at this point regarding MOAs) operates on UHF, while you in your GA aircraft use VHF. While the military RAPCON and tower may have VHF capability, they often don't monitor beyond their primary frequency or you may not have access to the one Victor freq. they do monitor. In my case, Center handed me off to the military controller on a VHF frequency. I was northbound out of Mormon Mesa VORTAC to Lincoln, County Airport (1L1) in Nevada, which is about 30 miles west of the eastern border of the Desert MOA (floor 100' AGL). There's a note on the Las Vegas sectional chart advising pilots to "contact Nellis Control on 126.65 or nearest FSS prior to entering MOA." So I suppose they are expecting to provide some assistance to VFR flights. 2.) they aren't responsible for the MOA. The FAA is. As I was VFR, no one but me was taking _responsibility_ for my flight. 3.) they seldom have radar coverage of the MOA, since it isn't their responsibility. This military controller apparently had me on radar. 4.) Even if they did have radar, they did have Victor, and they wouldn't be stepping on ATC's toes, they aren't going to deconflict you if you are VFR. As I stated initially, the military controller wasn't providing separation. He was just alerting nearby participating military aircraft and providing radar traffic advisories for me. The military controller was aware of my position, and although I couldn't hear his communications with the military aircraft, he seemed to be attempting to keep us separated. 5.) Once cleared to operate in the MOA by ATC, the military aircraft are on a discrete UHF frequency. They don't maintain a vector long enough for ATC to provide any sort of prediction of flight path and they may be contactable by ATC only on Guard. The ATC controller has the MOA discrete, but won't be listening to the in flight chatter which may be secure anyway. 6.) It is a poorly understood concept of IFR that somehow someone "can shield me"--you are only guaranteed separation from other traffic if you a a.) on an IFR flight plan In Class G airspace, IFR flights are not separated by ATC. b.) in controlled airspace Actually, VFR flights in Class C controlled airspace are not separated by ATC. c.) in IMC That seems redundant with 'a' above. If you're in IMC without benefit of an IFR clearance, you've got bigger issues than separation from other traffic. If you fail to meeet any one of those three conditions, the responsibility for safe separation returns to the basic principle of VFR, "see-and-avoid". Actually, if you are in VMC at any time, you are _required_ to see-and-avoid. But military pilots on VR MTRs don't seem to appreciate that fact: http://www.ntsb.gov/ntsb/brief.asp?e...13X33340&key=1 Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
![]() "Mike Williamson" wrote in message ink.net... There is less airspace used by the military than there used to be. Don't know what it looked like before, but there is sure a lot potentially tied up: http://makeashorterlink.com/?G1942408A |
On Thu, 17 Feb 2005 12:52:57 GMT, "Blueskies"
wrote in :: "Mike Williamson" wrote in message link.net... There is less airspace used by the military than there used to be. Don't know what it looked like before, but there is sure a lot potentially tied up: http://makeashorterlink.com/?G1942408A That's an interesting link. Thanks. Unfortunately, the depiction of Special Use Airspace is incomplete. It fails to show Military Training Routes. That spider web of routes ensnares most of the west. Finding the current status of MTRs continues to be a problem for pilots. |
wrote: Blueskies wrote: "Ed Rasimus" wrote in message ... Airspace is airspace. There are no comments about anyone not wanting our pilots to be properly trained. There should be a big chunk set aside, say, out over the pacific or something, for all the air to air training. They would be able to turn and burn and go mach whatever without worrying too much (oh, they do that already?). If the folks need to do the air to ground work, there is already plenty of space out in Nevada and Calif set aside for that. Why all the airspace grabs these days? Please edit your post more carefully. The above quote was not said by me and the attribution line refers to my specific refutation of the absurd suggestion. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
![]() " Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com Sounds like a good book, Ed. I look forward to reading it some day.... |
On Thu, 17 Feb 2005 16:56:49 GMT, "Blueskies"
wrote: " Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com Sounds like a good book, Ed. I look forward to reading it some day.... Ask your local library or buy the paperback: http://www.amazon.com/exec/obidos/tg...glance&s=books Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" www.thunderchief.org www.thundertales.blogspot.com |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 06:12 PM |
AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Piloting | 12 | April 26th 04 06:12 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
